Light versus sound waves : velocity
In summary: Water is denser than air......So why speed of sound in Helium is higher than in air? Density of Helium is much lower than of air......Now the speed of sound is a bit more complicated than that, there is a correction factor involving the adiabatic constant of the gas in question. But the velocity needed for one collision is a good starting point to understanding why the velocity of sound is higher in helium.
gkangelexa
81
I noticed that in water, sound travels faster than in air, but when light hits water, its velocity decreases.
Is this because sound is a longitudinal wave and light is a transverse (electromagnetic) wave??
Science news on Phys.org
No. It has nothing to it.
Why do you think so?
what do you mean it has nothing to it :-(?
That there is no causal dependence in (any direction) between longitudinal/transversal character of the waves and direction of the change of wave speed between air and water.
I am just curious: why did you think they should be related?
Wave propagation speed is related to structure of the medium and wave frequency. Each medium responds differently to different frequency ranges. Sound travels faster in water because it is transferred by sonic vibrations through medium content. Water is denser than air thus it will be more efficient for transmission of sound waves. Another reason to this is that low frequency signals have more penetration depth than than high frequency signals.
When light enters water medium, water molecules should align to such a polarization that light will be able to penetrate through. Depending on the molecular structure there will be an extra delay for wave to propagate which is originating from the lag to set medium to a polarization state. Integrate this lag through the transmission path and you'll see that the measured amount of distance is traveled less than velocity 'c'. Relative phase velocity of light can be extracted from refractive index information which can be calculated from Fresnel Equations.
Would it be different, if they had to align longitudinally rather than lateraly?
Really? So why speed of sound in Helium is higher than in air? Density of Helium is much lower than of air.
The speed of sound in air is directly related to the speed of the air molecules. I hope you have heard of the Ideal Gas Law. It is PV = nRT where P is the pressure of the gas, V is the volume, n is the number of moles or the amount of gas, R is the gas constant and T is the temperature in absolute degrees.
If you notice the mass of the gas in question does not enter the equation. Since pressure is a result of elastic collisions between the air molecules and the container that implies that the lighter a gas is the faster the molecules are moving. Helium atoms are very light, they have roughly one seventh of the mass of the average air molecule. To transfer the same energy in a collision they have to be moving 2.7 times as fast as an average air molecule. Now the speed of sound is a bit more complicated than that, there is a correction factor involving the adiabatic constant of the gas in question. But the velocity needed for one collision is a good starting point to understanding why the velocity of sound is higher in helium.
For an article that gives you the actual formulas for the speed of sound in a gas you can go here:http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe3.html"
There is no linear bridge between wave propagation characteristics of different phases of a medium. From penetration depth approach density can be taken as reference for comparison. As stated by others comparison between same phases of different mediums (gas to gas) can be done and molecular mass is at the denominator of the expression. Fresnel equations can be applied between any medium at any phase.
So your arguments, which you gave to OP question (you must see he has pretty poor background and really easily gets confused by unclear argumentation) were wrong and misleading.
Again:
...Sound travels faster in water because it is transferred by sonic vibrations through medium content. Water is denser than air...
You gave higher density of water than air as an explanation of higher sound velocity.
When light enters water medium, water molecules should align to such a polarization...
You gave this argument in the context, where OP suspects if longitudinal/transversal nature of the wave affects wave speed. I just (rethorically) asked if you may defend this argument, as it applies equally to longitudinal and transversal waves (despite there is longitudinal light...).
xts said:
So your arguments, which you gave to OP question (you must see he has pretty poor background and really easily got confused by unclear argumentation) were wrong and misleading.
It might be misleading but this doesn't give you the right to say 'were wrong'. Density is a factor in penetration depth, thus affects the wave speed on medium, period. Polarization density is related to wave speed in medium through constitutive relations. Since air is composed of different materials with different ratios it is not meaningful to compare different phases of these mediums refractive indexes. Light will move faster in any gas than any liquid. It is a pedological analogy to a person at this level of interest.
Light can have any polarization type and it will affect it's speed in the medium. But this is just one of the reasons why sound travels faster than in air and light's velocity decreases when it enters from air to water. One of the contributing phenomenas.
No, that has nothing to do with it. Water and air are the media of sound vibration while they are mere obstacles for light propagation. Without atoms there is no sound propagation while light propagation proceeds unhindered.
It may be that there is a kind of relationship, in the sense that perhaps a more dense medium usually has a higher speed of sound while it reduces more the speed of light (I did not check this).
Harald
Related to Light versus sound waves : velocity
What is the difference between light and sound waves?
Light and sound waves are both forms of energy that travel through a medium. However, light waves are electromagnetic in nature and do not require a medium to travel through, whereas sound waves are mechanical and need a medium, such as air or water, to travel through.
Which type of wave travels faster: light or sound?
Light waves travel much faster than sound waves. The speed of light in a vacuum is approximately 300,000,000 meters per second, while the speed of sound in air is around 343 meters per second.
Why do light waves travel faster than sound waves?
The speed of a wave is determined by the properties of the medium it travels through. Since light waves do not require a medium, they are able to travel at much higher speeds compared to sound waves, which are limited by the properties of the medium they travel through.
How is the velocity of light and sound waves measured?
The velocity of light and sound waves can be measured using different methods. Light waves can be measured using devices such as lasers and mirrors, while sound waves can be measured using devices like microphones and oscilloscopes.
Can the velocity of light or sound waves be changed?
The velocity of light is constant and cannot be changed, as it is a fundamental constant of the universe. However, the velocity of sound waves can be altered by changing the properties of the medium they travel through, such as temperature or density.
  • Optics
