##\lim_{x \to0} \left(\dfrac{1}{\sin^2 x}-\dfrac{1}{x^2}\right)##
The limit as x approaches 0 of the expression (1/sin²x - 1/x²) is evaluated, leading to the conclusion that it equals 1/3. Various methods are discussed, including using L'Hôpital's rule and Taylor series expansion for sin x. The Taylor series approach reveals that the difference between sin x and x behaves like x³/6, confirming the limit's value. Additionally, an alternative formulation using the function f(x) = sin x/x shows that the limit converges to the same result. The discussion emphasizes the importance of proving the limit's finiteness while confirming its value as 1/3.
littlemathquark
Find ##\lim_{x \to0} \left(\dfrac{1}{\sin^2 x}-\dfrac{1}{x^2}\right)##
My solution is:
Let ##\lim_{ x \to 0}\left(\dfrac {1}{\sin^2x}-\dfrac1{x^2}\right)=L##
Let ##x=2y##
##\lim_{ y \to 0}\left(\dfrac {1}{\sin^22y}-\dfrac1{4y^2}\right)=\lim_{ y \to 0}\left(\dfrac1{4\sin^2y\cdot\cos^2y}-\dfrac1{4y^2}\right)=L##
##=\dfrac14\lim_{ y \to 0}\left(\dfrac1{\cos^2{y}}+\dfrac1{\sin^2{y}}-\dfrac1{y^2}\right)=\dfrac14+\dfrac{L}{4}=L##
##L=\dfrac13##
But I think I must show that firstly this limit L is a infinity number but I don't know how. Please help.
You've shown that if the limit is finite, then it is ##1/3##. It looks tricky to prove that the limit is finite.
You could use l'Hopital's rule several times. Although perhaps there is something better than that.
My second solution using L'Hopital rule twice.
##\lim_{x \to0} \left(\dfrac{1}{\sin^2 x}-\dfrac{1}{x^2}\right)=\lim_{x \to0}\dfrac{x(x-\sin x)(x+\sin x)}{x^3\sin^2x}##
##\lim_{x \to0}\left(\dfrac{x}{\sin x}\right)\cdot\lim_{x \to0}\dfrac{x+\sin x}{\sin x}\cdot\lim_{x \to0}\dfrac{1-\cos x}{3x^2}##
##=1.\lim_{x \to0}\dfrac{1+\cos x}{\cos x}\cdot\lim_{x \to0}\dfrac{1-\cos x}{3x^2}=1.2.\lim_{x \to0}\dfrac{\sin x}{6x}=\dfrac 13##
The clue was to look at the Taylor series for ##\sin x##:
$$\sin x = x - \frac{x^3}{6} + \dots$$Hence:$$x - \sin x = \frac{x^3}{6} + \dots$$And:
$$\lim_{x \to 0} \frac{x - \sin x}{x^3} = \frac 1 6$$Which you can confirm formally using L'Hopital.
For sufficiently small x^2,
\begin{split}<br /> \frac{1}{\sin^2 x} - \frac 1{x^2} &amp;= (\sin x)^{-2} - \frac{1}{x^2} \\<br /> &amp;= \frac{1}{x^2} \left(1 - \frac{x^2}{6} + O(x^4)\right)^{-2} - \frac{1}{x^2} \\<br /> &amp;= \frac{1}{x^2} \left( 1 + \frac{x^2}{3} + O(x^4)\right) - \frac{1}{x^2} \\<br /> &amp;= \frac{1}{3} + O(x^2) \end{split}
Likes nuuskur and SammyS
Another method is to set f(x) = (\sin x)/x with f(0) = 1. Then <br /> \frac{1}{\sin^2 x} - \frac{1}{x^2} = \frac{1}{x^2f^2} - \frac1{x^2} = \frac{1}{f^2} \frac{1 - f^2}{x^2} and <br /> f(x) = 1 - \frac{x^2}{6} + \dots \Rightarrow 1 - f^2(x) = \frac{x^2}{3} + \dots
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
