Lim_{x to infty} x^r / e^x = 0, where r is real
  • Thread starter fmam3
  • Tags
    E^x
In summary: The gamma function is defined as the extension of the factorial function to all real numbers greater than 0. Therefore, it allows us to evaluate factorials for values that are not integers. In this case, we can use it to evaluate the factorial of a non-integer value of r, which allows us to apply L'Hospital's Rule and ultimately show that the limit is equal to 0. Without the use of the gamma function, it would be much more difficult to evaluate the limit for non-integer values of r.
fmam3
82
Let [tex]r \in \mathbb{R}[/tex]. Show that [tex]\lim_{x \to +\infty} x^r / e^x = 0[/tex]
Intuitively, this is clear since exponential growth (i.e. denominator) is greater than linear growth (i.e. numerator).
If [tex]r \in \mathbb{N}[/tex] then it is easy. We just apply L'Hospital's Rule [tex]r[/tex] times and then we get that [tex]\lim_{x \to +\infty} x^r / \mathrm{e}^x = \lim_{x \to +\infty} rx^{r - 1} / \mathrm{e}^x =\ldots = \lim_{x \to +\infty} r! \cdot 1 / \mathrm{e}^x = 0 [/tex] since [tex]\lim_{x \to +\infty} \mathrm{e}^x = +\infty[/tex].
However, the issue that I have is when [tex]r \in \mathbb{R}[/tex]. The key step when [tex]r \in \mathbb{N}[/tex] was that I could keep taking derivatives until the [tex]x[/tex] term on the numerator becomes 1, and then all we're left is some constant on the numerator and something going to infinity on the denominator and hence the whole term tends to zero. This will clearly not work for when [tex]r \in \mathbb{R}[/tex]; i.e. if [tex]x^\sqrt{2}[/tex], then even if I take [tex]k \in \mathbb{N}[/tex] derivatives, I get something like [tex]\sqrt{2} (\sqrt{2} - 1) \ldots (\sqrt{2} - k) \cdot x^{\sqrt{2} - k}[/tex] and so the x term doesn't become 1, since [tex]\sqrt{2} \in \mathbb{R} / \mathbb{Q}[/tex] and [tex]k \in \mathbb{N}[/tex], it follows that [tex]\sqrt{2} - k \ne 0[/tex].
My attempt is the following but progress is limited. We write, [tex]x^r =\mathrm{e}^{r \ln x}[/tex], then it follows that [tex]x^r / e^x = \mathrm{e}^{r \ln x} / \mathrm{e}^x = \mathrm{e}^{r \ln x - x }[/tex]. Now, using the fact that [tex]\mathrm{e}^x[/tex] is continuous on [tex]\mathbb{R}[/tex], if we can show that [tex]\lim_{x \to +\infty} (r \ln x - x) = -\infty[/tex] then we are done.
To do this, we have to use an indeterminate form [tex]0 / 0 [/tex] or [tex]\infty / \infty[/tex] in preparation for L'Hospital's Rule. Note that if [tex]x = 0[/tex] then the result is trivially true, so WLOG, we can assume [tex]x \in \mathbb{R} - \{0\}[/tex]. Hence, we can write [tex]r \ln x - x = \frac{ \frac{r}{x} \ln x - 1} {\frac{1}{x}}[/tex]. Now, it is clear that on the denominator, [tex]\lim_{x \to +\infty} 1 / x = 0[/tex]. It remains to check check the hypothesis of L'Hospital's Rule and so we need to check that [tex]\lim_{x \to +\infty} (\frac{r}{x} \ln x - 1) = 0[/tex] holds... this is exactly where I'm stuck.
Note that since by L'Hospital's Rule, [tex]\lim_{x \to +\infty} \frac{r}{x} \ln x = \lim_{x \to +\infty} r \cdot \frac{1 / x}{1} = r \cdot 0 = 0[/tex]. And it follows that [tex]\lim_{x \to +\infty} (\frac{r}{x} \ln x - 1) = 0 - 1 = -1[/tex]. Thus, we have an indeterminate form [tex]-1 / 0[/tex] and hence, this fails the hypothesis of L'Hospital's Rule! And note that I'm very hesitant to conclude that [tex]-1 / 0 \approx -\infty[/tex] since I know this is not true...
Any help is appreciated!
Why not just apply l'hopital's rule from the start?
If we assume r to be a positive integer:
[tex]\lim_{x\to\infty} \frac{x^{r}}{e^{x}}=\lim_{x\to\infty} \frac{rx^{r-1}}{e^{x}}=\lim_{x\to\infty} \frac{r(r-1)x^{r-2}}{e^{x}}=\lim_{x\to\infty} \frac{r(r-1)(r-2)...(2)(1)x^{0}}{e^{x}}=\lim_{x\to\infty} \frac{r!}{e^{x}}=0[/tex]
To extend this to positive numbers, you can take replace [tex]r!=\Gamma(r+1)[/tex]. If it's negative, then it'll go to zero already.
Thanks for the reply! Actually, as I'd noted, if [tex]r \in \mathbb{N}[/tex] then I already know how to solve it --- in fact, using the same method you used. But my problem is that it is given that [tex]r \in \mathbb{R}[/tex]; again, as I'd noted, if, say, [tex]r = \sqrt{2}[/tex], then no matter how many derivatives you take on [tex]x^\sqrt{2}[/tex], we will never get something like [tex]x^0 = 1[/tex].
Any further help is appreciated!
