Lights dim when refrigerator is on
In summary, the conversation discusses the difference between the electrical load of starting up a motor versus maintaining a constant heavy current through a resistance, as well as the concept of a motor acting as both a motor and a generator at the same time. It also questions whether a generator produces electrical forces that oppose the applied kinetic or turning forces.
gillgill
128
1. In older houses, when a refrigerator starts up, the lights may dim briefly. When an electric heater is turned on, the lights may stay dimmed as long as it is on. Explain the difference.
2. Explain what is meant by the statement "a motor acts as a motor and generator at the same time." Can the same be said for a generator?
thanks
This question relates to the electrical load in a) starting up a motor compared to b) maintaining a constant heavy current through a resistance. It seems to be asking: why does the motor in the fridge draw more power when starting up and much less power afterward?
A generator transfers kinetic energy into electrical energy by 'induction'. Does the motor, which turns electrical energy into kinetic energy by 'induction', also transfer some of that kinetic energy back into electrical energy? How? I think that is what the question asks.
As for the second part, does a generator produce electrical forces that try to stop or reduce the applied kinetic or turning forces?
AM
ok...can u explain why?
FAQ: Lights dim when refrigerator is on
1. Why do the lights dim when the refrigerator is on?
This is a common question because people notice a change in their lights when the refrigerator turns on. The answer is that when the refrigerator's compressor turns on, it draws a large amount of electricity which causes a temporary drop in voltage, resulting in the lights dimming.
2. Is it normal for the lights to dim when the refrigerator is on?
Yes, it is normal for the lights to dim when the refrigerator is on. As mentioned before, this is due to the compressor drawing a large amount of electricity, causing a temporary drop in voltage. As long as the lights return to their normal brightness after a few seconds, there is no cause for concern.
3. Can the lights dimming when the refrigerator is on cause any damage?
No, the temporary dimming of lights when the refrigerator is on does not cause any damage. The decrease in voltage is not significant enough to cause harm to other appliances or electronics in the house.
4. Can I prevent the lights from dimming when the refrigerator is on?
Yes, you can prevent the lights from dimming by installing a voltage stabilizer or surge protector. These devices regulate the flow of electricity to prevent large fluctuations in voltage and protect your appliances from damage.
5. Should I be concerned if the lights stay dim while the refrigerator is on?
If the lights stay dim while the refrigerator is on, it could be a sign of a larger electrical issue. It is best to consult a professional electrician to inspect your wiring and ensure everything is functioning properly.
13K
