What Is the Correct Spacing for Diffraction Grating Lines?
In summary, using the diffraction grating equation, we can determine the spacing of the lines to be 7400 nm for a third-order maximum at an angle of 22 degrees for red light with a wavelength of 694.3 nm. For the second problem, we can calculate the highest spectral order visible as 6 for a 6200-line/cm grating illuminated with 633-nm laser light. For the third problem, we can use the index of refraction equation to find that the thickness of the oil slick is 193.5 nm for a maximum reflection with orange light, but the answer in the textbook may be due to a rounding error.
tambourine
A diffraction grating produces a third-order maximum, at an angle of 22 degrees, for red light (694.3 nm). Determine the spacing of the lines.
for maxima:
sin θm = mλ/d
where m is the order of the maxima, λ is the wavelength in nm, and d is the spacing of the lines
λ = 694.3 nm
θ = 22
m = 3
d = mλ / sin θ
d = 3 (694.3) / sin 22
d = 5560 nm
but the answer in the textbook is 7400 nm. what have i done wrong?
and this one:
Calculate the highest spectral order visible when a 6200-line/cm grating is illuminated with 633-nm laser light.
d = 1/6200 cm
λ = 633 nm = 6.33 x 10^9 cm
n = ?
how do i find n without θ? I'm probably missing some obvious things
interference in thin films:
A transparent oil (n=1.29) spills onto the surface of water (n=1.33), producing a maximum of reflection with normally incident orange light, with a wavelength of 6.00 x 10^-7 m in air. Assuming the maximum occurs in the first order, determine the thickness of the oil slick.
n[oil] = λair/λoil
where n is the index of refraction of oil
λoil = n[oil]λair
= 1.29(6.00 x 10^-7)
λoil = 7.74 x 10^-7
then,
t = λoil / 4
where t is the thickness of the oil and λ/4 is when the first maximum occurs
t = 7.74 x 10^-7/4
t = 1.935 x 10^-7 m = 193.5 nm
the answer is supposed to be 233 nm.
here, but could you provide some guidance on how to approach these problems?
It looks like you have the correct equations and approach for both problems. For the first problem, make sure that you are using the correct units for the spacing of the lines. The answer in the textbook is given in nanometers (nm), so you may need to convert your answer from centimeters (cm) to nanometers. Additionally, double check your calculations to make sure there are no errors.
For the second problem, you are correct that you cannot find the order (n) without knowing the angle (θ). This is because the equation for maxima involves both the order and the angle. It is possible that this problem is asking for the maximum order that can be seen with the given grating, in which case you would use the equation n = d/λ. This would give you the order in terms of the spacing of the lines and the wavelength, rather than the angle. However, without more information, it is difficult to determine the correct approach for this problem. I would recommend checking with your teacher or referring to the textbook for clarification.
FAQ: What Is the Correct Spacing for Diffraction Grating Lines?
1. What is light?
Light is a form of electromagnetic radiation that is visible to the human eye. It is made up of particles called photons, which have both wave-like and particle-like properties.
2. What is diffraction?
Diffraction is the bending and spreading of waves as they pass through an opening or around an obstacle. In the case of light, it refers to the bending of light waves as they pass through a narrow slit or are scattered off of a surface.
3. How do diffraction gratings work?
Diffraction gratings are made up of a series of parallel, closely spaced lines or slits that act as narrow openings for light to pass through. When light passes through a diffraction grating, the light waves are diffracted and interfere with each other, producing a pattern of bright and dark spots called an interference pattern.
4. What is the purpose of using a diffraction grating?
Diffraction gratings are used to separate light into its component wavelengths, similar to a prism. This is because different wavelengths of light diffract at different angles, creating distinct interference patterns. They are also used in spectrometers to analyze the spectral composition of light sources.
5. How are diffraction gratings made?
Diffraction gratings are typically made by etching or imprinting parallel lines onto a reflective surface, such as glass or metal. The distance between the lines determines the spacing of the diffraction pattern, and the number of lines per unit length determines the grating's resolution. They can also be made using holographic techniques.
