Limit (sinx)^2/x^2 answer check please
  • Thread starter synergix
  • Tags
    Limit
In summary, the limit of sin2x/x2 as x approaches infinity is 0, as sin will never go above 1 or below -1 and x2 will approach infinity. This can also be proven using the squeeze theorem or the comparison theorem.
synergix
178
Limit sin2x/x2
x->infinity
0 because sin will never go above 1 or below -1 and x2 will approach infinity
am I right??
Right. Formally, you conclude the limit is 0 from the squeeze theorem.
Thanks. But I never understood the squeeze theorem it was never explained to me very well.
You are saying 0<=sin(x)^2/x^2<=1/x^2 (sin(x) can be between -1 and 1 but 0<=sin(x)^2<=1 since it's squared). Since the two outside limits are zero, lim sin(x)^2/x^2 must also be zero. It's 'squeezed' between the two outside limits.
synergix said:
Limit sin2x/x2
x->infinity
am I right??
Personally, I start by using the comparison theorem for these types of limits/integrals. This helps me figure out whether it will converge or diverge and also gives me the limit.
sin(x) is always going to be less than or equal to 1 and greater than or equal to -1. Same goes for cos(x).
sec(x) or csc(x) will always be greater than or equal to one.
So, consider:
lim sin^2 (x)/x^2 < lim 1/x^2
x->infinity x->infinity
limit 1/x^2
x->infinity
limit 0
x->infinity
So, sin^2(x)/x^2 converges and its limit is 0.
*note* I'm a Calc II Student. *note*
Or you refer to the standard limit [tex]\lim_{x\to\infty}\frac{\sin x}{x}=0[/tex] and use the product rule. Of course this 'standard limit' can be proved with the squeezing theorem, so if you're not allowed to use it (as 'standard') you might as well follow Dick.
FAQ: Limit (sinx)^2/x^2 answer check please
1. What is the limit of (sinx)^2/x^2 as x approaches 0?
The limit is equal to 1.
2. How do you find the limit of (sinx)^2/x^2?
You can find the limit by factoring out x^2 from the numerator and denominator and then using the limit definition to evaluate the limit.
3. Can you simplify (sinx)^2/x^2?
Yes, you can simplify it to 1.
4. What does the limit of (sinx)^2/x^2 represent?
The limit represents the slope of the tangent line at x=0 on the graph of y=(sinx)^2/x^2.
5. Is the limit of (sinx)^2/x^2 defined at x=0?
Yes, the limit is defined at x=0 because the numerator and denominator both approach 0 as x approaches 0.
