Limit of a fraction as n-> infinity in the numerator and denomominator
In summary: Can you not see that?$$\lim_{n \rightarrow \infty} \frac{n}{n+1} = 1$$This is awful. Is this anywhere close to what you meant?
Sparky_
227
Find limit an n-> infinity (n*sqrt(n)) / (n+1)sqrt(n+1))
L'Hopital's rule f'(n) / g'(n)
Hello,This is actually a piece of a little bigger problem (convergence of a series) - you can see the ratio test ak+1 / ak
That's why the (n) and (n+1) terms
I have lim n->∞ of (n√n) / (n+1)√(n+1) ∞/∞
I have tried L'Hopitals rule (requiring multiple times) and I am not seeing an end.
derivative of n^3/2/ (n(n+1)^1/2 + (n+1)^1/2)
lim 3/2 n^1/2 / (1)( n+1)^1/2 + (n)1/2(n+1)^(-1/2) + (1/2 (n+1)^(-1/2) )
form is still ∞/∞
Looking ahead ... it looks as if continuing to apply L'Hopitals rule because of the fractional exponents I will be stuck in a repetitive always getting ∞/∞
The answer (just the answer) was provided to this problem, the series does converge (within a bound) so I know this limit is not ∞/∞
Am I on the right track with L'Hopitals Rule or am I overlooking some simplification to make things easier?
Thanks
Sparky_
Sparky_ said:
Homework Statement:: Find limit an n-> infinity (n*sqrt(n)) / (n+1)sqrt(n+1))
Relevant Equations:: L'Hopital's rule f'(n) / g'(n)
form is still ∞/∞
Thanks
Sparky_
Yes, you are overlooking something simpler. Think about the product of two sequences: ##\frac{n}{n+1}## and ##\sqrt{\frac{n}{n+1}}##.
Why don’t you just rewrite the expression? Divide both numerator and denominator by ##n\sqrt n##.
PeroK - the overall Problem is find the interval of convergence or what values of x ... for x^n / (n sqrt(n) 10^n) I was attempting to use ration test to get to x="10" does this change your reply? Meaning the n and n+1 terms are a result of me implementing the ratio test but I now have to do the limit
OroDruin ...
is this the right direction: lim n-> ∞ n sqrt (n) / (n(sqrt(n+1) + sqrt (n+1))
1 / ( n sqrt(n+1) / n(sqrt(n) + sqrt (n+1) / nsqrt(n) )
= 1 / ( sqrt (n+1) / sqrt (n) + sqrt (n+1) / nsqrt(n))
I see the right most term will go to 0 because of the n term in the denominator
is my next step L'Hoptal's rule?
That doesn't change my answer. You just have to put things together.
Consider the following relation:
\frac{n}{n+1} = \frac{1}{1 + 1/n}
Likes PeroK
I think I am with you ... That's how I got 1 / (sqrt(n+1) / Sqrt (n) + sqrt(n+1) / nsqrt(n))
right?
I have not caught up to you (yet) ... I should be looking toward the product of (n / n+1) and sqrt (n/n+1)
(n / (n+1) ) ^3/2 ??
Root Test?
Lim n-> ∞ x / n^1/n n^1/2n (10) = x/10
(n / (n+1) ) ^3/2??
Can you not see (or prove) that
If you can't see that, how have you progressed to the radius of convergence for power series?
right?
$$\frac 1 {\frac{\sqrt{n+1}}{\sqrt n}} + \frac{\sqrt{n+1}}{n\sqrt n}$$
If you right-click on the expression above, you can see the LaTeX script I wrote. There's also a link to our tutorial in the lower-left corner of the input pane.
L'Hopital's Rule isn't always useful, as you found out. For limits involving radicals, it's often better to manipulate the expression algebraically until you get something you can apply the limit to.
$$\lim_ { n\rightarrow \infty } \frac {n} {n + 1}$$
$$ = \lim_ { n\rightarrow \infty }\frac {\frac {n} {n} } {\frac {n} {n} + \frac{1} {n}}$$
$$ = \frac {1} {1 + 0}$$
I have not practiced (used) limits in about 40 years.
The background to this question is I was asked by a students parent if I could help with her calculus (having to be home and do the remote learning)
I told the parents yes without asking the topic, I am comfortable with derivatives, integrals differential equations and so forth (I do mathematical modeling as part of my job) I knew when they said series was the topic I was in trouble. Same time frame since doing series - just never really used in my graduate work nor work, only really touched both limits and series in my undergrad.
I was able to solve it without much effort once I found the root test I was stuck trying to solve it in a painful manner.
Likes PeroK
ThanksI have reviewed the tutorial and practiced some LaTex this morning (see my reply to PeroK)
Try substituting n/n+1 with some other variable and from that get a new limit for new variable.
Since you have already found an answer:
$$\frac{n\sqrt n}{(n+1)\sqrt{n+1}}=\frac{n}{n+1}\frac{\sqrt n}{\sqrt{n+1}}=\frac{n}{n+1}\sqrt{\frac{n}{n+1}}=\left(\frac{n}{n+1}\right)^\frac{3}{2}$$
$$\frac{n\sqrt n}{(n+1)\sqrt{n+1}}=\frac{n^\frac{3}{2}}{(n+1)^\frac{3}{2}}=\left(\frac{n}{n+1}\right)^\frac{3}{2}$$
$$\frac{n\sqrt n}{(n+1)\sqrt{n+1}}\underset{\infty}{\sim}\frac{n\sqrt n}{n\sqrt{n}}=1$$
##n+1\underset{\infty}{\sim}n## because ##\lim_{n\to\infty}\frac{n}{n+1}=1##.
n/n+1 is ##\frac n n + 1##, probably not what you intended. If you write fractions inline in text, use parentheses when the numerator or denominator contains multiple terms. IOW, for what you wrote -- n/(n+1).
Related to Limit of a fraction as n-> infinity in the numerator and denomominator
1. What does the limit of a fraction as n-> infinity in the numerator and denominator mean?
The limit of a fraction as n-> infinity in the numerator and denominator refers to the value that the fraction approaches as the variable n gets larger and larger. This is also known as the limit at infinity.
2. How do you calculate the limit of a fraction as n-> infinity in the numerator and denominator?
To calculate the limit of a fraction as n-> infinity in the numerator and denominator, you can divide both the numerator and denominator by the highest power of n. This will help simplify the fraction and make it easier to find the limit.
3. Can the limit of a fraction as n-> infinity in the numerator and denominator be infinity?
Yes, the limit of a fraction as n-> infinity in the numerator and denominator can be infinity. This occurs when the numerator grows faster than the denominator as n gets larger, resulting in an unbounded value.
4. What happens if the limit of a fraction as n-> infinity in the numerator and denominator is undefined?
If the limit of a fraction as n-> infinity in the numerator and denominator is undefined, it means that the fraction does not approach a specific value as n gets larger. This can happen when the numerator and denominator grow at the same rate.
5. Are there any special cases when calculating the limit of a fraction as n-> infinity in the numerator and denominator?
Yes, there are a few special cases to consider when calculating the limit of a fraction as n-> infinity in the numerator and denominator. These include when the fraction has a constant term, when the fraction has a polynomial in the denominator, and when the fraction has a radical in the numerator or denominator.
