Line absorption spectrum and stars
In summary: A/4πD2 of the energy. (A is the area of your Objective and D is the distance from the star / gas)...to the energy that is scattered?To the energy that is scattered, it is absorbed and then re-emitted in all directions.
Clara Chung
304
Why can't hydrogen gas on the stars be detected by using line emission spectrum of hydrogen. Why must we use line absorption spectrum to detect?
The hydrogen atoms that are producing the light energy inside a star are under high pressure and temperature. What emerges is not Hydrogen Line spectra but Black Body Radiation (a continuum of frequencies from 'DC to Daylight' and beyond). The H atoms that absorb light are cold and under low density conditions. They are operating in the conditions that our early QM lectures describe so they will absorb specific frequencies (lines).
Likes Clara Chung
The radiation from stars is black body radiation passing through a relatively cooler surface layer. We see the absorption lines from the elements of the star surface.
As a follow on question to the OP's, why do we see an absorption line at all? Why doesn't the hydrogen (and other elements) simply re-emit the same light a short time later, resulting in a continuous spectrum?
Likes Clara Chung
That was a question I asked , myself once. The light is absorbed from the direction of the source and then re-emitted in all directions so what you see is a dim line at the absorbed frequency.
Likes Clara Chung, davenn and Drakkith
almost :smile: it's purely an absorption thing, not re-emission
http://physics.ucr.edu/~wudka/Physics7/Notes_www/node107.html
Emission and absorption lines
When heated every element gives off light. When this light is decomposed using a prism it is found to be made up of a series of ``lines'', that is, the output from the prism is not a smooth spectrum of colours, but only a few of them show up. This set of colours is unique to each element and provides a unique fingerprint: if you know the colour lines which make up a beam of light (and you find this out using a prism), you can determine which elements were heated up in order to produce this light.
Similarly, when you shine white light through a cold gas of a given element, the gas blocks some colours; when the ``filtered'' light is decomposed using a prism the spectrum is not full but shows a series of black lines (corresponding to the colours blocked by the gas); see Fig. 8.3. For a given element the colours blocked when cold are exactly the same as the ones emitted when hot.
from wiki
https://en.wikipedia.org/wiki/Fraunhofer_lines
The Fraunhofer lines are typical spectral absorption lines. Absorption lines are dark lines, narrow regions of decreased intensity, that are the result of photons being absorbed as light passes from the source to the detector. In the Sun, Fraunhofer lines are a result of gas in the photosphere, the outer region of the sun. The photosphere gas is colder than the inner regions and absorbs light emitted from those regions.
my bolding ... the important part :smile:
Dave
Likes Clara Chung
"The photosphere gas is colder than the inner regions and absorbs light emitted from those regions."
I could take exception to that way of putting things because of the implication that the process only occurs in "colder" regions. There is a flux of photons moving out from the centre of the star and that involves energy being passed from one atom (ion) to the next in a chain. This takes hundreds of thousands of years, from core to surface, aamof. See Wiki Link on energy transfer. In the condensed state, the frequency of the photons can be anything (black body radiation spectrum) and can change at each interaction. So you have absorption and emission steps throughout the journey. The only difference with what happens in the cooler / less dense atoms is that the frequencies are limited to the characteristic ones of the gas atoms.
davenn said:
not re-emission
The energy has to be re-emitted after a finite (short) time. It can't be stored up.
yes, but it isn't the cause of the dark absorption line
I don't see how you can say that. Photons are absorbed (light on the path from the star to you) and they are then re-emitted in all directions, so each gas atom is a point source, from which you (in one particular direction) get only
i.e. the energy is scattered and not just absorbed.
In your model, what happens to the energy that's absorbed by the gas atoms?
Related to Line absorption spectrum and stars
1. What is a line absorption spectrum?
A line absorption spectrum is a pattern of dark lines seen in a continuous spectrum of light, created when light from a hot, dense source passes through a cooler, less dense gas. The gas absorbs specific wavelengths of light, leaving behind dark lines in the spectrum.
2. How is the line absorption spectrum used to study stars?
By analyzing the dark lines in a star's spectrum, scientists can determine the elements present in the star's atmosphere. Each element has a unique pattern of absorption lines, allowing scientists to identify the composition of a star. The spectrum can also reveal information about a star's temperature, density, and motion.
3. What causes the dark lines in a line absorption spectrum?
The dark lines in a line absorption spectrum are caused by the absorption of specific wavelengths of light by the elements present in a star's atmosphere. When light from the star passes through the cooler, less dense gas, the gas absorbs certain wavelengths of light, leaving behind dark lines in the spectrum.
4. How is the line absorption spectrum different from the emission spectrum?
The line absorption spectrum and emission spectrum are two types of spectra that result from the interaction of light and matter. The line absorption spectrum is created when light from a hot, dense source passes through a cooler, less dense gas, while the emission spectrum is created when a hot, dense gas emits light. The line absorption spectrum has dark lines, while the emission spectrum has bright lines.
5. Can the line absorption spectrum tell us about the age of a star?
Yes, the line absorption spectrum can provide information about the age of a star. As stars age, their chemical composition changes, and the absorption lines in their spectra shift. By analyzing the pattern and position of these lines, scientists can estimate the age of a star.
  • Other Physics Topics
16K
  • Astronomy and Astrophysics
