Line integrals, gradient fields
In summary, line integrals are used in vector calculus to find the total value of a function along a curve or path. Gradient fields are vector fields that represent the rate of change of a scalar field in all directions. These two concepts are related through the fundamental theorem of calculus, which states that the line integral of a gradient field over a curve is equal to the difference in values of the scalar field at the endpoints of the curve. In physics, line integrals and gradient fields are important in calculating work, potential energy, and electric and magnetic fields. They are also used to describe the flow of fields through a surface or volume, which is crucial in understanding fluid dynamics and electromagnetism. Line integrals and gradient fields can be calculated using
jonroberts74
189
##\nabla{F} = <2xyze^{x^2},ze^{x^2},ye^{x^2}##
if f(0,0,0) = 5 find f(1,1,2)
my book doesn't have a good example of a problem like this, am I looking for a potential?
##<\frac{\partial}{\partial x},\frac{\partial}{\partial y},\frac{\partial}{\partial z} >= <2xyze^{x^2},ze^{x^2},ye^{x^2}>##
Yes, solve the three differential equations to find F(x,y,z) up to a constant. The given condition sets this constant, from which you can find F(x,y,z) for all x,y,z.
##\frac{\partial}{\partial x} = 2xyze^{x^2} \Rightarrow \int 2xyze^{x^2}dx = yze^{x^2} + h(y,z)##
##\frac{\partial}{\partial y} = ze^{x^2} = ze^{x^2} + h(y,z) \Rightarrow h_{y}(y,z) = 0##
##\frac{\partial}{\partial z} = ye^{x^2} = ye^{x^2}+h(z) \Rightarrow h_{z}(z) = h'(z)##
##h'(z) = 0 \Rightarrow h(z) = k## for a constant k, and because f(0,0,0) = 5 then
##f= yze^{x^2} + 5##
so ##f(1,1,2) = 1(2)e^1+5 = 2e+5##
Correct!
ehild
Related to Line integrals, gradient fields
What is a line integral?
A line integral is a mathematical concept used in vector calculus to find the total value of a function along a curve or path. It takes into account not only the magnitude of the function, but also its direction along the path.
What is a gradient field?
A gradient field is a vector field that represents the rate of change of a scalar field in all directions. It is typically represented by a set of arrows pointing in the direction of the steepest increase of the scalar field.
How are line integrals and gradient fields related?
Line integrals and gradient fields are related through the fundamental theorem of calculus, which states that the line integral of a gradient field over a curve is equal to the difference in values of the scalar field at the endpoints of the curve.
What is the significance of line integrals and gradient fields in physics?
In physics, line integrals and gradient fields are used to calculate work, potential energy, and electric and magnetic fields. They are also used to describe the flow of fields through a surface or volume, which is important in understanding fluid dynamics and electromagnetism.
How can we calculate line integrals and gradient fields?
Line integrals and gradient fields can be calculated using various methods, including the fundamental theorem of calculus, Green's theorem, and Stokes' theorem. These theorems provide formulas for calculating line integrals and gradient fields for different types of curves and surfaces.
