Light Emission by Stars: Mass, Red Shift & Hubble's Law
  • I
  • Thread starter gptejms
  • Tags
    Light Star
In summary: The two effects are quite different in their physical origin; one might say that the first is due to time dilation and the second to space dilatation. Such a difference would be very hard to explain in tired light theories. . . ."In summary, gravitational redshift is a well-established phenomenon dating back to at least 1954. While it may contribute to the redshift seen in Hubble's law, it is not the only factor and its effect becomes less significant the further away the stars are. Alternative explanations, such as the idea of space being a medium that absorbs radiation, have been proposed but have not been able to fully explain the observed
gptejms
386
TL;DR Summary
Light emitted by a star should be affected (red shifted) by the gravitational pull of its own meaning thereby that light from bigger/ more massive stars should be red shifted more-- is this established?
Light emitted by a star should be gravitationally red shifted by its own mass, resulting in greater red shift of light emitted by a more massive star. Is this phenomenon known? Could this be contributing in Hubble 's law in some part too-- probably more distant stars are more massive too-- just guessing!
Likes FactChecker
gptejms said:
Hubble's law talks of only distance and not the mass of emitting star---is this effect negligible?
The link above is about measurable gravitational redshift, not Hubble's law. It talks about measuring the gravitational redshift of light from the Sun, for example.
That's right, but my question is that some part of the redshift attributed to receding of galaxies is actually due to the gravitational pull of its own star--is this part so small that it can be neglected altogether?
The gravitational redshift only depends on the mass of the star. That becomes less significant the further away the star is. I'm pretty sure it's not negligible in all cases. It's another complexity in measuring the recession at a smaller redshift.
Mass and radius, I think. I don't think one is wholely determined by the other.
Galaxies are full of stars of different masses. The effect would "blur" the cosmological red shift of a galaxy slightly, since some of its stars would have cosmological red shift plus a little gravitational red shift while others would have the same cosmological red shift plus a larger gravitational contribution. They all already have kinematic Doppler from their circulation around the galaxy.
The key point is that I wouldn't expect a pattern with distance from gravitational red shift. So it would become a less significant issue the further away you looked.
We can observe red shift by gravity for the stars in our own galaxy where Hubble's law is negligible or does not stand due to inhomogeneous distribution of energy in that scale. As for stars in other galaxies, I wonder if we can distinguish light of a star from other stars in that same galaxy by our current technology.
Actually, I am slowly trying to inch towards alternative explanations of Hubble's law.Recession of galaxies is the accepted view, but there may be other possible explanations. For example, if space were a medium like any other medium, it would absorb radiation(more at the higher frequency end) leading to frequency attenuation. This would also explain greater redshift of farther galaxies. Even though space is not accepted to be a medium, why not look for such simpler explanations rather than jumping into expanding universe model?
  • Skeptical
Likes Dale and weirdoguy
No it wouldn't. Spectral lines wouldn't appear at redshifted frequencies. And there's no dispersion.
Because no simpler explanation consistent with red shift, the CMB and its power spectrum, the theoretical framework of general relativity, and more abstruse concepts like the integrated Sachs-Wolfe effect has ever been found. And the FLRW solution to Einstein's field equations is one of the simplest ever found.
It's not that other solutions haven't been tried (look up "tired light" for starters). It's that you have to pile special case on special case to make them consistent with observation.
Likes PeroK
This not observed. Steven Weinberg, in his 2008 graduate-level book Cosmology, writes
"For instance, one important difference between "tired light" theories and the conventional big bang theory is that in the conventional theory all rates at the source are decreased by a factor ##(1+z)^{−1}##, while in tired light theories there is no such slowing down. One rate that is slowed down at large redshifts in the conventional theory is the rate at which photons are emitted by the source. This is responsible for one of two factors of ##(1+z)^{−1}## in ... apparent luminosity, the other factor being due to the reduction of energy of individual photons. On the other hand, if the rate of photon emission is not affected by the redshift, then in a static Euclidean universe in which photons lose energy as they travel to us, the apparent luminosity of distant source ... will be given by ... only a single factor of ##1+z## in the denominator."
Likes vanhees71 and Ibix
Please respect the forum mission statement: "Our mission is to provide a place for people (whether students, professional scientists, or others interested in science) to learn and discuss science as it is currently generally understood and practiced by the professional scientific community. " (emphasis mine)
Discussion of the (overwhelming) evidence for recession is good, and discussion of why the alternatives fail is acceptable as long as it does not slide into personal speculation, but we will not host a discussion that "inches towards alternative explanations".
Likes Dale and vanhees71
I was just trying to understand why alternate explanations if any haven't been accepted or looked into.
Is z the distance? Why (1+z)^-1?
##z## is the usual way of expressing cosmological redshift. ##z=0## is right here and increases with distance, whether you are talking about the frequency shift (which scales as ##(1+z)^{-1}##) or wavelength shift (which scales as ##(1+z)##).
Simple question: what is z?
