Lightspeed: does the definition of time make it constant?
In summary, the conversation discusses the synchronization of clocks in different points of space and how it is necessary for establishing a common "time". This concept is important in Einstein's theory of special relativity, which also defines the speed of light to be isotropic. The definition of a second and meter have also been refined over time to increase precision in measuring the speed of light. However, the same clock synchronization method used for light can also be applied to other particles, making their velocities isotropic as well. This shows that the constancy of the speed of light is not the only factor in adopting Einstein's clock synchronization method.
JUboy
If at the point A of space there is a clock, an observer at A can determine the time values of events in the immediate proximity of A by finding the positions of the hands which are simultaneous with these events. If there is at the point B of space another clock in all respects resembling the one at A, it is possible for an observer at B to determine the time values of events in the immediate neighbourhood of B. But it is not possible without further assumption to compare, in respect of time, an event at A with an event at B. We have so far defined only an ``A time'' and a ``B time.'' We have not defined a common ``time'' for A and B, for the latter cannot be defined at all unless we establish by definition that the ``time'' required by light to travel from A to B equals the ``time'' it requires to travel from B to A. Let a ray of light start at the ``A time'' from A towards B, let it at the ``B time'' be reflected at B in the direction of A, and arrive again at A at the ``A time'' .
In accordance with definition the two clocks synchronize if
T(b)-T(a) = T'(a) -T(b)
this is from electrodynamics of moving bodies einstein's original SR paper.tell me when we defined a common time for A and B didnt we define lightspeed to be constant
Yes, in the early 1980s the meter was re-defined as the distance that light travels in 1/299792458 second, so the speed of light is now exactly 299792458 m/sec.
Before that happened, physicists had spent several decades measuring the speed of light with greater and greater precision. Eventually the biggest remaining uncertainty was in the old definition of the meter (the distance between two marks on a platinum-iridium bar in a basement somewhere in Paris). The definition of a second (based on the oscillation of an atomic transition) was more precise.
So we can still do experiments like the old "speed of light" experiments, except that now, instead of measuring the speed of light more and more precisely, they make the definition of the meter more and more precise.
Not quite. This section defines lightspeed to be isotropic (the same in all directions), not necessarily constant.
A point that can and should be made is that this same defintion of clock synchronization that makes the velocity of light isotropic makes the velocities of other particles isotropic if their energy or momentum specified . For example, the same clock synch method makes the speed of 1 Gev electrons isotropic as well as the speed of light - not surprising, really, since 1 Gev electons travel at essentially lightspeed (this may not have been known experimentally in Einstein's time but is well known nowdays).
The same clock synch defintion makes the velocity of electrons of other energies isotropic as well, even low energy ones. And it's not limited to electrons, any particle of a known mass and specified energy will have an isotropic velocity only when clocks are synchornized in the same manner that makes light isotropic.
In addition, momentum could also be specified as well as energy.
Thus the constancy of the speed of light is not the only reason for adopting Einstein's clock synchronization method.
U da man,pervect!i had misunderstood the thing pretty badly i see now. thanks.
Related to Lightspeed: does the definition of time make it constant?
What is lightspeed?
Lightspeed, also known as the speed of light, is the fastest speed at which energy can travel in a vacuum. It is a fundamental constant in the universe and is denoted by the letter c. In a vacuum, light travels at a speed of approximately 299,792,458 meters per second.
Why is lightspeed important in understanding the concept of time?
Lightspeed is important because it is used to define the fundamental unit of time known as a second. The speed of light is constant, meaning it does not change, making it a reliable tool for measuring time. Additionally, the theory of relativity, which explains the relationship between space and time, relies on the speed of light to make accurate predictions.
What is the connection between lightspeed and the constancy of time?
The speed of light is directly related to the constancy of time. According to the theory of relativity, time slows down as an object approaches the speed of light. This means that as an object moves faster, time appears to pass slower for that object. However, this does not change the fact that the speed of light remains constant, making it a reliable measure of time.
Does the constancy of time mean that time is absolute?
No, the constancy of time does not mean that time is absolute. The theory of relativity states that time is relative and can be affected by factors such as speed and gravity. While the speed of light remains constant, time can appear to pass at different rates for different observers based on their relative motion and gravitational fields.
What implications does the constancy of time have on space travel?
The constancy of time has significant implications for space travel. As an object approaches the speed of light, time slows down, making it difficult for astronauts to accurately measure time and coordinate with Earth. Additionally, as an object moves closer to a massive object, such as a planet, time can also slow down due to the gravitational pull. This must be taken into account when planning space missions and communicating with spacecraft.
