Light intensity and polarization
In summary, The intensity of light passing through a circular polarization filter is less because the filter removes part of the input, meaning that not all the photons make it through. The energy of an individual photon is not affected by the filter, but the overall energy of the group of photons that pass through is reduced, resulting in a decrease in light intensity.
gespex
56
I have read about light and polarization. One thing I don't understand though... If you would look through a circular polarization filter, you notice that the light is less intense.
But if you look at photons that are unpolarized; they become polarized when they go through the filter. I have read that the x and y components are separated (as x^2 + y^2 = 1).
So I believe the amplitude of the wave of polarized light becomes smaller, and this causes the decreased intensity, is this correct? But if that's the case, how come this photon still has exactly the same amount of energy?
Thanks in advance
gespex, In answer to your last question, the energy of a photon depends only on its frequency, not the amplitude. The amplitude tells you how many photons you have.
Actually for situations like you're describing, I'm puzzled that anyone would want to talk about photons. As far as I know, Maxwell's equations have not yet been repealed! And it is often much easier to talk about electromagnetic waves than photons. Photons are only appropriate in other situations - at very high energy or very low intensity.
Regarding your first question, filters by definition remove part of the input, so naturally the output is less. Your idea that a photon would "become polarized" when passing through the filter is not true - part of the wave (i.e. some of the photons) is/are simply not transmitted.
Thanks for your answer. And that's understandable. But that doesn't answer my main question: what makes the light's intensity less at the other side of a polarization filter? Does that mean energy and light intensity, in this case, are completely unrelated?
Because from what I understand, a circular polarization filter removes one of the wave components but not the other. Meaning that nearly all the waves are let through, with the only exception being waves that are polarized perpendicular to the passed through polarization. The only difference would be the amplitude of the wave, if I can believe the random webpage I read.
This means that nearly all energy would pass through, right? And yet, the intensity of the light on the other side is visibly less.
So, where is the flaw in my logic, or are intensity and energy in light simply unrelated?
You need to distinguish between the energy of one photon and the energy of a group of photons passing through the filter. If an individual photon happens to be passed through the filter, then its energy will be unchanged. If it isn't passed through, then the photon is simply not there on the other side.
Overall, your light wave consists of billions and trillions of individual photons. Some pass through; others do not. What you call the "light intensity" is a number that is proportional to the number of photons present. The energy is of course related to the number of photons that pass through the filter - just add up the individual energies of all the photons that make it through.
FAQ: Light intensity and polarization
What is light intensity and how is it measured?
Light intensity is the amount of light energy passing through a unit area in a given time. It is measured using a device called a light meter, which detects the intensity of light in units such as lux or watts per square meter.
How does light intensity affect the brightness of an object?
The higher the light intensity, the brighter an object appears. This is because the intensity of light determines how many photons are hitting the surface of the object, which in turn affects the amount of light that is reflected or emitted.
What is light polarization and how does it occur?
Light polarization refers to the direction of the electric field of a light wave. This direction can be either linear, circular, or elliptical. Polarization occurs when light waves interact with certain materials, such as filters or crystals, causing the electric field to oscillate in a specific direction.
How does the polarization of light affect its properties?
The polarization of light affects how it interacts with other materials. For example, polarized light can be blocked or transmitted by certain materials, and can also be used to reduce glare. It can also affect the way light is scattered, which is important in fields such as astronomy and remote sensing.
What are some applications of light intensity and polarization in science?
Light intensity and polarization have many applications in science, including in the fields of optics, astronomy, and remote sensing. They are used to study the properties of light, such as its wavelength and energy, and to understand how light interacts with matter. They also have practical applications in areas such as photography, telecommunications, and medical imaging.
