Limit problem with exponents/logarithms
  • MHB
  • Thread starter GreenGoblin
  • Tags
    Limit
In summary, your problem is that you are trying to use a standard result for $\displaystyle y = \ln \left(1 + \frac{3}{x} \right)^{x}$ which doesn't seem to fit the case here.
GreenGoblin
68
Hello,
I am tackling a problem which I have an answer for but I can't complete the work of showing where it's coming from. This is where I have arrived
$\lim \frac{e^{xln(3+x)}}{e^{xlnx}}$ for x goes to infinity. (Also, what's the code for this please? To show the lim with arrow?)
I have that the answer is $e^{3}$ but not how to get there. I've tried a lot of cancelling but not quite got there.
Gracias,
GreenGoblin
GreenGoblin said:
Hello,
Gracias,
GreenGoblin
$\displaystyle\lim_{x\to\infty}\frac{e^{x\ln(3+x)}}{e^{x\ln x}}=\lim_{x\to\infty}\frac{e^{\ln(3+x)^x}}{e^\ln x^x}$
$\displaystyle=\lim_{x\to\infty}\frac{(3+x)^x}{x^x}$
$\displaystyle=\lim_{x\to\infty}\left(1+\frac{3}{x}\right)^x$
$\displaystyle=\lim_{x/3\to\infty}\left[\left(1+\frac{3}{x}\right)^{x/3}\right]^3$
$\displaystyle=e^3$
Hi,
Your third line is actually the start of the problem, I had arrived at what I wrote by rearranging from that. Are you telling me I was moving away from a solution? Now I just don't see at all where $e^{3}$ comes from as a solution from that.
GreenGoblin said:
Hi,
Do you know that $\displaystyle\lim_{x\to\infty}\left(1+\frac{1}{x}\right)^x=e$?
Yes but I don't think such standard results are allowed to be used in this case. This problem comes from a set of exercises on L'Hospital's rule, hence why I looked to get in a fraction form (even if it is not applicable to use this rule here).
$ \displaystyle \lim_{x \to \infty} \left(1 + \frac{3}{x} \right)^{x} $
let $ \displaystyle y = \ln \left(1 + \frac{3}{x} \right)^{x} = x \ln \left(1 + \frac{3}{x} \right) = \frac{\ln \left(1 + \frac{3}{x} \right)}{\frac{1}{x}} $
$\displaystyle \lim_{x \to \infty} y = \lim_{x \to \infty} \frac{\ln \left(1 + \frac{3}{x} \right)}{\frac{1}{x}} = \lim_{x \to \infty} \frac{\frac{1}{1+\frac{3}{x}} \left(\frac{-3}{x^{2}}\right)}{-\frac{1}{x^{2}}} = \lim_{x \to \infty} \frac{3}{1+\frac{3}{x}} =3 $
therefore $\displaystyle \lim_{x \to \infty} \left(1 + \frac{3}{x} \right)^{x}= \lim_{x \to \infty} e^{y} = e^{\lim x \to \infty y} = e^{3}$
FAQ: Limit problem with exponents/logarithms
What is a limit problem with exponents?
A limit problem with exponents involves finding the value that a function approaches as the input (usually denoted as x) gets closer and closer to a specific value. This value can be a constant, such as a number, or a variable, such as infinity.
How do I solve a limit problem with exponents?
To solve a limit problem with exponents, you can use algebraic manipulation, the laws of exponents, and theorems such as the Squeeze Theorem or L'Hopital's Rule. You can also use a graphing calculator or online limit calculator for more complex problems.
What are common mistakes when solving limit problems with exponents?
Common mistakes when solving limit problems with exponents include forgetting to use the laws of exponents, incorrectly applying theorems, and not considering the behavior of the function at the specific value that the input is approaching.
What is a logarithm and how does it relate to limit problems with exponents?
A logarithm is the inverse operation of an exponent. It is used to solve for the exponent in an exponential function. In limit problems with exponents, logarithms can be used to simplify the expression and make it easier to evaluate the limit.
How do I solve a limit problem with logarithms?
To solve a limit problem with logarithms, you can use algebraic manipulation, the properties of logarithms, and theorems such as the Squeeze Theorem or L'Hopital's Rule. You can also use a graphing calculator or online limit calculator for more complex problems.
