- #36
elou
- 74
- 3
Ibix said:How can the mirror miss what?
Never mind. I think this discussion has gotten as far as it could.Ibix said:How can the mirror miss what?
elou said:But the scattered particles have to come together again,
These two quotations make me wonder what is your idea of what is actually going on. I think it's necessary to sum up all the ideas in this thread.elou said:How can the mirror miss?
Would you be able to see the reflection of your hand in a mirror in space?elou said:if I do the same experiment in outer space, where there is no scattering, would I still see the glow of the laser in the mirror?
I don't know. Do you?Dale said:Would you be able to see the reflection of your hand in a mirror in space?
I'm really interested in why you think the answer might be "no". (It's "yes", by the way, assuming there's a light source like a star around.)elou said:I don't know.
Yes, @Dale does. He knows whether you could see your hand for a whole host of scenarios that match the description "hand in a mirror in space".elou said:I don't know. Do you?
As @jbriggs444 said, I was intending for you to put your thoughts down.elou said:I don't know. Do you?
Very kind of you to point at all the things I should worry about. The question was not what happens when things get hit by a beam, but what scattering means in outer space. If you could tell me what is being scattered in outer space and how that relates to the reflection of the laser head on the mirror, we can end this discussion with me much wiser than I started.jbriggs444 said:Yes, @Dale does. He knows whether you could see your hand for a whole host of scenarios that match the description "hand in a mirror in space".
His question was an invitation for you to think. And to think out loud so that we can troubleshoot your reasoning.
Feel free to specify any missing details:
Is there a line of sight with a valid reflection angle from hand to eye?
Does this mean that there is necessarily also a line of sight from eye to hand?
Is the hand illuminated? Illuminated on the portion that faces the line of sight?
How do you think seeing works?
Same as it means anywhere else. Light hits a particle or something and some of the energy reflects off it. When the reflection isn't in one direction because the surface light is reflecting off isn't flat and smooth, we call it scattering.elou said:what scattering means in outer space.
Completely unrelated, unless you start spraying smoke. Any scattering off the few bits of space dust the beam might encounter are pretty much negligible.elou said:how that relates to the reflection of the laser head on the mirror
Light comes out of a light source and hits an object, which scatters it in all directions (note that some materials reflect directionally, like mirrors, and most materials do a bit of both). Some of the scattered light might hit a mirror, and bounces off that. If it reaches your eye, you see it.elou said:If we are looking not at something being illuminated, but at its reflection on a mirror, what is exactly happening that makes the mirror reflect the object, and us see the reflection. That is in short, what I would like to understand.
Yes , of course. And because there is no way to make the scattering visible, we just have to take it in good faith.Ibix said:Same as it means anywhere else. Light hits a particle or something and some of the energy reflects off it. When the reflection isn't in one direction because the surface light is reflecting off isn't flat and smooth, we call it scattering.
Which scattering? The scattering off the illuminated object? How else do you think we see it?elou said:And because there is no way to make the scattering visible
I don't know.Ibix said:Which scattering? The scattering off the illuminated object? How else do you think we see it?
If you can't think of an alternative to scattering to explain how we see illuminated objects, then why do you question that it is scattering?elou said:I don't know.
I am, rightly or wrongly, not convinced. I was hoping to find a clear answer one way or another.A.T. said:If you can't think of an alternative to scattering to explain how we see illuminated objects, then why do you question that it is scattering?
A mirror does "specular reflection". Most ordinary objects (trees, grass, sand, concrete, wood, birds, hands, etc) do "diffuse reflection". As @Ibix tried to say without using the big words.elou said:If we are looking not at something being illuminated, but at its reflection on a mirror, what is exactly happening that makes the mirror reflect the object, and us see the reflection.
A very nice summary of reflection phenomena.jbriggs444 said:A mirror does "specular reflection". Most ordinary objects (trees, grass, sand, concrete, wood, birds, hands, etc) do "diffuse reflection". As @Ibix tried to say without using the big words.
In specular reflection, an incident ray is all reflected in a single direction. You know: angle of reflection equals angle of incidence. This is characteristic of smooth surfaces. In terms of wave optics (think Huygen's principle), the ray path is one that extremizes path length, at least locally. Importantly, this means that the first derivitive of path length with respect to impact location is zero. Small deviations from the center of line result in wave forms that interfere constructively.
By contrast, microscopially rough surfaces tend to reflect diffusely. Small deviations from the center line result in significant variations in path length. There is no constructive interference.
With specular reflection, nearly equal angles of incidence yield nearly equal angles of reflection. A beam of light is all reflected the same way. The angle of reflection yields information on the location of the source.
With diffuse reflection, the angle of reflection tells us nothing about the angle of incidence. The location of the illumination source is not determinable by observing the diffusely reflected light.
We "see" a point on an illuminated object because the portion of the light that is emitted in a very narrow fan-shaped arc stays aligned with the rest of that fan-shaped spray all the way to our eye. The lens of the eye is then able to focus all of that incident light at a single point on the retina that corresponds to the angle of incidence on the eye. This yields what might be seen as a two-dimensional hemispherical bit map of the light incident on the eye.
Post-processing in the eye and the visual cortex mean that the bit map metaphor is not technically apt. But it is good enough for purposes of the ray optics we are discussing.
elou said:not convinced.
I have a feeling that you are demanding 'spoon feeding' about this. If you put a postage stamp to cover the beam, all the light will be reflected / blocked and you will see a red disc and there will be a shadow behind it. If you put a grain of rice in the beam, it will block / reflect some / most of the beam. If you put a speck of dust, you will see it because it reflects a small proportion of the beam. For very small items, the light may be scattered in all directions due to diffraction.elou said:I am, rightly or wrongly, not convinced. I was hoping to find a clear answer one way or another.
Our eyes see light that enters the eye.elou said:what is exactly happening that makes the mirror reflect the object, and us see the reflection
You can lead a horse to water. . . . .Dale said:Our eyes see light that enters the eye.
If you are in a dark room you cannot see anything because there is no light to enter your eye from anything.
If you turn on a light bulb in the room then light from the bulb hits your hand and scatters in all directions. One of those directions is from your hand to your eye. That light enters your eye and you see your hand.
If there is a mirror in the room then there are two directions from your hand to your eye. The direct one described above, and one that reflects off the mirror. So light can reach your eye by scattering off your hand in two directions. You can see the back of your hand directly (for example) while light from the palm of your hand scatters off the palm in all directions including the one that hits the mirror and reflects to your eye.
Then clearly explain what is still unclear.elou said:I was hoping to find a clear answer one way or another.
... but you can't make him think.sophiecentaur said:You can lead a horse to water. . . . .
I am glad we could help.elou said:As far as I am concerned, this thread can be closed.
