Limits of functions, inequalities (analysis)
In summary: Therefore, by the definition of limit, g(f(x)) \rightarrow l as x \rightarrow x0.In summary, we can prove that g(f(x)) tends to l as x tends to x0 by using the definition of limit and choosing appropriate values for \epsilon and \delta based on the given conditions for f(x) and g(y).
Kate2010
146
Assume:
1) f(x) [tex]\rightarrow[/tex] yo as x [tex]\rightarrow[/tex] x0
2) g(y)[tex]\rightarrow[/tex] l as y [tex]\rightarrow[/tex] y0
3) g(y0) = l
Prove that g(f(x)) [tex]\rightarrow[/tex] l as x [tex]\rightarrow[/tex] x0
Definition of function tending to limit - E is a subset of R, f:E->R, f tends to l as x tends to p if for all e>0 there exists a d>0 such that |f(x) - l | < e for all x in E such that 0 < |x-p|< d.
Theorem: f: E [tex]\rightarrow[/tex] R where E [tex]\subseteq[/tex] R, p is a limit point of E and l [tex]\in[/tex] R. The following are equivalent:
a) f(x) [tex]\rightarrow[/tex] l as x [tex]\rightarrow[/tex] p
b) for every sequence {pn} in E such that pn [tex]\neq[/tex] p and lim[tex]_{n\rightarrow\infty}[/tex] pn = p we have that f(pn) [tex]\rightarrow[/tex] l as n[tex]\rightarrow[/tex] [tex]\infty[/tex]
I thought I could use the above theorem with (1) to say that every sequence {xn} such that xn[tex]\neq[/tex] x0 and lim[tex]_{n\rightarrow\infty}[/tex] xn = x0, we have that f(xn) [tex]\rightarrow[/tex] y0 as n [tex]\rightarrow[/tex] [tex]\infty[/tex]
Similarly from (2) every sequence {yn} such that yn[tex]\neq[/tex] y0 and lim[tex]_{n\rightarrow\infty}[/tex] yn = y0, we have that g(yn) [tex]\rightarrow[/tex] l as n [tex]\rightarrow[/tex] [tex]\infty[/tex]
So, can I let yn = f(x) ( or maybe f(xn)?
Would this help show that g(f(x)) [tex]\rightarrow[/tex] l? I haven't used (3) or really shown this happens as x [tex]\rightarrow[/tex] x0.
You don't need sequences to do this; you can use the definition of limit directly. Find a condition on [tex]y[/tex] that ensures that [tex]g(y)[/tex] is close to [tex]l[/tex], then find a condition on [tex]x[/tex] that ensures that [tex]f(x)[/tex] satisfies that condition on [tex]y[/tex].
From (3) I know for all [tex]\epsilon[/tex]>0 [tex]\exists[/tex] [tex]\delta[/tex]1 > 0 such that |g(y)-l|<[tex]\epsilon[/tex] for all y such that 0<|y-y0|<[tex]\delta[/tex]1
Similarly from (1)
for all [tex]\epsilon[/tex]>0 [tex]\exists[/tex] [tex]\delta[/tex]2 > 0 such that |f(x)-y0|<[tex]\epsilon[/tex] for all x such that 0<|x-x0|<[tex]\delta[/tex]2
Can I then do something along these lines:
|g(f(x)-y0)-l|
=|g(f(x)) - g(y0) -l|
=|g(f(x)) - 2l|
Is less than [tex]\epsilon[/tex] for all [tex]\delta[/tex]=min([tex]\delta[/tex]1, [tex]\delta[/tex]2) such that 0<|x-x0|<[tex]\delta[/tex]?
Similarly from (1)
|g(f(x)-y0)-l|
=|g(f(x)) - 2l|
They are not correct because one can't ensure that g(f(x)-y0) is close to [tex]l[/tex] and of course g(y) is not a linear function to assign such a property to it that g(f(x)-y0) = g(f(x))-g(y0). Try to apply both the f(x) and g(f(x)) to the triangular inequality!
AB
How is this?
Let [tex]\epsilon[/tex]> 0
[tex]\exists[/tex][tex]\delta[/tex]1>0 such that |g(y)-l| = |g(y) - g(y0| < [tex]\epsilon[/tex]
[tex]\exists[/tex] ][tex]\delta[/tex]2>0 such that |f(x) - y0| < [tex]\delta[/tex]2
So for all x such that |x-x0|< min([tex]\delta[/tex]1,[tex]\delta[/tex]2) we have
|(gof)(x) - (gof)(x0)| = |g(f(x))-g(f(x0))| = |g(f(x)) - l| < [tex]\epsilon[/tex]
FAQ: Limits of functions, inequalities (analysis)
What are limits of functions?
Limits of functions refer to the value that a function approaches as the input approaches a certain value. It is used to describe the behavior of a function near a specific point. For example, the limit of the function f(x) as x approaches 2 can be written as lim x→2 f(x).
How do you determine the limit of a function?
To determine the limit of a function, you can use various techniques such as direct substitution, factoring, and rationalization. You can also use the limit laws to simplify the expression and evaluate the limit. In some cases, you may need to use more advanced techniques like L'Hopital's rule or the squeeze theorem to evaluate the limit.
What are the different types of inequalities in analysis?
In analysis, there are three main types of inequalities: strict inequalities, non-strict inequalities, and absolute value inequalities. Strict inequalities, denoted by < (less than) or > (greater than), indicate that the values on either side of the inequality sign are not equal. Non-strict inequalities, denoted by ≤ (less than or equal to) or ≥ (greater than or equal to), allow for the values to be equal. Absolute value inequalities, denoted by | |, involve the absolute value of a variable and can have multiple solutions.
How do you solve an inequality?
To solve an inequality, first identify the type of inequality and then use algebraic techniques to isolate the variable on one side of the inequality sign. Remember to apply the same operation to both sides of the inequality. Once you have isolated the variable, you can determine the solution set by either graphing the inequality on a number line or using interval notation.
How are limits and inequalities related?
Limits and inequalities are related in the sense that limits are used to describe the behavior of a function near a certain point, whereas inequalities are used to describe the relationship between two quantities. In some cases, limits can be used to prove inequalities, and in other cases, inequalities can be used to determine the existence or non-existence of a limit.
