Limit to Infinity of Quotient with Square Root - Reducing the Equation
  • Thread starter njh
  • Tags
    Limits
In summary, the process of finding the limit of a quotient involving a square root as the variable approaches infinity typically involves simplifying the equation. This can be achieved by dividing both the numerator and the denominator by the highest power of the variable present in the denominator. This method helps eliminate the square root and simplifies the expression, allowing for easier evaluation of the limit, which often results in identifying dominant terms that dictate the behavior of the function at infinity.
njh
Find the limit as x tends to negative infinity of the quotient.
##\lim_{x \to -\infty} f(x)## = ##\frac{\sqrt{16x^2 - x^2}}{6x^3 + x^2}##
##\frac{\sqrt{16x^6}-\sqrt{x^2}}{6x^3 + x^2}##
##\frac{4x^3-\sqrt{x^2}}{6x^3+x^2}##
##\frac{4-\sqrt{x^2}}{6+x^2}##
My request is may I confirm that I have this correct up to this point?
I do know the final answer, I know the suggested process for calculating the answer, but I want to check that I can also get the correct answer this way. Thank you. Hopefully the formulas come out alright, as I am using Laytex for the first time.
I have corrected the delimiter $ to ## which is what we use for inline LaTeX code here. I have not corrected what looks like a typo in your "relevant equation" line.
I assume we have a function ##f(x)=\dfrac{\sqrt{16x^6-x^2}}{6x^3+x^2}## and you want to know what ##\lim_{x \to -\infty}f(x)## is.
Note that in general ##\sqrt{a+b}\neq \sqrt{a}+\sqrt{b}##. Furthermore, ##\sqrt{x^6}=|x^3|=|x|^3## because we only have the positive square root here. ##\sqrt{x^6}=+\sqrt{x^6}=|x|^3.## Since ##x^3## can assume negative numbers, whereas the positive square root can not, we have to use the absolute value function here.
Please confirm that I got the function right or correct it if I guessed it wrong.
Likes MatinSAR
Notice you can pull out the ##x^2## out of the root in the numerator , end up with an ##x^1## on top , then you have ##6x^3+x^2## in the denominator.
Can you see which of the numerator or denominator will dominate the expression?
Likes MatinSAR
Yes, that is the correct function. Thank you for the notation correction, as well as the reminder on addition and subtraction under square roots, which I see would have led me down the wrong path. I see the subsequent pointer from WWGD, so I'll try and answer that next and see where it takes me.
In response to WWGD, The denominator dominates the equation. The reason is that ##\sqrt{x^6}=|x|^3##, so the equation (in terms of what dominates) is ##\dfrac{x^3-x^2}{x^3+x^2}##
I take the point from fresh_42 that I can not square root the numerator's terms individually' as ##\sqrt{a+b}\neq \sqrt{a}+\sqrt{b}##
I have tried to pull out the x^2 from the numerator, though I get 1 and not x, so I have missed something here ##\dfrac{\sqrt{16x^6-x^2}}{x^2}=\sqrt{x^2(16x^4-1)}## I do not see that helps me and it is not what WWGD implied, so I have missed something. I will go away and think about this.
Function equivalent in terms dominating numerator and denominator is 4x^3/6x^3=4/6
No, because as already stated, ##\sqrt{16x^6} \ne 4x^3##. For example, if x = -1, the left side simplifies to 4, but the right side simplifies to -4.
I think bamboum just meant in terms of whether the numerator or denominator dominates the equation, so they are just saying that the denominator dominates, which as a starting indicator sounds correct. Oh, but I think that I see what you mean. Whether it is + or - is not.
Proceed step by step. We have ##f(x)=\dfrac{\sqrt{16x^6-x^2}}{6x^3+x^2}.## Don't remove parts of the equation too early. By ##\sqrt{a \cdot b}=\sqrt{a}\cdot \sqrt{b}## we get ##f(x)=\dfrac{|x|\sqrt{16x^4-1}}{6x^3+x^2}.## We can assume that ##x<0## since we are interested in ##x\rightarrow -\infty .## So
\begin{align*}
\lim_{x \to -\infty}f(x)&=\lim_{x \to -\infty}\dfrac{|x|\sqrt{16x^4-1}}{6x^3+x^2}=\lim_{x \to -\infty}\dfrac{\sqrt{16x^4-1}}{-6x^2+|x|}
\end{align*}
Now, @WWGD's hint asks: what happens with decreasing ##x,## i.e. with ##x\rightarrow -\infty .## As you correctly observed, the higher powers of ##x## dominate the lower powers of ##x## which becomes irrelevant by decreasing ##x.## Now we can write
\begin{align*}
\lim_{x \to -\infty}f(x)&=\lim_{x \to -\infty}\dfrac{\sqrt{16x^4-1}}{-6x^2+|x|}=\lim_{x \to -\infty}\dfrac{\sqrt{16x^4}}{-6x^2}=\ldots
\end{align*}
You have to keep the signs in mind at every step. We have ##f(x)=\dfrac{+}{-}=-## for ##x<0.##
Fantastic, so -2/3.
There were a couple of things that I hit a wall on.
The first was watching the negatives at each stage, which with hindsight just requires care.
The second was that I initially tried to get rid of the square root as a way to simplify, which proved wrong.
The one thing that surprised me is the ignoring of |x|. I take your point that the dominating factor is the highest power, but I thought that I still had to get rid of any other value for x, which I now is not necessary. Ignoring something close to infinity is counter intuitive.
Thank you for that additional direction. As I had not understood that last principle, I would not have got any further alone.
FAQ: Limit to Infinity of Quotient with Square Root - Reducing the Equation
What is the general approach to finding the limit to infinity of a quotient involving a square root?
The general approach involves simplifying the quotient by factoring out the highest power of the variable in the numerator and the denominator. This often includes rationalizing the square root if necessary, and then evaluating the limit as the variable approaches infinity.
How do you handle the square root in the quotient when taking the limit to infinity?
To handle the square root, you can multiply and divide by the conjugate of the expression involving the square root. This helps to eliminate the square root in the denominator or numerator, making it easier to simplify the expression and find the limit.
What happens to the terms of lower degree when taking the limit to infinity?
When taking the limit to infinity, terms of lower degree become negligible compared to the terms of higher degree. Therefore, you can often ignore these lower-degree terms in the simplified form of the quotient to find the limit more easily.
Can L'Hôpital's Rule be used to find the limit to infinity of a quotient with a square root?
Yes, L'Hôpital's Rule can be used when the limit results in an indeterminate form like 0/0 or ∞/∞. By differentiating the numerator and the denominator, you can often simplify the expression and find the limit more straightforwardly.
What is a common mistake to avoid when finding the limit to infinity of a quotient involving a square root?
A common mistake is failing to correctly simplify the expression by not factoring out the highest power of the variable or incorrectly handling the square root. This can lead to incorrect conclusions about the behavior of the function as the variable approaches infinity.
