Limit of (3/4)^(n+1) as n approaches infinity
In summary, the limit of (3/4)^(n+1) as n approaches infinity is equal to 0. This can be proven by bringing the limit inside and using the fact that (3/4)^n is a continuous function. It can also be shown through the use of sequences and the understanding that continually multiplying by a small fraction will result in a smaller number.
seal308
Hello,
I was just wondering how to solve this limit: Limit of (3/4)^(n+1) as n approaches infinity
My attempt:
(3/4)^(n+1) = (3^ (n+1) ) / (4 ^ (n+1))
Top goes to infinity and bottom goes to infinity to use l'hopital rule.
lim = ( ln(3) * 1 * 3^(n+1) ) / ( ln(4) * 1 * 4^(n+1) )
But the correct answer is apparently 0.
Not sure if I'm totally wrong or if I'm just halfway there.
Thanks
I don't think this requires l'hopital's rule. We have $\lim_{{n}\to{\infty}}(3/4)^{n+1}=\lim_{{n}\to{\infty}}(3/4)^n$.
Because $(3/4)^n$ is a continuous function, we can bring the limit inside to get $(3/4)^{\infty}=0$.
EDIT:
I suppose you could also do it this way:
$e^{\ln(3/4)^n}=e^{n \ln(3/4)}=e^{-n\ln(4/3)}$
Hence, $\lim_{{n}\to{\infty}}e^{-n\ln(4/3)}=e^{-\infty}=0$
I'm just learnign about sequences right now.
What does making the limit inside mean?
Do you mean something like it becomes lim(3^(n+1) / lim(4^(n+1))
and because the denominator is bigger than the numerator it goes to zero?
For any \(\displaystyle |x|<1,\quad\lim_{n\to\infty}x^n=0\)
This is essentially the intuition behind why the limit goes to zero. For example, if we take a number $c$ such that $|c|<1$, then obviously $\lim_{{n}\to{\infty}}c^{n}=0$. In this case, $c=3/4$.
There is a theorem that states for a composite function $f(g(x)$, that $\lim_{{x}\to{a}}f(g(x)=f(\lim_{{x}\to{a}}g(x))$ if $f$ is continuous at $g(a)$. In this case, we have $\lim_{{n}\to{\infty}}(3/4)^n=(3/4)^{\lim_{{n}\to{\infty}}n}=(3/4)^{\infty}=0$.
Rido12 said:
This is essentially the intuition behind why the limit goes to zero. For example, if we take a number $c$ such that $|c|<1$, then obviously $c^{\infty}=0$. In this case, $c=3/4$.
Wow thanks, that makes so much sense.
Ty everyone.
$c^{\infty}$ is not really defined notation. It's much clearer to write that:
$$\lim_{n \to \infty} c^n = 0$$
Which can be proven for $\lvert c \rvert < 1$ through e.g. sequences and stuff.
I thought that would be an issue, but thought the OP would understand it better if written in a more explicit fashion. Anyway, I have edited it to reflect this.
The OP needs to realize that when multiplying an amount by a small fraction (i.e. with a size less than 1) you get a SMALLER number as a result. So continually multiplying by a small fraction will continually result in a smaller amount.
FAQ: Limit of (3/4)^(n+1) as n approaches infinity
What is the limit of (3/4)^(n+1) as n approaches infinity?
The limit of (3/4)^(n+1) as n approaches infinity is 0. This can be determined by using the limit definition and taking the limit as n goes to infinity.
How do you find the limit of (3/4)^(n+1) as n approaches infinity?
To find the limit of (3/4)^(n+1) as n approaches infinity, you can use the limit definition and take the limit as n goes to infinity. Alternatively, you can use the properties of limits, such as the fact that the limit of a product is the product of the limits, and the limit of a power is the power of the limit.
Is the limit of (3/4)^(n+1) as n approaches infinity equal to 0?
Yes, the limit of (3/4)^(n+1) as n approaches infinity is equal to 0. This can be determined by using the limit definition and taking the limit as n goes to infinity.
Can the limit of (3/4)^(n+1) as n approaches infinity be any other value?
No, the limit of (3/4)^(n+1) as n approaches infinity can only be 0. This is because as n approaches infinity, the value of (3/4)^(n+1) gets closer and closer to 0, but it never actually reaches 0.
How does the value of n affect the limit of (3/4)^(n+1) as n approaches infinity?
The value of n does not affect the limit of (3/4)^(n+1) as n approaches infinity. This is because as n approaches infinity, the value of (3/4)^(n+1) gets closer and closer to 0, regardless of the value of n.
