Limit problem - [applying L'Hopitals law/rule]
  • Thread starter SirPlus
  • Tags
    Limit
So, while the limit does not exists in the usual sense, it does in the sense of the definition of the limit, which is somehting a lot of students seem to forget in this forum.In summary, the limit of the function ##x^{1/x}## as ##x## tends to zero is zero.
SirPlus
Hi,
Find the limit of the function x^(1/x) as x tends to zero
I had assigned y to x^(1/x) and took the natural logarithm on both sides but that had not given me a quotient in its indetermined form that is 0/0 or infinity / infinity
maybe there is another approach not l'Hopitals rule ..
Thanks,
If y = x^(1/x) and you took the log of y, what did you get?
I got 1/0 ...
L'Hopital can not be used here, use small numbers to see the trend (from the right side of zero that is).
First show that if ##x \in ]0,1[## , then ##x^{1/x} \in ]0,x[##. Then deduce that this implies the limit is zero.
Sure, you can use de L'Hospital's rule for the log of the function
[tex]\ln(x^x)=x \ln x, \quad x>0.[/tex]
The limit for [itex]x \rightarrow 0^+[/itex] is of the type "[itex]0 \cdot \infty[/itex]". This you easily can transform into a limit of the type "[itex]\infty/\infty[/itex]"!
@vanhees: that's not the limit, right?
If you have the limit of [itex]\ln[f(x)][/itex], then you can use [itex]f(x)=\exp\{ \ln[f(x)] \}[/itex] and the continuity of the exponential function to get the original limit!
^ But it's ##x^{1/x}##, not ##x^{x}##. You will get something like "##-\infty / 0##"
Exactly my point.
Argh. I misread this from the beginning. Then of course you have
[tex]\ln[f(x)]=\frac{\ln x}{x},[/tex]
and you don't need de L'Hospital at all. As a real function defined for [itex]x>0[/itex] you can take the limit from above [itex]x \rightarrow 0^+[/itex] (giving [itex]-\infty[/itex]) and then apply the argument with the continuity of the exponential function.
I don't get your argument vahess71 - i understand that as the x values decrease to the right the numerator as function tends to (- infinity) however the dinomenator tends to zero, the limit does not exist at all?
How do you define a limit? Are you familiar with the epsilon-delta definition?
In the case of this problem, you can show that if x is a positive number that is close to zero, then ##x^{1/x}## is even closer to zero and it's obvious that ##x^{1/x} \rightarrow 0## when ##x \rightarrow 0##.
Try giving ##x## the sequence of values ##x=10^{-1},10^{-2},10^{-3},\dots ## and see what are the corresponding values of ##x^{1/x}##.
No, the limit is not obvious, try, like I said earlier, to fill in some small number in ln(x)/x and analyze the trend.
As an answer, would it be easier for me to rather tabulate values of x between zero and one for functions in numerator and denomenator to observe the trend?
perhaps maybe sketch the graph for support - i guess its difficult to find the limit arithmetically
##y = x^{1/x}##
##ln(y) = \frac{ln(x)}{x}##
##lim( ln(y) ) = lim( \frac{ln(x)}{x} )## ( I'm intending the limit to be ##x→0^+## )
##ln(y) = lim( \frac{ln(x)}{x} )##
It is important to note that the two sided limit does not exist in this case because ##ln(x)## is defined only for ##x > 0## in the reals.
Now, observe the nature of the expression as we inch closer and closer to zero from the right. The numerator ##ln(x)## will decrease rapidly towards ##-∞## as we tend to zero. While the denominator ##x## will also decrease, but will tend towards zero.
It is important to note that ##x > ln(x)## for all ##x > 0##. So the denominator tends to zero faster than the numerator tends to ##-∞##. This causes the expression to 'blow up' because you know any quantity divided by something very very small is something very very large.
All this info tells us that ##lim( \frac{ln(x)}{x} ) → -∞## as ##x→0^+##. So we get :
##ln(y) = -∞##
##e^{ln(y)} = e^{-∞}##
##y = 0##
This tells us that ##lim(x^{1/x}) = 0##.
Likes 1 person
We have ##\ln(y) \to - \infty## as ##x \to 0+.## While you are technically correct that the limit does not exist, you need to go back and look at what is actually meant by all this. It means that for any given number ##N > 0## we can find ##\delta > 0## so that ##\ln(y) < -N## if ##0 < x < \delta.## Thus, ##0 < y < e^{-N}## for ##0 < x < \delta##. So, given any ##\epsilon > 0## we can choose ##N > 0## so that ##e^{-N} \leq \epsilon##, and then we an choose ##\delta > 0## so that for ##x \in (0,\delta)## we have ##|y(x)| < \epsilon##. That means that we have ##\lim_{x \to 0+} y(x) =0.##
Related to Limit problem - [applying L'Hopitals law/rule]
1. What is L'Hopital's rule and when is it used?
L'Hopital's rule is a mathematical tool used to evaluate limits of indeterminate forms, where the limit of a function approaches either 0/0 or ∞/∞. It is used when the standard methods of evaluating limits, such as substitution or factoring, do not work.
2. How do you apply L'Hopital's rule to solve limit problems?
To apply L'Hopital's rule, first rewrite the limit as a fraction in the form of 0/0 or ∞/∞. Then, take the derivative of the numerator and denominator separately, and evaluate the limit again. If the resulting limit is still in an indeterminate form, repeat the process until a solution is reached or the limit is determined to be infinite.
3. Is L'Hopital's rule applicable to all types of limit problems?
No, L'Hopital's rule can only be applied to limits that are in the indeterminate forms of 0/0 or ∞/∞. It cannot be used for limits that are already in a determinate form, such as 1/2 or 3.
4. Are there any limitations to using L'Hopital's rule?
Yes, L'Hopital's rule is not applicable to limits that involve trigonometric functions, logarithms, or exponential functions, as well as limits that involve multiple variables. It also cannot be used for limits that go to infinity without being in the indeterminate form of ∞/∞.
5. Can L'Hopital's rule be used to find the limit of a function at a specific point?
No, L'Hopital's rule is used to evaluate limits as x approaches a certain value, not at a specific point. It can only determine the behavior of a function as it approaches a certain point, not the actual value at that point.
