Limit of a Sequence: Does Square or Sqrt Change It?
  • Thread starter Thread starter Karl Porter
    Limit Sequence
Karl Porter
I was curious, if I have a sequence that has a limit of 1
Lim an=1 as n tends to inf
Lim of an^2=1 as n tends to inf
Does the square of the sequence also have a limit of 1. Does the square root also equal 1? I've been trying to find some counterexamples but I think the limit doesn't change under these operations?
Karl Porter said:
Homework Statement:: I was curious, if I have a sequence that has a limit of 1
Relevant Equations:: Lim an=1 as n tends to inf
Can you think of a basic theorem of limits that would lead to a one line proof?
Hint: If ##\lim_{n \rightarrow \infty} a_n = L_a## and ##\lim_{n \rightarrow \infty} b_n = L_b##, then ...
Likes pbuk and berkeman
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
