Limiting angle of resolution question
In summary: Aschild is standing at the edge of a straight highway watching her grandparents' car driving away at 20.6 m/s. The air is perfectly clear and steady, and after 13.1 min the car's two taillights (645 nm) appear to merge into one. Assuming the diameter of the child's pupils is 4.97 mm, calculate the width of the car.In summary, the child's eye's diameter is 4.97 mm, and the car's width is 2.56 m.
glid02
54
I have a question about a limiting angle of resolution when viewed from a circular aperture.
I'm trying to find the distance between two lights of a certain wavelength. The lights appear to merge into one at a given distance when viewed through an aperture of some given size.
So far I've tried these equations:
theta(min)=1.22(lambda/D)
I know both lambda and D (diameter), so I now know theta(min).
Now I've tried
theta(min)=d/L
where I know L(distance at which the lights appear to merge) but not d. After solving for d I still can't get the right answer. If anyone could help me out a it'd be great. Thanks a lot.
It looks like you did the right thing. Give us the values and we'll check your math.
The formulas you used are for "small angle approximations." If L is not very large, then the answer will be off.
Now I've tried
theta(min)=d/L
Try [itex]sin\theta_{min} = d/L[/itex]
AM
A child is standing at the edge of a straight highway watching her grandparents' car driving away at 20.6 m/s. The air is perfectly clear and steady, and after 13.1 min the car's two taillights (645 nm) appear to merge into one. Assuming the diameter of the child's pupils is 4.97 mm, calculate the width of the car.
That's the question, I have 2.564 m as the answer.
You have everything you need. Use [itex]\theta = d/L[/itex] and [tex]\theta = 1.22\lambda/D[/itex] where D is the diameter of the pupil, L is the distance of the car and d is the width of the car.
What are you using for L? How do you calculate it? That is probably where your problem is. The answer 2.56 m is correct using the information provided.
AM
FAQ: Limiting angle of resolution question
What is the limiting angle of resolution?
The limiting angle of resolution is the smallest angle at which two closely spaced objects can be seen as separate and distinct from one another. It is a measure of the resolving power of a given optical system.
How is the limiting angle of resolution determined?
The limiting angle of resolution is determined by the diameter of the objective lens or mirror and the wavelength of light being used. It can also be affected by atmospheric conditions and the quality of the optics.
Why is the limiting angle of resolution important in scientific research?
The limiting angle of resolution is important because it determines the level of detail that can be observed and recorded in a given optical system. It is crucial for accurately studying and understanding small or distant objects, such as cells or celestial bodies.
Can the limiting angle of resolution be improved?
Yes, the limiting angle of resolution can be improved by using higher quality optics, increasing the diameter of the objective lens or mirror, and using shorter wavelengths of light. Advanced techniques such as adaptive optics can also improve the resolution of images.
How does the limiting angle of resolution affect the design of optical instruments?
The limiting angle of resolution plays a significant role in the design of optical instruments, as it determines the size and complexity of the optics needed to achieve a desired level of resolution. It also influences the choice of light source and other components of the instrument.
