hime
- 26
An infinite line of charge with linear density λ = 8.8 μC/m is positioned along the axis of a thick insulating shell of inner radius a = 2.9 cm and outer radius b = 4.1 cm. The insulating shell is uniformly charged with a volume density of ρ = -659 μC/m3.
What is Ex(R), the value of the x-component of the electric field at point R, located a distance 1.45 cm along a line that makes an angle of 30 deg with the x-axis?
What is Ey(R), the value of the y-component of the electric field at point R, located a distance 1.45 cm along a line that makes an angle of 30 deg with the x-axis?
E.dA = q/ eo
Area of the cylinder = 2*pi* r* length
Using the above formula, I got:
Ex(R) =10914190.5*cos(30) but its wrong.
The y-component of the electric field at point R is not zero. The charges do produce a non-zero field at point R. You can determine the direction of the field at point R from the symmetry of the charge distribution.
