zeromodz
- 246
Like say I have one candela of luminosity. How far away do I have to go until the photons of this light are completely undetectable?
...which is only a matter of waiting long enough.Drakkith said:As long as one photon from the candle hits it, it would detect it.
russ_watters said:...which is only a matter of waiting long enough.
AtomicJoe said:Given it travels as a wave how can it be in so many places at the same time, before it is detected?
Drakkith said:Light travels in "packets of energy" called Photons, the particle of light. The light bulbs you see everywhere emit trillions upon trillions of photons per second. Only when a photon hits the right point in your eye can you see it, even though many many more are actually entering it.
ALL matter AND light has wavelike and particlelike properties. You'd have to look up more about Quantum Physics to learn about it all.
russ_watters said:The double slit experiment is more complicated than that. Light may show similarities to a wave but it is not a wave.
zeromodz said:Like say I have one candela of luminosity. How far away do I have to go until the photons of this light are completely undetectable?
AtomicJoe said:...and a wave moves in all directions at once...
AtomicJoe said:Not sure what your point is, however it does travel like a wave and a wave moves in all directions at once.
I think light is a wave and not a particle at all.
Heck, you can stick with the double-slit experiment. It can be performed by firing one photon at a time at the slits. When most people find out what happens for the first time, it blows their minds!Drakkith said:Like Russ said, that is incorrect. There is overwhelming evidence that light has properties of BOTH waves and particles. Look up the photoelectric effect.
russ_watters said:Heck, you can stick with the double-slit experiment. It can be performed by firing one photon at a time at the slits. When most people find out what happens for the first time, it blows their minds!
russ_watters said:Well sorry, but both of those statements are just plain factually wrong.
Drakkith said:Yes, but that still demonstrates the wavelike properties of the photon. The photoelectric effect is one of the most basic demonstrations of the particle like properties of the photon, as Einstein himself explained!
Definition/Summary
When a metal surface is irradiated, it ejects electrons whose kinetic energy can be measured. This electron emission only happens when the irradiating light is above a certain angular frequency . This frequency threshold is found to be independent of the intensity of the radiation. The kinetic energy of the electrons is found to be linearly related to the frequency of light after the threshold, with
1. Light has some similarities to waves, but, also behaves in distinctly unwavelike ways.AtomicJoe said:s1) Not sure what your point is, however it does travel like a wave and a wave moves in all directions at once.
Absolutely not.s2) I think light is a wave and not a particle at all.
Yes, you are certainly entitled to be wrong if you want, but given a choice, I'd think you'd want to be right! That's why most people come here, after all - to learn what is right.As for s2, well I am entitled to be wrong in my thinking I guess, but I find it easier to think of a particle as a special type of wave rather than accept a particle went through two slits at the same time. So if I was forced to choose I go for a wave.
The answer to how light travels is, in fact, "something else" besides a (classical) particle and a wave. Light travels in photons, which have properties like waves and particles, but are not either. They are "something else".Maybe the answer is that is is 'something else'.
Particles do have frequencies, but that's besides the point. The point is that a single photon knocks-loose a single electron, demonstrating clearly that light is quantized (travels in discrete packets).After-all, particles do not have frequencies!
AtomicJoe said:The statements.
For s1 the double slit experiment shows it travels as wave does it not?
As for s2, well I am entitled to be wrong in my thinking I guess, but I find it easier to think of a particle as a special type of wave rather than accept a particle went through two slits at the same time. So if I was forced to choose I go for a wave. Maybe the answer is that is is 'something else'.
FtlIsAwesome said:Didn't the double slit experiment show that light must behave as both a particle and a wave for it to make the observed interference pattern? Like it behaves as one of them when it passes through one slit, then it behaves as the other when it passes through the other slit.
Yes - the photons might individually land anywhere, but as you watch large numbers over time, you find they follow the probability distribution of the interference pattern.FtlIsAwesome said:The culiminative effect of photons over time contribute to the pattern observed.
russ_watters said:. Particles do have frequencies, but that's besides the point. The point is that a single photon knocks-loose a single electron, demonstrating clearly that light is quantized (travels in discrete packets).
Dr Lots-o'watts said:The shorter the wavelength, the more it behaves as a particle.
Dim UV can knock off electrons from metals, but blinding red light carrying the same energy or more cannot.
If it were a totally classical wave, it wouldn't matter whether the energy was carried as frequency or amplitude. The fact that it does matter, suggests a particle nature.
Then we get to the point that a single electron is released, well I can say the wave had enough energy to release a particle can't I?
AtomicJoe said:I don't see that, turning up the light just means more waves are emitted per second, so to me it proves nothing.
Drakkith said:It proves that each "wave" is a distinct entity in itself that must be emitted and absorbed as a whole and has a set amount of energy. In a classic wave, this is not the case.
Dr Lots-o'watts said:No matter how you phrase it, turning up the light won't knock off electrons. Only shortening the wavelength will.
How would YOU (atomicjoe) explain that experimental fact?
If light were really purely a wave, it would be possible to cut down the intensity by any amount, including an amount where it wouldn't be enough to cut loose an electron.AtomicJoe said:Then we get to the point that a single electron is released, well I can say the wave had enough energy to release a particle can't I?
Well, one exists, one doesn't: there is no such thing as a "quantized wave".I see little difference between a quantised particle and a quantised wave, so it does not necessarily suggest particle behaviour to me, could be either.
Except that you're now saying that there is a minimum amplitude to a wave. That doesn't jive with how waves work.I mean there are two ways of looking at it for the energy from light, you can say the wave has a bigger amplitude, or that more waves of a smaller amplitude are emitted per second.
