keepitmoving
- 97
if an object moving at .99 c emits a light, does that light move away from the emitter at 1.00 c ?
No it won't. A stationary observer would still measure the speed of light as c. The invariance of the speed of light is a fundamental concept in special relativity.keepitmoving said:if the emitter suddenly stops, does the light know it? If the light doesn`t know it, the light will be moving at c plus the previous speed of the emitter.
In a way it will, but with a different definition of "plus". In SR you have to add up velocities like this:keepitmoving said:the light will be moving at c plus the previous speed of the emitter.
pesto said:Fredrik, what equation is that? Does it have a name I can google? :)
pesto said:Does the [tex]u \oplus v[/tex] means the velocity of the emitter relative to the observer plus the velocity of the photon relative to the emitter? If I could try your patience for one more stupid question, what's a plus sign with a circle around it? Just a sign for adding vectors or what?
Thanks again.
malawi_glenn said:v is the velocity relative the observer for objectA and u is the velocity relative the observer for objectB, always. And [itex]
u \oplus v
[/itex] means the relative velocity of A and B as measured by the observer. [itex]
\oplus
[/itex] means "composition law for velocities under boosts"
In the wiki article this [itex]
u \oplus v
[/itex] is just called "s".
pesto said:Woah! Back to the old drawing board. Thank you for the explanation. I though [tex]u \oplus v[/text] or "s" was the velocity of objectB relative to the observer!
Sorry, that's confused.malawi_glenn said:v is the velocity relative the observer for objectA and u is the velocity relative the observer for objectB, always. And [itex]
u \oplus v
\oplus
u \oplus v
DrGreg said:Sorry, that's confused.
If A, B and C are 3 objects all moving along the same straight lineThe symbol [itex]\oplus[/itex] is not standard notation. Some may use it but others don't. It's just a way of denoting a different way of "adding" velocities. I'd prefer to call it "composition" rather than "addition".
- u is the velocity of B measured by A
- v is the velocity of C measured by B
- [itex]u \oplus v [/itex] is the velocity of C measured by A
Sorry, my intentions weren't clear. That comment was really aimed at Pesto in answer to post #11.malawi_glenn said:yup I know, it was an error, I fixed it.
regarding "composition" vs. "addition" I actually mentioned that [itex]
\oplus
[/itex] stands for "composition" right? why adding that?
Cheers
DrGreg said:Sorry, my intentions weren't clear. That comment was really aimed at Pesto in answer to post #11.
In case anyone reading this thread is confused, I was correcting an error in post #12, but then malawi_glenn corrected his own error at the same time, making my comment out of date by the time I posted it. But it's too late to undo that now without causing even further confusion...
Light moves away from the emitter at a constant speed of 1.00 c, which is equivalent to the speed of light in a vacuum. This means that light travels at approximately 299,792,458 meters per second.
No, nothing can move faster than light at 1.00 c. According to Einstein's theory of relativity, the speed of light is the maximum speed at which all matter and information in the universe can travel.
As light travels at 1.00 c, it affects both time and space. Time dilation occurs when an object is moving at a high speed, causing time to slow down. Also, the length of an object appears to shorten in the direction of its motion.
When light reaches its maximum speed at 1.00 c, it becomes massless and has infinite energy. This is a fundamental aspect of the theory of relativity and is a result of the mass-energy equivalence equation, E=mc^2.
The speed of light at 1.00 c plays a crucial role in the concept of causality. According to the theory of relativity, the speed of light is constant for all observers, regardless of their relative motion. This means that the effects of an event can only be observed after the cause has occurred, and not simultaneously.
