Limit of a trigonometric function
In summary, to find the limit as x approaches 0 of f(x) = 3x / sin 5x, we can substitute u = 5x and use the fact that the limit of u/sin(u) as u approaches 0 is equal to 1. Similarly, for the limit of f(x) = 3x^2 / (1 - cos 1/2 x)^2, we can multiply and divide by 1/4 and use the fact that the limit of (1 - cos(u))/u as u approaches 0 is equal to 0.
Jimmy84
191
Find the limit as x approaches 0 of
f(x) = 3x / sin 5x
I might have to use the fact that "the lim of x approaches 0 of sin x/x = 1"
I don't know how to start to solve the expresion, I would appreciate any help.
thanks.
Substitute u=5x. So u also approaches 0. Then use lim u/sin(u)=1 as u->0.
f(x) = 3x / sin 5x
You can rewrite f(x) as
f(x) = 3/5*5x/sin5x and the find the limit.
A good explanation of this problem lies in this https://www.physicsforums.com/showthread.php?t=305154".
I think the best advice is to combine the above two suggestions. Rewrite the limit as
[tex]\lim_{x\to0} \frac{3x}{\sin 5x} = \lim_{x\to0} \frac{3}{5} \frac{5x}{\sin 5x} = \frac{3}{5}\lim_{x\to0} \frac{5x}{\sin 5x}[/tex]
Now let u=5x, and follow the example shown in the posted link.
thanks a lot guys, the explanation you gave in the other post were useful for me, my book didnt explain that way of substitution a lot.
right now I am having a difficult time subtituting this:
1.) f(x) 3x^2 / 1 - cos 1/2 x^2
I think that for this problem I got to use the fact that x - cos x / x = 0
and
2.) g(x) sin x /x^2
at first sight, these problems arent substutited in the same was as you described in the previous post though. Sometimes when I try to substitute terms I get all confused and end up mading up answers for the trigonometric functions, I was wondering if there are certain substitution steps that I could use for most of the trigonometric functions? like the one you described in the previous posts.
take care and thanks a lot.
is this supposed to be
[tex]\lim_{x \rightarrow 0} \frac{3x^2}{1-cos\frac{x^2}{2}}[/tex]
Jimmy84 said:
2.) g(x) sin x /x^2
[tex]\lim_{x \rightarrow 0} \frac{sinx}{x^2} [/tex]
if that is the question then try using the fact that 1/x2 = (1/x)*(1/x)
and
[tex]\lim_{x \rightarrow a} f(x)g(x) = \lim_{x \rightarrow a}f(x) * \lim_{x \rightarrow a} g(x)[/tex]
and
the second problem is right, the first one is 3x^2 / (1-cos 1/2 x)^2
sorry I am having problems with the notation.
Then both multiply and divide the numerator by 1/4 to get
[tex]\frac{12\frac{x^2}{4}}{\left(1- cos \frac{x}{2}\right)^2}= 12\left(\frac{\frac{x}{2}}{1- cos(\frac{x}{2})}\right)^2[/itex]
[tex]\lim_{a\rightarrow 0}\frac{1- cos(u)}{u}= 0[/itex]
But note that your fraction is the reciprocal of that- that's very important here!
FAQ: Limit of a trigonometric function
What is the definition of the limit of a trigonometric function?
The limit of a trigonometric function is the value that a trigonometric function approaches as its input (x-value) approaches a specific value.
How is the limit of a trigonometric function calculated?
The limit of a trigonometric function is calculated by plugging in the specific value that the input is approaching into the function and simplifying.
What is the difference between a one-sided limit and a two-sided limit for a trigonometric function?
A one-sided limit for a trigonometric function only considers the values of the function as the input approaches from one side (either the left or right) of the specific value. A two-sided limit considers the values from both sides of the specific value.
Can a trigonometric function have a limit that does not exist?
Yes, a trigonometric function can have a limit that does not exist if the function oscillates or has a jump at the specific value that the input is approaching.
How do you determine if a trigonometric function has a limit at a specific value?
To determine if a trigonometric function has a limit at a specific value, you can plug in values that approach the specific value from both sides and see if the resulting values approach a single number. If they do, then the limit exists. If not, the limit does not exist.