##z## is relative change in wavelength. In terms of a mathematical definition, ##z## is given by
$$1 + z = \frac{\lambda_{obs}} {\lambda_{em}},$$
so that
$$z = \frac{\lambda_{obs}} {\lambda_{em}} - 1 = \frac{\lambda_{obs} - \lambda_{em}} {\lambda_{em}} = \frac{\Delta \lambda} {\lambda_{em}}.$$
If you want to compete, you have to know at least the most basic of notation and terminology.
Likes vanhees71
so that
Likes vanhees71 and robphy
so that
Compete? What gives you that impression?
This:
Likes robphy
George Jones said:
This:
C' mon I am no expert on GTR and just trying to understand something here-- the only way to do that is by asking questions. You guys need to be more tolerant.
Then a better phrasing would be something like "I am not an expert in GR or cosmology, and I am trying to understand why alternative explanations of redshift do not work."
Likes vanhees71, robphy, Vanadium 50 and 2 others
GR does already, in some sense, incorporate gravitational redshift from large stars/masses. It does not usually separate out the effects of "gravitational redshift" from the effects of "doppler shift due to cosmological expansion". The methodolody doesn't actually care, because the methodology is coordinate independent. Conceptually differentiating these effects is only possible if one takes a coordinate dependent approach to the problem. And the results one gets will depend on the details of one's coordinate choice.
Usually, professionals adopt the cosmological coordinates to do the analysis, which are defined in such a way that expansion of the coordinates is non-zero (as measured by something called the expansion scalar). Roughly speaking, the usual cosmological coordinates expand along with what are called "co-moving" observers. This coordinate choice is most likely non-intuitive to the average reader. It is possible to adopt other coordinates that do not expand in this manner, such as Fermi-Normal coordinates.
At a basic level, we can roughly say that observers with constant cosmological coordinates move with the cosmological expansion. The CMB as measured by such an observer, called a co-moving observer, will be the same in all directions (isotropic). A signal emitted from one co-moving observer to another will experience redshift.
Observers in Fermi-Normal coordinates can be thought of as being at rest relative to each other (in some sense, at least. Technically it might be better to say that they expansion scalar of these coordinates is zero). Furthermore, observers who are at rest in cosmological coordinantes can be regarded as moving relative to observers in Fermi-Normal coordinates, with the velocity between the observers increasing as one moves away from the origin of the Fermi-Normal coordinates.
However, textbooks will generally not treat the cosmological problem in Fermi-Normal coordinates.
I have some intuitions as to what happens in Fermi-Normal coordinates, though I haven't done or seen a thourogh analysis. But basically, what I think should happen is that if it were not for the cosmological constant, there would indeed be be a gravitational redshift associated with objects at rest in Fermi-normal coordinates. However, I believe this changes with the addition of the cosmological constant in the standard ##\Lambda CDM## cosmological model. Uniituitively, the gravitational redshift becomes a gravitational blueshift, and this effect is what makes the expansion of the universe accelerate. Without the cosmological constant, the expansion of the universe would deacclerate.
Tired light idea is different from what I was suggesting(read my post that you replied to above).
Pulling that quote forward...
That theory would not explain a red shift in absorption lines. You'd shift the bulk distribution by selective attenuation, but not the lines within the distribution.
If you are going to try to promote personal theories like this, you may earn yourself some mentor attention.
Likes berkeman
This is personal speculation and is off limits at PF. Your valid question in the OP of this thread has been answered.
Thread closed.
Likes vanhees71
Indeed.
  • Haha
Likes vanhees71 and Vanadium 50
FAQ: Light Emission by Stars: Mass, Red Shift & Hubble's Law
What is light emission by stars?
Light emission by stars refers to the process by which stars release energy in the form of electromagnetic radiation, or light. This light can be visible to the human eye, as well as other forms of light such as infrared and ultraviolet.
How does the mass of a star affect its light emission?
The mass of a star plays a significant role in its light emission. Generally, the more massive a star is, the more energy it can produce and the brighter it will appear. This is because a star's mass determines its core temperature and the rate at which nuclear fusion reactions occur, which are responsible for producing the star's energy and light.
What is red shift in relation to light emission by stars?
Red shift is a phenomenon in which light from a distant object, such as a star, appears to have a longer wavelength than it actually does. This is due to the expansion of the universe, which causes the wavelength of light to stretch as it travels through space. Red shift can also be used to measure the distance of a star from Earth.
How does Hubble's Law relate to light emission by stars?
Hubble's Law states that the farther away a galaxy or star is from Earth, the faster it is moving away from us. This is due to the expansion of the universe. As stars and galaxies move away from us, their light is stretched and appears to have a longer wavelength, resulting in red shift. This law has been used to estimate the age and size of the universe.
Can light emission by stars be used to determine their age?
Yes, light emission by stars can be used to estimate their age. This is because the brightness and color of a star can give clues about its stage of evolution and how long it has been burning. For example, younger stars tend to be brighter and bluer, while older stars are dimmer and redder. By studying the light emission of a star, scientists can make educated guesses about its age and lifespan.
