Limit of (3/4)^(n+1) as n approaches infinity
In summary, the limit of (3/4)^(n+1) as n approaches infinity is 0. This can be seen by writing the expression as e^(n+1)ln(3/4) and noting that the ln is negative, causing the whole expression to approach zero as n goes to infinity. L'Hopital's rule is not necessary.
seal308
Hello,
I was just wondering how to solve this limit: Limit of (3/4)^(n+1) as n approaches infinity
My attempt:
(3/4)^(n+1) = (3^ (n+1) ) / (4 ^ (n+1))
Top goes to infinity and bottom goes to infinity to use l'hopital rule.
lim = ( ln(3) * 1 * 3^(n+1) ) / ( ln(4) * 1 * 4^(n+1) )
But the correct answer is apparently 0.
Not sure if I'm totally wrong or if I'm just halfway there.
Thanks
You are not done here. Both numerator and denominator still go to infinity, and you didn't gain anything.
There are more direct approaches that work.
Am I overthinking this.
Is it as simple as the denominator is larger and gets bigger faster and numerator making the whole thing = 0 for that reason?
Yes.
Something like that, but the "whole thing" never equals zero. It gets arbitrarily close to zero, though.
OK I'll use that logic then. thx
If a is any number in the interval (-1, 1), then ##\lim_{n \to \infty}a^n = 0##.
BTW, please don't delete the three parts of the homework template. They are there for a reason; namely, to help you organize your problem and the work you've done.
Likes seal308
I see thanks again.
if you write (3/4)^(n+1) as ##e^{(n+1)\ln{(\frac{3}{4})}}## maybe it will be easier to see why it goes to zero since the ln is negative & you don't need l'hopital's rule either.
Related to Limit of (3/4)^(n+1) as n approaches infinity
1. What is the limit of (3/4)^(n+1) as n approaches infinity?
The limit of (3/4)^(n+1) as n approaches infinity is 0. This means that as n gets larger and larger, the value of (3/4)^(n+1) gets closer and closer to 0.
2. How do you calculate the limit of (3/4)^(n+1) as n approaches infinity?
To calculate the limit of (3/4)^(n+1) as n approaches infinity, you can use the formula lim(x->inf) f(x) = lim(x->inf) f(x)/g(x) if the limit exists and g(x) is nonzero at x=a. In this case, we can simplify the expression to (3/4)^n, and since 3/4 is less than 1, the limit is 0.
3. Is the limit of (3/4)^(n+1) as n approaches infinity equal to 0?
Yes, the limit of (3/4)^(n+1) as n approaches infinity is equal to 0. This means that as n gets larger and larger, the value of (3/4)^(n+1) gets closer and closer to 0.
4. How does the value of n affect the limit of (3/4)^(n+1) as n approaches infinity?
The value of n does not affect the limit of (3/4)^(n+1) as n approaches infinity. The limit will always be 0, regardless of the value of n.
5. What does it mean when the limit of (3/4)^(n+1) as n approaches infinity is 0?
When the limit of (3/4)^(n+1) as n approaches infinity is 0, it means that as n gets larger and larger, the value of (3/4)^(n+1) will get closer and closer to 0. This can also be interpreted as the function approaching 0 as n approaches infinity.
