MHB Limit Calc: 1-cos(x)/x^2 w/o L'Hôpital's Rule
  • Thread starter Thread starter Yankel
    Calculation Limit
The limit in question, as x approaches 0 for (1-cos(x))/x^2, can be approached without L'Hôpital's rule by using the identity 1 - cos(x) = 2sin^2(x/2). This transforms the limit into (1/2)(sin^2(x/2)/((x/2)^2)), which leads to the fundamental limit of sin(u)/u as u approaches 0, yielding a result of 1. Alternative methods, such as power series, are suggested but may not align with the request to avoid L'Hôpital's rule. The discussion highlights multiple approaches to solving the limit while adhering to the constraints provided.
Yankel
Hello,
I need some assistance with this limit when x->0:
\frac{1-cos(x)}{x^{2}}
I do not wish to use L'Hôpital's rule.
What I tried was to write x^2 as x*x, and to separate it so I can use the known limit of cos(x)/x, however it only brought me to the 0*infinity problem.
Do you not want to use l'Hôpital's rule because the probem given to you wants you to use a different method? That is, must you not use it? Or would you just personally prefer a different way? l'Hôpital's rule solves this problem in two lines.
Not using l'Hôpital's rule is just as fast. Multiply and divide by $1 + \cos x$, yielding
$$\frac{1 - \cos x}{x^2} \cdot \frac{1 + \cos x}{1 + \cos x} = \frac{1- \cos^2 x}{x^2 (1 + \cos x)} = \frac{\sin^2 x}{x^2 (1 + \cos x)}.$$
Can you finish from here? (Smile)
Yankel said:
Hello,
A possibility in this particular case is to use the identity...
$\displaystyle 1 - cos x = 2\ \sin^{2} \frac{x}{2}$ (1)
... and from (1) to derive...
$\displaystyle \frac{1 - \cos x}{x^{2}} = \frac{1}{2}\ \frac{\sin^{2} \frac{x}{2}}{(\frac{x}{2})^{2}}$ (2)
In the right term of (2) there is a 'fundamental limit' and this limit is 1...
Kind regards
$\chi$ $\sigma$
I came late to the party! (d)
All I have to add is that to write the limit with $\displaystyle \LaTeX$, use the following code:
\lim_{x\to0}\frac{1-\cos(x)}{x^2}
to get:
$\displaystyle \lim_{x\to0}\frac{1-\cos(x)}{x^2}$
cosx=1-x^2/2+O(x^4) as x -> 0
Poirot, that is a good idea. However, since he doesn't wish to use l'Hôpital's rule (or perhaps can't, therefore he wishes not to), I'd say that using power series is probably out of context as well. Nevertheless, another clever suggestion! (Clapping)
We already have four possible paths to the solution. (Dance)
