Lighter equals faster acceleration
  • Thread starter Mohd Abdullah
  • Tags
    Acceleration
In summary, motorcycles have less horsepower than cars because they lack the aerodynamic down-force and tire traction of top fuel dragsters. A 300 pound mini car with the same horsepower as a top fuel dragster would not be able to beat it in a quarter mile drag race due to the limitations of tire friction and weight. Additionally, there is a weight restriction for top fuel dragsters, which may explain why they are not as lightweight as some may expect.
Mohd Abdullah
99
Why did motorcycles always have less horsepower than cars? If a lightweight, say, a 300 pound dragbike or car have 7000 horsepower which is the same as Top Fuel dragsters, it could easily be the fastest accelerating machine on Earth thanks to its very light curb weight. Maybe it can do 3-4 seconds in quarter mile straight drag race. Thoughts?
Science news on Phys.org
If you could get 7000 HP from a small engine motorcycle, that would be impressive. One disadvantage of motorcycles is that they do not have the aerodynamic down-force at high speeds that a top fuel dragster does. The dragster tire traction is higher at the high speeds, but that is not true for motorcycles. Both can easily lay rubber at the beginning, which limits the acceleration they can do, but the dragster can get more traction and accelerate more at high speeds. So a motorcycle will never get the times that a top fuel dragster can (unless you put an upside-down wing on it).
A jet-exhaust-powered vehicle would be different because it is not counting on tire friction for its acceleration.
I see. But how about, say, a 300 pound mini car? If this small car with very light curb weight have the same horsepower like the Top Fuel dragster, can it or will it acquire the same elapsed time in quarter mile drag race like the Top Fuel dragster always does? Other people said that 300 pound car will simply fly away over the drag strip because of its very light weight but I'm not sure about it. Thoughts?
That would give you a lot of flexibility for putting down-force wings on it. Remember that F=MA, so as long as a larger engine gives more force/pound, it will be better. Also, there is a lot of weight even before the engine is added, so comparing two engines with the same force/pound would give an advantage to the heavier engine. (The vehicle with the heavier engine would have a smaller percentage of non-engine weight. As an extreme example, a 1 oz, 50 HP engine has a great engine HP/weight number, but would not even move the driver very fast. ) I am not sure if top fuel dragsters have weight restrictions in the rules. If not, you will probably find that every single pound more than pays for itself and that their weight is at the optimum.
Remember that the maximum force you can "push" the car with is limited to the friction between the tires and the surface. Since the friction depends on the weight of the car, a light car will probably spin - at least until the rubber in the tires has melted enough to increase the friction coefficient.
If you try accelerating too fast on a motorbike, the bike will probably flip over backwards ("backwards somersault"). This is due to the torque from the motor and the light weight of the front wheel (draw a diagram and you will see it).
Likes Mohd Abdullah
There is a weight restriction on Top Fuel. Top Fuel dragsters at least must weigh 2320 pounds.
So if I understand you correctly, even a 300 pound mini car that have the same horsepower like the Top Fuel dragster, can't beat the Top Fuel dragster in a quarter mile drag race. Right?
So, the Top Fuel dragster, despite weigh at 2320 pound, still beat the 300 hundred pound mini car with 7000 horsepower (which is just the same like the horsepower of Top Fuel dragster) in a quarter mile drag race?
I do not know. What is the friction coefficient between the tires and the ground?
No, that is not what I meant to say. Sorry for the confusion. All else being equal, the lighter car will accelerate faster. What I meant is that greater weight of the engine that gives it greater horsepower may make it faster. The "dead" weight of the frame, suspension, etc. does not add horsepower. So the less % of "dead" weight, the faster. Of course, there is a reason for the frame, suspension, etc.
Just considering F=MA: If two dragsters have the same amount of "dead" weight and their engines have the same horsepower per pound of engine, then the heavier engine dragster will be faster. The heavier dragster will have the higher horsepower per vehicle pound.
Thought experiment: Assume that the track is slippery ice. Which car will move at all?
Top Fuel dragster uses Chrysler 426 Hemi "Elephant Engine" which is very heavy around 700-800 pounds. So, assuming if someone want to make the 300 pound mini car faster by installing that kind of engine, that mini car would weigh around 800-900 pound with the weight of the engine included.
But if you are going to see the records of the Top Fuel, Top Fuel drag bike which is lighter than Top Fuel dragster, still can't beat Top Fuel dragster in a 300 m drag race. The Top Fuel drag bike weigh at around 1000 pounds and making around 1000 horsepower while the Top Fuel dragster weigh around 2300 pound but makes 7000 hoesepower.
I guess the lighter one? Because the lighter car will give less friction.
With no friction, none of them will move. Less friction means less force to move the car forward.
To quote "Top Gear": Thousands of horsepower does not help if you cannot transfer the torque to the track!
Related to Lighter equals faster acceleration
What is the concept behind "Lighter equals faster acceleration"?
The concept is based on Newton's Second Law of Motion, which states that the force applied to an object is directly proportional to its mass and acceleration. This means that a lighter object will require less force to accelerate compared to a heavier object.
How does the weight of an object affect its acceleration?
The weight of an object is directly related to its mass. The greater the mass, the more force is needed to accelerate the object. Therefore, a lighter object will require less force to achieve the same acceleration as a heavier object, making it accelerate faster.
Does this mean that a lighter object will always have faster acceleration?
No, there are other factors that can affect acceleration such as the force applied, the surface friction, and air resistance. However, in general, a lighter object will have a faster acceleration than a heavier object under the same conditions.
Can this concept be applied to all types of objects?
Yes, the concept of "lighter equals faster acceleration" can be applied to all objects regardless of their size or shape. As long as the mass of the object is reduced, the acceleration will increase.
Are there any limitations to this concept?
Yes, this concept is limited by the laws of physics. Eventually, as an object becomes too light, other factors such as air resistance and friction will become more significant and may limit its acceleration. Additionally, the strength and capabilities of the object's engine or motor will also play a role in its acceleration.
  • Other Physics Topics
  • Mechanical Engineering
11K
36K
  • General Engineering
10K
