Light travelling on curved surface
In summary, the conversation discusses the phenomenon of light traveling on a curved surface and how it relates to total internal reflection. The participants also discuss the possibility of it being caused by subtle shaping of the corners of the object in question. They also mention the importance of the angle of incidence in determining if total internal reflection will occur. There is some confusion about the specifics of the situation and how the angle of incidence plays a role.
SataSata
39
Can anybody explain under what conditions does this happens?
Why does the light beam travel on the curved surface? How does this happen? Isn't light suppose to travel in straight line?
Science news on Phys.org
Why do you think the light beam is traveling on the curved surface? If you drilled a tiny hole in the top of the plastic, what would you see?
Likes SataSata
Light travels in a straight line in space. In your picture, the light is being ducted along the curved channel in a series of short straight lines between reflections against the walls. The phenomenon is probably Total Internal Reflection, if it is traveling through a plastic rod.
Likes SataSata
I don't understand what I would see. Can you elaborate?
I'm not sure how there's a curved channel in this. I got the picture from this video:
It happens around 2.55 mins and only for a short window of angle of incidence.
That's a better picture. It was not clear what the original picture was showing. It isn't a curved channel - it's just the inside of the D shape.
Do you know about Total Internal Reflection? You can see many pictures of it happening just once as it strikes the internal surface of glass / water / plastic etc. For it to happen, the angle of incidence must be greater than the Critical angle. In your first picture. the light is being reflected internally many times by the internal curved surface. The picture is too blurry to see that happening but you could draw the effect if you draw a circular arc and draw a line, striking it very obliquely (inside the curve) the ray will be reflected and hit the circle again and again (following the i = r rule at each contact) If the ray hits the curve too steeply, it will just escape and if it enters the D too shallow, it will not make it to the curved surface.
Likes SataSata
I still don't understand how total internal reflection on the curve could have happen at that angle. Look at my attached drawings. I can understand total internal reflection happening for the left drawing. But in the video, the beam came in from a different side which is shown in my drawing on the right. I couldn't come up with any way total internal reflection can happen on the D shape side.
Likes sophiecentaur
I don't think it's total internal reflection. That requires a duct and small angles. To me it just looks like some minor scattering inside a not perfectly clear prism.
Likes SataSata
It is possible to launch a ray that will pass along the circular block as long as the angle is right. (As a series of cords to the curve). I think there must be a curved section at the transition between flat and semicircular sides (the corner`) that causes light to be refracted at the correct angle. This will be restricted to only a small range of incident angles. It would be easier to explain with a different shaped block - one with a flat side which is almost at right angles to the present flat edge.
If you can launch the ray at the correct angle, you can do it with reflections on just one concave internal surface. You can draw a diagram yourself to show it happening. Imo, the D block has some pretty subtle shaping of the corners that allow it to happen.
Likes SataSata
Yes I think it's possible depending on how the corner of the D block is shaped. It won't work if the corner is a perfect right angle which is unlikely. It probably has a little curvature at the corner.
Isn't "the correct angle" small? The angle just in from the corner is almost 90 degrees!
Yes, that would produce the effect but the incidence would have to be almost normal to the flat side. The picture in the OP shows the light coming in, apparently nearly parallel to the flat side. It's a bit confusing.
FAQ: Light travelling on curved surface
1. How does light travel on a curved surface?
Light travels on a curved surface in a straight path, but its path appears curved to an outside observer due to the curvature of the surface. This is known as the principle of least time, where light takes the shortest path possible between two points.
2. What is the difference between light travelling on a flat surface and a curved surface?
On a flat surface, light travels in a straight line, while on a curved surface, its path appears curved due to the curvature of the surface. This difference is due to the principle of least time, where light takes the shortest path possible between two points.
3. What causes light to travel on a curved surface?
The curvature of the surface causes light to travel on a curved path. This is due to the principle of least time, where light takes the shortest path possible between two points. The curvature of the surface determines the path of the light.
4. Can light travel on any curved surface?
Yes, light can travel on any curved surface as long as there is a difference in the index of refraction between the two media. This can be observed in phenomena such as mirages and light bending around objects.
5. How does the curvature of a surface affect the path of light?
The curvature of a surface determines the path of light. Light will always travel in a straight line, but its path will appear curved due to the curvature of the surface. The greater the curvature, the more the path of light will deviate from a straight line.
