LIMIT question needs your attention
  • Thread starter khurram usman
  • Tags
    Limit
In summary: up a bit more.here is what i understand:for right hand limit : 3(x-5)/|x-5|and since both numerator and denominator are positive we get 3for left handed : 3(x-5)/|x-5|in this case the numerator becomes negative but the denominator stays positive . so we get -3
khurram usman
87
Limit x-->0- [[sqrt(88*x^2)] / x]
i think the answer of this question should be sqrt(88) but according to my instructor its -sqrt(88)
so please solve this one for me. only the left hand limit .
Remember that sqrt(x2)= |x| = -x if x < 0.
ok...so the x in numerator will be positive and the one in the denominator negative.
so now the answer will be -sqrt(88)
Not quite. The x in the numerator is equal to the x in the denominator; it's not that one of them is negative and the other positive. The point is that the fraction |x|/x = (-x)/x. Still, x itself is negative as x → 0-.
i have one more question for you
cant we cut the two 'x' in the numerator and denominator without putting values?
if we do so then we won't get the - sign in the answer
You can't cancel the x values in |x|/x without distinguishing the cases whether x > 0 or x < 0.
sorry.i get your point now. but your last point has confused them in another problem:
lim x->5 [3x-15/(sqrt{x^2 + 25 - 10x}]
how will u solve this question for the left and right hand limits separately?
Given our previous example, what do you get for your denominator [itex]\sqrt{(x-5)^2}[/itex] ? It is the same idea.
ryt?
and overall the limit of function doesn't exist at 3
:smile: Yes that's right. Sorry for the delay getting back to you but the rest of my life intervened.
thanks for your help...you cleared my concept
FAQ: LIMIT question needs your attention
What is a "LIMIT question"?
A "LIMIT question" is a type of question that asks for the maximum or minimum value of a given function or expression. It is commonly used in mathematical and scientific fields to determine boundaries or limits of a system or process.
Why does a "LIMIT question" require attention?
A "LIMIT question" requires attention because it is often used to solve problems and make predictions in scientific research. The results of a "LIMIT question" can provide valuable insights and inform decisions in various fields, such as physics, engineering, economics, and more.
How is a "LIMIT question" typically solved?
A "LIMIT question" is typically solved by using mathematical techniques, such as the limit laws, L'Hopital's rule, or Taylor series expansion. These methods involve evaluating the function or expression at a specific point or approaching a certain value, and can be done by hand or with the help of computational tools.
What are some real-world applications of "LIMIT questions"?
"LIMIT questions" have numerous real-world applications, including predicting the maximum load a bridge can withstand, determining the limits of a chemical reaction, estimating the maximum population size of a species, and more. They are also commonly used in data analysis to identify trends and patterns in large datasets.
Are there any limitations to "LIMIT questions"?
Yes, there are limitations to "LIMIT questions". The results may not accurately represent the real-world scenario if the underlying assumptions and conditions are not met. Additionally, some "LIMIT questions" may not have a closed-form solution and require approximation methods. It is important to carefully consider the context and assumptions when using "LIMIT questions" in scientific research.
