Limit as a function, not a value
In summary, the conversation discusses the possibility of a limit of a range of functions returning a function. The concept of a limit of a sequence of functions is also mentioned, with a clarification that the set of functions in question is indexed by a continuous parameter rather than the integers. Different definitions of "limit" are also mentioned, with the assumption that a set of functions indexed by a continuous parameter can be approximated by a set of functions indexed by the integers.
bsaucer
30
Is it possible for a limit of a range of functions to return a function?
Example: f(z)= limit (as p approaches 0) (xp-1)/p.
Yes. You define ##f_p(x)=f(p,x)=\dfrac{x^p-1}{p}## and ask for ##\lim_{p \to 0}f(p,x)=\log x.##
Just consider the sequence of fuctions ##f_n(x)= x/n ##. Or a Taylor Series.
Assuming the parameter p is real, How do we arrive at the fact that the limit of the functions approaches the function Log x?
With l'Hôspital's rule.
However, your question can only be answered if you first tell what the logarithm is for you and which tools are allowed in such a proof.
Setting [itex]f(p) = x^p[/itex] we have by definition of the derivative [tex]\lim_{p \to 0} \frac{x^p - 1}{p} = \lim_{p \to 0} \frac{f(p) - f(0)}{p} = f'(0)[/tex] whenever the limit exists. There is no need to invoke l'Hopital's rule in such a case; it won't work for the example [tex]
\lim_{x \to 0} \frac{g(x)}{x}[/tex] where [itex]g(x) = x^2 \sin (x^{-1})[/itex] for [itex]x \neq 0[/itex] with [itex]g(0) = 0[/itex], where [itex]g'(0) = 0[/itex] but [itex] \lim_{x \to 0} g'(x)[/itex] does not exist.
I cited what Wikipedia said without checking, my bad. Here is the solution
\begin{align*}
\log x&=\int_1^x \dfrac{dt}{t}=\int_1^x\lim_{p\to 0}\dfrac{dt}{t^{1-p}}=\lim_{p\to 0} \int_1^x \dfrac{dt}{t^{1-p}}=\lim_{p\to 0} \left[\dfrac{t^p}{p}\right]_1^x=\lim_{p\to 0}\left(\dfrac{x^p}{p}-\dfrac{1}{p}\right)=\lim_{p\to 0}\dfrac{x^{p}-1}{p}
\end{align*}
Integral and limit can be exchanged because there exists an integrable majorant to ##f_n=t^{1-(1/n)}.##
\begin{align*}
\lim_{p \rightarrow 0} \dfrac{x^p - 1}{p} = \lim_{p \rightarrow 0} \dfrac{e^{p \log x} - 1}{p} = \log x .
\end{align*}
julian said:
\begin{align*}
\end{align*}
I don't see how the equality follows here.
Just do ##e^{p \log x} = 1 + p \log x + \frac{1}{2!} (p \log x)^2 + \cdots##.
Likes WWGD
... and add an argument why the limits can be exchanged:
\lim_{p\to 0}\lim_{n\to \infty }\sum_{k=0}^n \dfrac{(p\log x)^k}{k!}=\lim_{n\to \infty }\sum_{k=0}^n \lim_{p\to 0}\dfrac{(p\log x)^k}{k!}
\begin{align*}
\end{align*}
I remember that result on exchanging limits named after one of the major names. Was it Lagrange, or Euler? Someone else?
I don't know. My source calls it the theorem of dominated convergence and uses Fatou's lemma to prove it.
Ah, one of the Lebesgue convergence theorems; MCThm or DCT. Maybe I'm thinking of another result
Lebesgue is correct. It applies to any measurable function. I have found a nice PowerPoint presentation that covers most exchangeability results: sums <> limits <> integrals including counterexamples. Unfortunately, the only English part is a quotation at the beginning:
Then I come along and try differentiating under the integral sign, and often it worked. So I got a great reputation for doing integrals, only because my box of tools was different from everybody else’s, and they had tried all their tools on it before giving the problem to me.
(Richard Feynman, 1918–1988, Surely You’re Joking, Mr. Feynman!)
... and the Chrome translation trick doesn't work on pdf.
http://scratchpost.dreamhosters.com/math/HM3-D-2x2.pdf
Likes WWGD
Just as a matter of terminology, a standard topic in mathematical analysis is whether a limit of a sequence of functions is another function. To study that question one must first define what "limit" means in the context of sequences of functions. The approach taken (implicitly) in this thread is to use the definition known as "pointwise convergence". There are other ways to define the limit of a sequence of functions. (See "uniform convergence").
The usual interpretation of a sequence of functions requires that it be a set of functions indexed by the integers. The set of functions of the form ##\frac{x^p -1}{p}## is a set indexed by the continuous parameter ##p##, so your question is technically more general than a question about a sequence of functions. In practical applications, I think most people would assume a set of functions indexed by a continuous parameter can be approximated by a set of functions indexed by the integers and they would pick a definition of "limit" from the list of standard definitions that apply to limits of sequences of functions.
Likes WWGD
FAQ: Limit as a function, not a value
What does it mean for a limit to be a function rather than a value?
A limit as a function refers to the behavior of a function as the input approaches a certain point, rather than the limit being a specific numerical value. It describes how the output of the function behaves as the input gets closer to a particular point from either side, allowing us to analyze continuity and differentiability in a more nuanced way.
How do you find the limit of a function as it approaches a certain point?
To find the limit of a function as it approaches a certain point, you can use various techniques such as direct substitution, factoring, rationalizing, or applying L'Hôpital's rule if the limit results in an indeterminate form. Graphical analysis can also help visualize the behavior of the function near the point of interest.
Can a limit as a function exist even if the function is not defined at that point?
Yes, a limit as a function can exist even if the function is not defined at that point. The limit describes the behavior of the function as it approaches the point from either side, and it is possible for the function to approach a specific value even if it is undefined at that exact location.
What is the difference between one-sided limits and two-sided limits?
One-sided limits refer to the behavior of a function as the input approaches a certain point from one side only: the left side (denoted as the left-hand limit) or the right side (denoted as the right-hand limit). A two-sided limit exists if both one-sided limits are equal as the input approaches the point from both directions.
How do limits as functions apply to calculus concepts like continuity and differentiability?
Limits as functions are foundational to the concepts of continuity and differentiability in calculus. A function is continuous at a point if the limit as the input approaches that point equals the function's value at that point. Differentiability, on the other hand, requires that the limit of the average rate of change approaches a specific value as the interval shrinks to zero, indicating a well-defined tangent at that point.
