Light Transmission Measurements: What Else Can You Find?
In summary, the human thumb can be used to measure the heart rate, and using light transmission measurement, bacteria can be detected in water.
btb4198
572
If you measure the light transmission over time of the human thumb you can get the heart rate.
Is there another thing you can get by using light transmission ? like the Heart rate?
can you find bacteria in water using light transmission ?is light transmission measurement even the right word ?
Science news on Phys.org
  • Pulse Oximetry
  • Smoke Alarm
  • Pulse Oximetry
  • Smoke Alarm
Smoke Alarm use light transmission measurement ?
Google is your friend. Try a search on:
How Do Photoelectric Smoke Detectors Work?​
btb4198 said:
Summary:: usages for light measurement
The most common accurate way to find out what elements are present in astronomical objects is to use Absorption Spectroscopy. For instance, the spectrum of light from a star, passing through the atmosphere of a planet or through a Nebula will have dark bands in it, corresponding to the elements in the gas it has gone through. Helium was discovered in the atmosphere of the Sun by this method, long before its presence was identified on Earth. (Helios is Greek for Sun)
We can't go and visit distant objects so their effect on light can be the only information we have about them.
Your question looks like a homework assignment to me. Use the keywords in all the above answer to search for more information.
I promise you, I have been out of school since 2010. lol No, over the pass two years, I have develop software that can interpret light intensity from different cameras and I just wanted to see what all I can do with this software.
Likes sophiecentaur
Like with a microscope? Yes, although you do have to do the right sample preparation.
I'm not sure it's exactly what you had in mind, but try searching for "spectroscopy" or "flow cytometry"
I would argue that measuring light that has been transmitted through things, reflected off of things, or created by things is the most common and powerful scientific tool in use. The applications are far to numerous to elaborate. Everyone uses it for everything.
Wow, I did not know that. I am new to the optic field. This software was the 1st time I had coded anything with a video camera before. DaveE, did you happen to see my other post? https://www.physicsforums.com/threads/pulse-oximetry-equations.1004269/
Dave can you find knots in a person's back with this ?
What? Muscle spasms? I think there are less expensive ways, like a physical therapist.
Although I would guess you could look at IR radiation to find the heat generated by muscular contraction, if you had to. There have been experiments with using thermography to locate solid cancers, which also make localized heat (from increased blood flow mostly).
Why would that be expensive ? Most people have an iPhone. I would just use that
  • Skeptical
Likes Motore
Go for it.
DaveE said:
Go for it.
so it can be done ? What is the science? Like for the heart rate monitor , Your heart pumps oxygen into your blood, causing your blood cells to become redder and blocking out more light that you can measure. How would finding Knots or muscle spasms work ?
Probably not with a cell phone camera. Those cameras are designed to only see the same colors we can see, so that your vacation photos won't be ruined by UV or IR light. For thermography, you want IR light. Read about "thermography" or "black body radiation" to learn more about measuring heat by looking at the IR light it creates. This is like when a stove top glows "red hot" for example. What you are looking for is hotter parts of the skin due to increased heat generated by the muscles that are working. I'm pretty sure it can be done if you spend enough money and hire good engineers, spending tens or hundreds of thousands of dollars. I not at all sure you can do it. But, it is a good thing to learn more about in any case. You don't have much to lose by trying.
Instead of a cell phone try getting a cheap web cam. Most of these have a filter in front of the sensor that blocks IR light. Take it apart and experiment to see if you can find it and remove it. It may be as subtle as a plastic film or coating on a lens. Then you will have a cheap IR camera, sort of like the night vision cameras the military uses.
DaveE, I have a IR cam from flir that works with my software. However, it only reads IR like from a laser or from a lighter. I have tested this. How could I use it in my case ? lol lighting the human body with fire or a laser is a bad idea ...
Sorry. I have a suspicious mind. You are 'just interested in the World' and that's good.
If you are interested I spectroscopy, you can use a cheap prism from eBay (a 60 degree one) and produce a spectrum of the light from a slit or point. Your camera will give you a set of light level values across the band of colours. The spectrum of sunlight, various filament lamps, CFLs and LEDs will all look different. I am sure your software will allow you to dig out the values from your images. Getting a spectrum and photographing it is not too hard if you use a narrow slit and let the coloured bands fall on a white card. Take your images with the other lights off and you will get better results.
Note: the thinner the slit, the more spectral detail can be seen but the light level drops, of course.
Likes DaveE
FAQ: Light Transmission Measurements: What Else Can You Find?
What is light transmission measurement?
Light transmission measurement is a scientific technique used to quantify the amount of light that passes through a material or substance. It involves using specialized instruments to measure the intensity of light before and after it passes through the material, allowing researchers to determine the percentage of light that is transmitted through it.
Why is light transmission measurement important?
Light transmission measurement is important in many fields of science, including optics, materials science, and environmental science. It can provide valuable information about the properties of materials, such as their transparency, opacity, and color. This information can be used to develop new materials, improve product quality, and understand the behavior of light in different environments.
What types of materials can be measured using light transmission?
Light transmission measurement can be used on a wide range of materials, including liquids, gases, and solids. It is commonly used to measure the transparency of glass, plastic, and other transparent materials, but it can also be used to analyze the properties of opaque materials, such as metals and ceramics.
How is light transmission measured?
Light transmission is typically measured using a spectrophotometer, which is an instrument that can measure the intensity of light at different wavelengths. The material being measured is placed between a light source and a detector, and the amount of light that passes through is recorded. This data is then used to calculate the percentage of light transmission.
What other information can be obtained from light transmission measurements?
In addition to measuring the percentage of light transmission, other information can also be obtained from these measurements. This includes the absorbance and reflectance of the material, as well as its refractive index and color. These parameters can provide insight into the chemical composition and physical properties of the material being measured.
