Limit of f along an indicated curve?
  • Thread starter SithsNGiggles
  • Tags
    Curve Limit
In summary, the problem is that the author is not understanding how to find a limit and is instead trying to substitute y in for x. He is also trying to use L'Hopital's Rule, but if differentiation does not work then he is considering using the "divide numerator and denominator of the rational function by the highest power of x" approach.
SithsNGiggles
186
I have a problem here with a the syntax of a question.
"Compute the limit of f as (x,y) approaches (0,0) along the indicated curves.
f(x,y) = (x2 - y2)/(x2 + y2)
a) y = x
b) y = x/2
c) y = x2
d) y = 2x
I haven't quite started, I've spent most of my time trying to figure out what the conditions under the question meant and how they would change the process of finding the limit.
If it means anything, I'm expected to use the sequence definition of limits (which I'm capable of doing, I just don't know how to begin).
The idea with specifying functions y = g(x) as approach paths to the origin is that you can substitute for y in f(x,y) to reduce the problem to finding a limit of a function of just one variable...
So I replace y with the corresponding relation in a-d, right? I'm doing this, so I that I now have f(xn,yn) = (xn2 - (xn2)2)/(xn2 + (xn2)2).
(for part c)
Since I now get 0/0, what can I do?
Do you know about L'Hopital's Rule?
Does differentiation work in the same manner with sequences? If they do I'll try that.
You can treat the points xn as discrete points on the curve of a function f(x), but I don't know if they'll fuss at you about not having established this in your course. As an alternative, you can use the "divide numerator and denominator of the rational function by the highest power of x " approach, so you will have a constant leading term "above and below" and the rest are terms which are reciprocals of positive powers of x.
(I take it this is an analysis course and not just multivariate calculus.)
FAQ: Limit of f along an indicated curve?
What is the definition of the limit of f along an indicated curve?
The limit of f along an indicated curve is the value that a function approaches as its input variable approaches a specific point on a given curve. This can be thought of as the y-value of a point on the curve as the x-value approaches a certain value.
How is the limit of f along an indicated curve calculated?
The limit of f along an indicated curve can be calculated by evaluating the function at points on either side of the desired point on the curve. If the values approach the same value, then that value is the limit. If the values approach different values, then the limit does not exist.
What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit only considers the values of the function on one side of the desired point on the curve, while a two-sided limit considers values on both sides. One-sided limits are used when the function is not defined on both sides of the point on the curve.
Can the limit of f along an indicated curve be different from the value of the function at that point?
Yes, the limit of f along an indicated curve can be different from the value of the function at that point. This can occur when there is a discontinuity or a hole in the graph of the function at that point.
What are some real-world applications of limits along an indicated curve?
Limits along an indicated curve are used in various fields such as physics, engineering, and economics. For example, in physics, the limit of a function along a trajectory can be used to determine the velocity or acceleration of an object at a specific point in time. In economics, limits can be used to model the behavior of supply and demand curves.