As already said, replace [tex]r!=\Gamma(r+1)[/tex]. The gamma function is an extension of factorials from integers, and yields a positive real number for values >0.
zcd said:
As already said, replace [tex]r!=\Gamma(r+1)[/tex]. That yields a positive number less than infinity.
Is it possible to solve the problem without using the Gamma function? Since it is not introduced at this point...
Let x=lnt, then [tex]\lim_{t\to\infty} r\frac{\ln(t)}{t}=\lim_{t\to\infty} r\frac{1}{t}=0[/tex]
Thanks for the reply again.
What does "let x = Int" mean?
Define t as a variable which depends on x. The exact relationship is [tex]t=e^{x}[/tex]. Since t and ex are equal, you can substitute it back into the limit.
Actually, on another thought of this --- how does, even with the use of the Gamma function, allow you to show this, when [tex]r \in \mathbb{R}[/tex]. That is, the key part of your argument, when you'd assumed r is a positive integer is that this holds: [tex]\lim_{x\to\infty} \frac{x^{r}}{e^{x}}=\lim_{x\to\infty} \frac{rx^{r-1}}{e^{x}}=\lim_{x\to\infty} \frac{r(r-1)x^{r-2}}{e^{x}}=\lim_{x\to\infty} \frac{r(r-1)(r-2)...(2)(1)x^{0}}{e^{x}}=\lim_{x\to\infty} \frac{r!}{e^{x}}=0[/tex], and the key is that ultimately, you get to a term where [tex]x^0 = 1[/tex].
Again, if [tex]r = \sqrt{2}[/tex], what is the addictive inverse in the natural numbers, say k, such that [tex]\sqrt{2} - k = 0[/tex] for [tex]k \in \mathbb{N}[/tex]?
I admit that I also find it questionable to just plug in the gamma function after I've declared r to be a positive integer, but if r is a positive noninteger then after enough derivatives it will pass zero and go into the negatives. When r is negative the limit will approach 0.
Again, I'm not disputing your argument (in fact, I agree with 120%) that it is true. With r positive or negative integer, it is trivially true.
The tough part of this question is dealing with cases like [tex]r = \sqrt{2}[/tex].
Sorry but I'm actually finding this hard to understand. Yes, if you set [tex]t = e^x[/tex], then as [tex]x \to +\infty[/tex], [tex]t = t(x) = e^x \to +\infty[/tex]. But that does not mean [tex]t \to \infty[/tex] implies [tex]x \to \infty[/tex].
But the way you had applied L'Hospital's Theorem is incorrect. Suppose [tex]t = e^x[/tex], or [tex]x = \ln t[/tex], then we have that
[tex]\lim_{x \to +\infty} x^r / e^x = \lim_{x \to +\infty} r \ln x / e^x = \lim_{x \to +\infty} \frac{r \ln( \ln(t(x)) )}{ t(x)}[/tex]. Then even if you apply L'Hospital's Rule, you need to take derivatives with respect to x, and not t, since t is a function of x...
You do not need to use anything about the gamma function. Simply extend your integer argument using the squeeze theorem.
Thanks! That was the tip I'd needed to push me into the right direction.
The proof is as follows. By the Archimedian Property, for [tex]\forall r \in \mathbb{R}[/tex], [tex]\exists n \in \mathbb{N}[/tex] such that [tex]n \geq r[/tex]. Then consider the limit value [tex]\lim_{x \to +\infty} x^n / e^x[/tex]. This is an indeterminate form [tex]\infty / \infty[/tex] and hence we can apply L'Hospital's Rule. In fact, by applying L'Hospital's Rule n times, we have that [tex]\lim_{x \to +\infty} x^n / e^x = \lim_{x \to +\infty}nx^{n-1} / e^x = \ldots = \lim_{x \to +\infty} n!x^0 / e^x = n! / e^x = 0[/tex]. This implies that [tex]\forall \varepsilon > 0, \exists \alpha > 0[/tex] such that [tex]\forall x > \alpha[/tex], we have [tex]| x^n / e^x - 0 | < \varepsilon [/tex]. Then, it follows that for [tex]x > \max\{ \alpha, 1\}[/tex], we have that [tex]|x|^r \leq |x|^n[/tex], which implies [tex]0 < |x^r / e^x| \leq |x^n / e^x| < \varepsilon[/tex]. Thus, by the Squeeze Theorem (or just evident by the expression above), it follows that [tex]\lim_{x \to +\infty} x^n / e^x = 0[/tex] as desired.
Thanks again!
FAQ: Lim_{x to infty} x^r / e^x = 0, where r is real
What does "Lim_{x to infty} x^r / e^x = 0" mean?
This equation represents the limit as x approaches infinity of the function x raised to the power of r, divided by the exponential function e to the power of x. The result of this limit is equal to 0.
How is this limit evaluated?
To evaluate this limit, we substitute infinity for x in the equation and simplify. This results in 0 divided by a very large number, which equals 0.
What does the variable r represent in this equation?
The variable r represents any real number. This means that the result of the limit will always be 0, regardless of the value of r.
What is the significance of this limit?
This limit is significant because it demonstrates the behavior of the function x^r / e^x as the input value approaches infinity. The function approaches 0, indicating that the exponential function e^x grows much faster than the polynomial function x^r as x gets larger.
Can this limit be applied to other exponential functions?
Yes, this limit can be applied to any exponential function with a variable in the exponent, as long as the variable is raised to a real power. The result will always be 0 as the input value approaches infinity.
