Light Speed in Vacuum vs Media: A Question
In summary, the speed of light is slower in any medium other than a vacuum due to the presence of ions. However, when light passes through a medium and enters a vacuum, it will return to its maximum speed. This is because the speed of light is determined by the characteristics of the medium it is traveling through at any given moment, not by where it has been. This is similar to how other waves behave. The reason for the slower speed in a medium is simply due to the presence of ions, which can alter the speed of the wave. However, in a vacuum, there are no ions present, allowing light to travel at its maximum speed.
HyperUniverse
Hi,
I know the speed of light is the highest in vacuum.
And in any other mediums is a bit slower.
I just want to know...
...if a light passes through a medium (water let's say) and comes out in vacuum, will it retain the same speed as it had in the water, or will it increase back to its maximum speed?
Thanks.
Science news on Phys.org
The light will have its usual (maximum) speed in a vacuum, regardless of where it came from.
Could you be a bit more explicit, please?
Has anybody done such tests? Where can I read more about?
Because I take it like this...let's imagine that we shoot an arrow through the air.
Then the arrow passes through "a floating ball of water" (just imagine it).
Then it comes out of this water, back into the air.
Obviously, when it passed through the water its speed was slower, but when it came out of the water and back into the air, it did not increase its speed back to what it was before entering the water...
So how the light will increase its speed back to maximum when leaving the water?
Thanks
Think of light as a wave, not as an object like an arrow. The speed of a wave depends only on the characteristics of the media its traveling through at any given moment, not on where it's been. In that respect, light acts like any other wave. But for light, the maximum speed is attained when traveling through a vacuum.
Does light ever "slow down" or is it merely absorbed and re-emitted by the atoms of the media it is passing through with the time this takes slowing down the overall "speed"?
The reason light is slower in a medium is not because it is being absorbed and re-emitted.
It is slower simply because of the presence of ions.
How would ions slow down light? The implication is that a bulk material with no ions would allow light to travel at the same speed as in a vacuum, this doesn't seem correct.
In a plasma, the EM wave gets slowed down because of the presence of ions. I guess I assumed that it would be a similar reason for the slowing of an EM wave in normal matter.
But maybe it is slowed down because each of the atoms act slightly like a dipole (which would require a quantum-mechanical treatment?)
FAQ: Light Speed in Vacuum vs Media: A Question
What is the speed of light in a vacuum?
The speed of light in a vacuum is approximately 299,792,458 meters per second, or 186,282 miles per second. This is known as the universal speed limit and is denoted by the symbol c.
How does the speed of light in a vacuum compare to the speed of light in a medium?
The speed of light in a medium is always less than the speed of light in a vacuum. This is due to the fact that light is slowed down as it travels through a medium, such as air, water, or glass. The exact speed of light in a medium depends on the density and composition of the medium.
Why does the speed of light change when it travels through a medium?
Light is an electromagnetic wave, and when it travels through a medium, it interacts with the atoms and molecules of the medium. This interaction causes the light to slow down, as it is absorbed and re-emitted by the particles in the medium.
Is it possible for anything to travel at the speed of light?
According to Einstein's theory of relativity, it is impossible for anything with mass to travel at the speed of light. As an object's speed approaches the speed of light, its mass increases and it requires an infinite amount of energy to continue accelerating. However, particles with no mass, such as photons, can travel at the speed of light.
How does the speed of light in a medium affect the refraction of light?
The speed of light in a medium determines the angle at which light is refracted, or bent, as it travels from one medium to another. The higher the speed of light in a medium, the less the light is bent. This is why light appears to bend when it travels from air to water or from air to glass, as the speed of light is slower in these media compared to air.
