- #36
S.Vasojevic
- 173
Yes, it will be 'stretched' towards infinite wavelength.
S.Vasojevic said:Yes, it will be 'stretched' towards infinite wavelength.
S.Vasojevic said:... same energy is still there ...
If what we are seeing now were the edge (as in, nothing at all beyond the CMB we see today), then it would be gone tomorrow.DevilsAvocado said:Thanks, but why tomorrow (and not today or x billion years from now)?
Chalnoth said:If what we are seeing now were the edge ...
Well, basically, the matter we see right now as the CMB was, when the light was emitted, undergoing the phase change from a plasma to a gas. I suppose upon further reflection, this phase change probably will take a bit longer than a day. But once the phase change finishes, since you postulated no matter beyond the CMB, there simply wouldn't be any more matter out there to emit new CMB photons, and it would wink out.DevilsAvocado said:Okay thanks.
But... (and now I’m taking a big risk to get lost in pure cosmic confusion) isn’t the Hubble volume 13.8 billion light years...? Wouldn’t there be a 'buffer' (like 46.5 - 13.8 = 32.7 bly) ...?
Edit: Of course this depends on the expansion rate (like DE influence), right?
Edit2: A finite universe could (must?) still expand, right?
Chalnoth said:... if there actually were no matter beyond the current CMB, then that should have really significant effects upon the CMB that we see.
Well, that shouldn't be so surprising...the CMB is much much further away than supernovae are.DevilsAvocado said:Aha! Very interesting!
So the CMB in fact tells us more about the (rest of) universe (> observable universe) then any IA Supernova!? A m a z i n g.
Chalnoth said:Well, that shouldn't be so surprising...the CMB is much much further away than supernovae are.
Well, you don't need to even go into this much detail. It is plenty sufficient to state that at the time the CMB was emitted, our universe was uniform to one part in one hundred thousand. That's uniform enough that stars simply were not possible, let alone supernovae. So all of the CMB photons that we see were already on their way by the time supernovae started to go off.DevilsAvocado said:So the edge of the observable universe, 46.5 billion light-years away, is actually where the CMB is right 'now'? But the light was emitted (13.8 byr - 377,000 yr =) 13,799,623,000 years ago, right?
And the most distant Supernova is 28 billion light-years away? Like in this picture:
Question (if this is correct): So the distance to the CMB is 'calculated', like the calculated position of the Supernova (orange line above)?
Well, that's the way it's going to happen in reality, because there's a lot more stuff out there beyond the CMB we see today. So as the part that we see today as the CMB becomes transparent and stops emitting new photons, there's always a new piece of the CMB just beyond that that is still emitting.Chronos said:SV gets it. You never leave a photon sphere, just redshift into obscurity.
Chalnoth said:... That's uniform enough that stars simply were not possible, let alone supernovae. So all of the CMB photons that we see were already on their way by the time supernovae started to go off.
Chalnoth said:... there's a lot more stuff out there beyond the CMB we see today ...
Chronos said:... You never leave a photon sphere ...
The big bang theory, without inflation, correctly predicts the amount of light elements that we measure. This means that it's basically correct, without modification, to very early times. Inflation proposes some changes to what happens at even earlier times.DevilsAvocado said:Thanks Chalnoth, for the elegant clarification.
And from this we can derive that 'working overtime' won’t do it if 'Albert Laymanstein' is not using his brain– the inflation (of course) must have happen between BB and Recombination to get the uniform CMB (like stretching a wrinkled sheet), right...?
Because the expansion since then affects the relationship between redshift and brightness. Basically, distant supernovae are too dim compared to their redshifts.DevilsAvocado said:One thing still puzzles me: How can Saul Perlmutter and the other guys at the http://en.wikipedia.org/wiki/Supernova_Cosmology_Project" prove that the (DE) expansion is accelerating now, when the information is ~13 billion years old...? I get that is proven from the redshift, but how can one say it’s starting 'now', and not x billion years ago?
Very very indirectly. Basically we expect that any sort of boundary can't be sudden: there's going to be some effects going on near the edge that would be detectable. So in a way, the fact that we see no significant deviations from smoothness and uniformity out to the limits of our vision (the CMB), we know that this smoothness and uniformity must continue for a while beyond the limits of our vision.DevilsAvocado said:That’s what excited me in post #43. There are 'signs' in the current CMB of 'things' outside the observable universe, or?
Chalnoth said:It's not useful, I don't think, to talk about the "big bang" as if it were a singular event that spawned our universe, because that just adds confusion to the fact that the big bang theory describes what happens at later times, and has nothing at all to say about what happened at the earliest of times (or rather, it has some things in the theory, but we know they're completely wrong).
Chalnoth said:Instead, what we know is this: when we look at the past of our universe, the big bang theory describes things correctly back to a certain point. Before that, inflation describes things correctly. But we don't know how inflation started (other than it had to begin somehow). Perhaps if we discover precisely what inflation was, that theory will automatically come along with a method of generating an inflating patch, but we don't yet know.
Chalnoth said:Because the expansion since then affects the relationship between redshift and brightness. Basically, distant supernovae are too dim compared to their redshifts.
Chalnoth said:... there's going to be some effects going on near the edge that would be detectable ...
Yes, basically. It was a derogatory term for the theory. I don't really like "Universe Evolution" either, as Evolution is too closely associated with biological evolution, which is a completely unrelated process.DevilsAvocado said:I read somewhere that the expression "Big Bang" actually came from one of the "steady state” proponents (Fred Hoyle?), as a 'patronizing' joke... and then it became the official name of the theory. A more describing name is perhaps The Universe Evolution Theory...
Most definitely. The fact that the earliest stage of our universe had such vastly lower entropy than our current stage really needs explaining. Sean's got some really good popular articles that go into why this is, such as this one:DevilsAvocado said:Interesting, I watched Sean Carroll (Caltech) & Mark Trodden (UPenn) on Bloggingheads.tv, and in one section http://bloggingheads.tv/diavlogs/21709?in=23:39&out=40:25". At 27:00 Sean state – "You’re attempted to explain why the early universe is so special, by imagine it started out even more special …!"
There’s clearly 'some' work to do...![]()
Well, another aspect of the redshift is time dilation. Basically, if it takes twice as long for the next peak of the electromagnetic wave to arrive, then it also takes twice as long for the next photon to arrive.DevilsAvocado said:Thanks, for the explanation. I read that the photons actually arrive at a 'lower rate' (like a machinegun slowing down) due to the expansion of space. I guess this is causing the 'dusky effect'...
Thanks for taking the time.
Chalnoth said:Most of the stuff we see out there (stuff at very roughly redshift greater than one) is now and always has been receding faster than the speed of light, according to the simplest definition of recession velocity (the definition of recession velocity is actually rather arbitrary).
First, you construct a distance by imagining what would happen if we froze the universe's expansion right now, and timed some light signals between different places. Then you ask how rapidly this distance changes with time. That gives you a relative velocity.S.Vasojevic said:What is the simplest definition of recession velocity, and how it yields recession faster than light for z > 1, and why is Marcus saying that it is safer to say that it is true for z > 1.7 ?
