Light Speed Invariance: Experiments, Difficulties & Clarification
In summary, there are many experiments that prove the invariance of the speed of light to observers, but there is no experimental proof of the equivalence of the speed of light between source and observer.
georgechen
TL;DR Summary
There are many experiments proving the constant light speed independent of the motion of source. Is there any experimental proof of the invariance of light speed to observers?
Let me clarify my question, is there any experiment directly proved the invariance of light speed to observers? Let's not get to the argument of equivalence between source and observer.
SR was based on the postulate that the light speed is constant and independent of both the motions of source and observer. There are many experiments proving the constant light speed independent of the motion of source. Is there any experimental proof of the invariance of light speed to observers? If not, what is the difficulty?
Thanks. That was the place that I got my question. You can see only the experiments for
No dependence on source velocity or energy
But not really experiments proving the light speed is invariant to observer velocity.
It's the same thing isn't it? If the source is moving relative to the observer, then the observer is moving relative to the source.
Likes Vanadium 50, russ_watters and Nugatory
Every experiment that shows that the motion of the source doesn’t affect the speed is also a test of the receiver moving - we can choose to interpret either source or receiver to be at rest.
The GPS system is a working example of a large real-life system in which sources and receivers are all in motion relative to one another, and it wouldn‘t work if the speed of light were not invariant.
Likes russ_watters and PeroK
No. That is not correct. Think about Doppler effect. The source movement is not equivalent of the observer's.
Even this is correct, why no one perform an experiment of moving observer vs. source.
  • Sad
  • Skeptical
Likes weirdoguy and PeroK
Yes, it is; that is what the principle of relativity says. Only relative velocity is physically meaningful.
The Doppler effect for light in vacuum depends on relative velocity.
If you are thinking of the Doppler effect for sound, sound doesn't travel in vacuum, only in a medium, so velocities relative to the medium become meaningful.
There is no such thing. There are only experiments in which the source and observer are in relative motion. The fact that Wikipedia describes such experiments as varying "source velocity" is a matter of Wikipedia's choice of words, not physics.
We’re talking about the speed of a light in a vacuum, and the Doppler effect there is symmetrical and depends only on the relative speed between source and receiver.
Think about the scenario of the sound wave from a supersonic jet and an observer in another supersonic jet in front. The source jet movement doesn't impact the speed of sound, otherwise the sound will be supersonic. But the observer jet movement does impact, because the sound wave will never reach the observer.
SR postulates the invariance of the speed of light in vacuum; not the speed of sound in air.
Yes. You are right. Doppler effect doesn't prove there is no equivalence. My question is any experimental proof of the equivalence? Doppler effect is an example that we should not take it for granted.
I already pointed out why considering sound is not relevant in this discussion. See post #7.
Every experimental proof of the principle of relativity--that the laws of physics are the same in all inertial frames--is a proof of the equivalence. There are lots of experimental proofs of the principle of relativity.
That is exactly my point. It is a postulate. Is there any experimental proof? There are many experiments for the invariance to source motion. But I didn't see any to observer motion. I used the example only to show that we should not take equivalence for grant.
Not any experiments that would convince you, I imagine!
Seriously, there's no point in asking for experimental evidence of SR and then rejecting all evidence provided. You're just wasting our time, really.
Likes Dale
I don’t understand what you mean when you say the Doppler effect should not be taken for granted - are you asking whether the symmetrical Doppler effect for light has been experimentally proven? It has been, many times over.
I don't know why you are irritated. I am here for a sincere technical discussion.
1. There are many experiments proving the invariance of light speed to source.
2. Is there any experiment proving the invariance of light speed to observer? If not, what is the difficulty?
3. The claim that 1 is equivalent with 2 should not be taken for grant, I gave several unrelated examples. If that is true, any experiment proving the equivalence?
  • Skeptical
Likes weirdoguy
Yes. The Michelson-Morley experiment has been re-run many times with more accurate equipment. Same result.
It has already been repeatedly pointed out to you that the principle of relativity, which has also been tested and confirmed by many experiments, is sufficient to show that there is no such thing as "source motion" or "observer motion", only relative motion.
We aren't. We've demonstrated it in many experiments. See above.
You're not behaving like it. You keep repeating the same misconceptions even after they have been repeatedly corrected. For the latest corrections, see my post #21.
Likes Dale
Would an experiment where the observer is not at rest satisfy you?
Yes. That is exactly my question from the begining. Is there any experiment of testing light speed with moving observers?
  • Sad
Likes weirdoguy
If there is such an experiment, it not only proved the light invariance to the observers. It also proved the equivalence. Then we don't need to have any argument.
  • Sad
Likes weirdoguy
That's an evasive answer! A simple "no" would have been more sincere.
It is a postulate, but we choose to use that postulate when we reason about how the real world works for the same reasons that when I choose to use the postulates of Euclidean geometry when I’m laying out plans for a construction project - there is an enormous amount of evidence to show that these postulates are also accurate statements about how things really are.
Likes cianfa72
Yes. The successful operation of the GPS system.
Likes Wrichik Basu, vanhees71, Klystron and 4 others
No. I am not evasive. If there is any doubt about SR, this is the only one. I believe you are very knowledgeable in SR. How about a direct answer? Is there any? If no, what is the reason?
Thank you. Could you please provide a link?
  • Sad
Likes weirdoguy
  • #33
georgechen said:
I meant the explanation of how GPS proves the invariance of light speed to moving observer.
This is like knowing that ##2 + 3 = 5## but asking for a proof that ##3 + 2 = 5##. Nobody is going to bother to write down an explicit proof since it is already a well established fact that addition is commutative. Similarly, nobody is going to bother to write down an explicit explanation of how GPS proves that only relative motion is physically meaningful, since it is already a well established fact that the principle of relativity is true.
In other words, your question has been answered. The fact that you obstinately refuse to accept the answer does not mean the answer is invalid. It's valid.
Thread closed.
Likes Wrichik Basu, vanhees71, berkeman and 2 others
  • #34
Likes vanhees71, PeroK, russ_watters and 1 other person
Related to Light Speed Invariance: Experiments, Difficulties & Clarification
1. What is light speed invariance?
Light speed invariance refers to the principle that the speed of light in a vacuum is constant and does not change regardless of the observer's frame of reference. This principle is a fundamental concept in the theory of relativity.
2. How is light speed invariance measured?
Light speed invariance is measured using experiments such as the Michelson-Morley experiment, which compares the speed of light in perpendicular directions. Other experiments, such as the Kennedy-Thorndike experiment, have also been conducted to test the constancy of the speed of light.
3. What difficulties have scientists encountered in measuring light speed invariance?
One of the main difficulties in measuring light speed invariance is the precision and accuracy required in the experiments. Any small errors or uncertainties in the measurements can greatly affect the results. Additionally, the effects of gravity and other external factors must be carefully accounted for in order to accurately measure the speed of light.
4. Have there been any experiments that have contradicted the principle of light speed invariance?
No, all experiments conducted to date have consistently shown that the speed of light is constant and does not depend on the observer's frame of reference. This has been confirmed by numerous experiments and is a well-established principle in physics.
5. Why is light speed invariance important in physics?
Light speed invariance is important because it is a fundamental principle that has led to the development of the theory of relativity. It has also been confirmed by numerous experiments and is essential in understanding the behavior of light and other fundamental particles in the universe.
