Light - stopped or trapped inside a crystal?
In summary: So, it depends on the specific material used. In summary, the experiment discussed in the conversation involved using an opaque crystal of yttrium silicate doped with praseodymium to stop and store light for a short period of time. This is achieved through a process called electromagnetically induced transparency, where the steep dispersion profile of the crystal allows for the slowing down and storing of light energy in the form of polaritons. The coherence time of the material determines how long the energy can be held before being reconverted back into a photon and emitted from the material.
San K
911
Light -- stopped or trapped inside a crystal?
In the below experiment:
http://www.extremetech.com/extreme/...-inside-a-crystal-the-basis-of-quantum-memory
Opaque crystal of yttrium silicate doped with praseodymium1. Is light stopped or trapped (i.e. internally reflecting, bouncing off the "walls")?
2. Will quantum coherence be preserved as long as the photon stays inside the crystal?
3. Is light "slowed" in water because of absorption and re-emittance of the photon?
I'm bumping this thread in hopes that somebody has an answer regarding this experiment. Thanks!
Likes 1 person
San K,
Read the Wikipedia article on Electromagnetically induced transparency. You will see that the answer to your question 1 is no. The answer to question 2 is yes. As far as question three goes; when light passes from a medium of lower refractive index to a medium of higher refractive index, the group velocity slows down. This is a completely different optical process from EIT.
With regards to your specific question f.wright above me answered it correctly, but I can still expand on these results a bit.
Slowed and stopped light of pulses happens when the dispersion profile contains very steep slopes, as the group velocity of a pulse inside a medium depends on the derivative of the group refractive index with respect to frequency. In addition, one can see that while the pulse is being slowed down by this effect, an increasing part of its energy is actually stored in the material. A kind of pseudoparticle is formed, called a polariton, which is a coupled system of a photon and a material excitation. Stopped light is a special case when all of the energy has been converted into the material. Hope that makes things a bit more clear.
Thanks Zargon, f.wright and coktail.
Good introduction to the term "polariton"
can the converted energy be held (in the material) for upto to, say, an hour and then later re-converted back as a photon? ...that emits out of the material
Yes, in principle it can, it depends on the coherence time of the material. In the quoted paper, the hyperfine levels of Praseodymium is used, which have a max of about 1 minute, which they reach. But there are other rare-earth elements which can be used as well, for example Europium where the theoretical coherence time is several days.
Likes 1 person
FAQ: Light - stopped or trapped inside a crystal?
What is the concept of "stopping" or "trapping" light inside a crystal?
The concept of stopping or trapping light inside a crystal refers to the phenomenon of controlling the direction and speed of light as it travels through a crystal. This can be achieved by manipulating the material properties of the crystal, such as its refractive index, to create a medium that slows down or completely stops the propagation of light.
How is light stopped or trapped inside a crystal?
Light can be stopped or trapped inside a crystal through a process called optical trapping. This involves using lasers to create a highly focused beam of light that can exert forces on microscopic particles, causing them to be trapped in a specific location within the crystal. This technique has applications in areas such as optical tweezers, which can be used to manipulate and study tiny particles at the nanoscale.
What are the potential applications of trapping light inside a crystal?
The ability to control and manipulate light inside a crystal has a wide range of potential applications. One possible use is in the development of advanced optical computing and communication technologies, where the ability to precisely manipulate light can lead to faster and more efficient data processing. This technique also has potential applications in fields such as biomedical imaging and sensing.
Can light be permanently trapped inside a crystal?
No, light cannot be permanently trapped inside a crystal. Eventually, the light will either be absorbed or scattered by the crystal's material. However, by continuously supplying energy to the trapped light, it is possible to maintain its trapped state for extended periods of time.
Are there any challenges or limitations to trapping light inside a crystal?
One of the main challenges in trapping light inside a crystal is finding the right material and conditions to achieve the desired effect. Additionally, the process of trapping light requires precise control and manipulation, which can be technically difficult and expensive. Furthermore, the trapped light can only be maintained for a limited amount of time, making it difficult to use in practical applications. However, ongoing research and advancements in technology continue to address these challenges and expand the potential uses of trapping light inside a crystal.
