Line of regression substitution
Linear regression allows for substituting a value of x to estimate y, but not the reverse due to the nature of correlation and regression analysis. The product of the slopes from two linear regressions (y on x and x on y) equals the R² value, which indicates the strength of their correlation. If x and y are uncorrelated, both slopes can be zero, leading to poor estimates when trying to invert the regression. The minimization of errors differs between estimating y from x and vice versa, as each regression targets different axes. Understanding these principles is crucial for accurate predictions in statistical modeling.
Einstein44
This is relatively straight forward, but I somehow forgot why this is:
Why is it that you can not substitute y to find x? I remember that this was the case, but I can't seem to remember why this actually is.
$$y=ax+b$$
This is the equation you get for a line of regression of a data set using the GDC...
I am not exactly sure in what context this is, as I cannot remember much about this and I couldn't find anything on the internet that mentioned this. I just hope someone understands what I mean :)
I don't understand your question. In general the point of a linear regression is so you can substitute in a value of x to find a good guess for y. You won't get exactly the right answer just because you usually assume there's some noise in your prediction, is that what you mean?
Nevermind, I believe I phrased this wrong. I meant why you cannot substitute y to estimate x. Because I remember the prof saying that you can substitute x to estimate y, but not the other way around. And I forgot the reason and didn't find anything on this on the internet, so I thought maybe someone knows what I mean.
Oh yeah. I think the way to think about this is that you can consider two linear regressions (I'm going to assume the constant term comes out zero for both)
##y=\beta_x x##
##x= \beta_y y##.
It's tempting to think that ##\beta_x \beta_y =1##. But it's not, in fact in general the product of the betas is ##R^2## value of the linear regression, and only equals 1 when the two variables are perfectly correlated. As a simple example, suppose x and y are totally uncorrelated. Then ##\beta_x=\beta_y=0##. If they are only slightly correlated, you might get that ##\beta_x## and ##\beta_y## are both small and almost zero. Then trying to invert your linear regression is going to give you a very bad result for an estimate.
The regression shown was calculated to minimize the sum-squared-errors of the y estimates versus the y sample values. Those errors are the distances parallel to the Y-axis. If you want to estimate x, you would want a regression line that minimizes the sum-squared-errors of the x estimates versus the x sample values. Those errors are the distances parallel to the X-axis. So the minimization would be different.
As Schreder said, product of slopes is ## R^2##, where ##R## is the correlation coefficient.
Slopes are given as ##R \frac {s_{xx}}{s_{yy}}##, so that the products *
Barring cases where either denominator is ##0, R \frac {s_{yy}}{s_{xx}} * R \frac {s_{xx}}{s_{xx}} =R^2##,
Notice that for nonlinear relations, the relation between the two may be invertible only locally , e.g., for
Hooke's law ##y =kx^2 ##
* Barring cases when either is 0, which means data is constant.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
