Limit - Values of a and b that satisifies the equation.
  • MHB
  • Thread starter Dethrone
  • Tags
    Limit
In summary, the conversation discusses using l'Hopital's rule to find the values of $a$ and $b$ that would make an equation true. The conversation also explores the use of trigonometric properties and how to handle indeterminate forms. The values of $a$ and $b$ are determined to be $\frac{4}{3}$ and $-2$, respectively.
Dethrone
717
Hi (Wave), back already :D
For what values of $a$ and $b$ is the following equation true?
$$\lim_{{x}\to{0}}\left(\frac{\sin\left({2x}\right)}{x^3}+a+\frac{b}{x^2}\right)=0$$
I tried l'hopitals rule, but it just got more complicated.
My progress:
$$\lim_{{x}\to{0}}\left(\frac{x^2\left(\sin\left({x}\right)+ax^3+bx\right)}{x^5}\right)=0$$
For the limit to evaluate to $0$, then it has to be in indeterminate form. Hence, $\sin\left({x}\right)+ax^3+bx=0$.
Any hints?!
You inclination to combine terms is good, but you should have:
\(\displaystyle \lim_{x\to0}\left[\frac{\sin(2x)+ax^3+bx}{x^3}\right]\)
We see this in an indeterminate form of 0/0, so apply L'Hôpital's rule (remember to differentiate numerator and denominator separately). What do you get?
My progress:
Any hints?!
What happened to the $(2x)$ that was insided the sine? :eek:
Anyway, let's simplify to:
$$\lim_{{x}\to{0}}\left(\frac{\sin\left({2x}\right)+ax^3+bx}{x^3}\right)=0$$
This is in the indeterminate form 0/0, because:
$$\lim_{{x}\to{0}}\left(\sin\left({2x}\right)+ax^3+bx\right)
=\sin\left({2\cdot 0}\right)+a\cdot 0^3+b\cdot 0
=0$$
So... what do you get if you apply l'Hôpital's rule? (Wondering)Edit: Darn! Outmarked! ;)
I realized about the cancelling right when you posted, but...
$a=\frac{4}{3}$ :D
$a=\frac{4}{3}$ :D
That's quick now!
... and $b$? (Wondering)
I think I got it!
$$\displaystyle \lim_{x\to0}\left[\frac{\sin(2x)+ax^3+bx}{x^3}\right]=0$$
It's in indeterminate form, so the numerator must evaluate to 0.
$$\lim_{{x}\to{0}}\sin(2x)+ax^3+bx=0 $$
Knowing that $\lim_{{x}\to{0}} \frac{sin2x}{2x}=0$,
$$b=-2$$
Similarly, we can go back to the original limit and applying l'hopital's once:
$$\lim_{{x}\to{0}}\frac{2\cos\left({2x}+3ax^2+b\right)}{3x^2}=0$$
And,
$$\lim_{{x}\to{0}}2\cos\left({2x}\right)+3ax^2+b=0$$
$$\lim_{{x}\to{0}}2\cos\left({2x}\right)+4x^2+b=0$$
$$b=-2$$Finally,$$\lim_{{x}\to{0}}\frac{\sin\left({2x}\right)}{x^3}+\frac{4}{3}-\frac{2}{x^2}=0$$
Which satisfies :D
Rido12 said:
I think I got it!
Erm... it's the other way around.
Both the numerator and the denominator evaluate to 0, so it's in indeterminate form. (Nerd)
Hold on! I don't know that! Is that really true? (Wondering)
Hmm. Is $2\cos\left({2x}+3ax^2+b\right)$ really the derivative of $\sin(2x)+ax^3+bx$? (Wondering)
This is what I did...I began with:
\(\displaystyle \lim_{x\to0}\left[\frac{\sin(2x)+ax^3+bx}{x^3}\right]=0\)
Apply L'Hôpital:
\(\displaystyle \lim_{x\to0}\left[\frac{2\cos(2x)+3ax^2+b}{3x^2}\right]=0\)
In order for the value of the limit to be determinate, we must have:
\(\displaystyle \lim_{x\to0}\left[2\cos(2x)+3ax^2+b\right]=2+b=0\implies b=-2\)
So, we have:
\(\displaystyle \lim_{x\to0}\left[\frac{2\cos(2x)+3ax^2-2}{3x^2}\right]=0\)
Apply L'Hôpital and simplify:
\(\displaystyle \lim_{x\to0}\left[\frac{3ax-2\sin(2x)}{3x}\right]=0\)
Apply L'Hôpital:
\(\displaystyle \lim_{x\to0}\left[\frac{3a-4\cos(2x)}{3}\right]=0\)
\(\displaystyle \frac{3a-4}{3}=0\)
\(\displaystyle a=\frac{4}{3}\)
Hence:
\(\displaystyle (a,b)=\left(\frac{4}{3},-2\right)\)
Sorry, these were $LaTeX$ and typing errors, hehe.
About the your first statement, I wasn't clear, but I meant to say was because the denominator goes to 0, and the limit evaluates to a finite value, the numerator must also go to 0, meaning that it must be indeterminate.
2nd statement, it equals 1, don't know what I was on. (Smoking) -> too much smoking on this forum :D
Last statement, I meant $2\cos\left({2x}\right)+3ax^2+b$. I was too excited that I got the answer that I couldn't wait one second longer to submit! :D
- - - Updated - - -
Apply L'Hôpital:
So, we have:
Apply L'Hôpital:
Hence:
Thanks ILS and Mark!
I essentially did it this way (look at my method #2 for solving $b$), but I did it in a different order :D
As an aside, if you want the trademark $\LaTeX$, use the code:
\LaTeX
:D
FAQ: Limit - Values of a and b that satisifies the equation.
What is the equation that represents the limit values of a and b?
The equation is represented as a/b = a√b or a^2b = b^3.
What do the values a and b represent in this equation?
The values a and b represent the constants in the equation that determine the limit of the function. They can be any real numbers, but must satisfy the given equation.
How do I find the limit values of a and b?
The limit values of a and b can be found by solving the given equation. You can also use a graphing calculator or a computer program to plot the function and determine the values that satisfy the equation.
Can there be more than one pair of values for a and b that satisfy the equation?
Yes, there can be multiple pairs of values for a and b that satisfy the equation. This is because the equation can have multiple solutions, and the limit values of a and b will depend on the specific function and its properties.
How do the values of a and b affect the function's limit?
The values of a and b determine the behavior of the function and its limit. The function may have a different limit for different values of a and b, and these values can also affect the continuity and differentiability of the function at a certain point.
