Line Segment AB....Challenge Question
  • MHB
  • Thread starter mathdad
  • Tags
    Line
In summary, the point P is located on line segment AB in such a way that AB/AP = AP/AB. This means that the ratio of AB to the longer segment is equal to the ratio of the longer segment to the shorter segment.
mathdad
1,283
The point P is located on line segment AB in such a way that AB/AP = AP/AB. In words: P divides line segment AB into two segments such that the ratio of AB to the longer segment is equal to the ratio of the longer segment to the shorter segment.
(A) Show that this ratio is equal to (1/2)(1 + sqrt{5}).
Hint: Let AP = x and PB = y.
(B) The ratio is part (A) is denoted by k and
k = (1 + sqrt{5})/2
Verify that the number k satisfies the following algebraic properties.
1. k^2 = k + 1
2. k^3 = 2k + 1
3. k^(-1) = k - 1
4. k^(-2) = - k + 2
What on Earth is this all about?
Mathematics news on Phys.org
I think the problem should state:
"The point P is located on line segment AB in such a way that AB/AP = AP/PB"
If we use the given hint, then we may state:
\(\displaystyle \frac{x+y}{x}=\frac{x}{y}\)
Or:
\(\displaystyle x^2-xy-y^2=0\)
What do you get when you apply the quadratic formula to solve for $x$ and discard any negative roots?
Or:
I'll get back to you regarding the rest of this question.
Or:
To use the quadratic formula in your equation, we need a, b, and c.
Do we let a = 1?
Do we let b xy?
Do we let c = y^2
Do we let a = 1?
Do we let b xy?
Do we let c = y^2
To solve for $x$ here, we let:
\(\displaystyle a=1\)
\(\displaystyle b=-y\)
\(\displaystyle c=-y^2\)
Ok. I will work on this and provide solution for x.
x = +- sqrt{(-y)^2 - 4(1)(-y^2)}/2(1)
x = +- sqrt{y^2 + 4y^2}/2
x = +-sqrt{y^2(1 + 4)}/2
x = +- y*sqrt{5}/2
x = - y*sqrt{5}/2
and
x = y*sqrt{5}/2
That's not quite right:
\(\displaystyle x=\frac{-(-y)\pm\sqrt{(-y)^2-4(1)(-y^2)}}{2(1)}=y\frac{1\pm \sqrt{5}}{2}\)
Discarding the negative root, we obtain:
\(\displaystyle x=y\frac{1+\sqrt{5}}{2}\)
Now:
\(\displaystyle k=\frac{x}{y}=\)?
Now:
I see that I forgot to include the -b part of the quadratic formula. Solving for k will let me completely solve the problem. I see that k = x/y.
The x value is what you found using the quadratic formula. I am not clear on the y value.
As you said, x = y[(1 + sqrt{5})/2]. Do I solve this equation for y?
We don't need to solve for $y$. We need only to have shown that:
\(\displaystyle \frac{x}{y}=\frac{1+\sqrt{5}}{2}\)
to satisfy part A) of the problem. For part B), consider:
If we write this in terms of $k$, we find:
\(\displaystyle 1+\frac{1}{k}=k\)
This will help you with the four questions of part B). :D
Ok. I just have to replace every k with k = 1 + 1/k to verify all four parts of part (B). So, lots of algebra is basically what needs to be done.
Now necessarily...for example if we multiply through by $k$, we get:
\(\displaystyle k+1=k^2\)
And BOOM! we have question 1 of part B) done.
Thanks. Your help in my study of precalculus is greatly appreciated.
FAQ: Line Segment AB....Challenge Question
What is a line segment?
A line segment is a straight path that extends infinitely in both directions, but has a defined start and end point. It is a basic geometric shape that has length but no width or thickness.
How is a line segment different from a line?
A line segment has a finite length and two distinct endpoints, whereas a line extends infinitely in both directions and has no endpoints. A line segment can also be measured and has a specific length, whereas a line has no measurable length.
What is the notation for a line segment?
A line segment is typically denoted by two capital letters, with a bar drawn over them to signify the segment. For example, "Line Segment AB" would be written as AB ̅.
Can a line segment have a negative length?
No, a line segment by definition cannot have a negative length. The length of a line segment is always a positive value as it represents the distance between the two endpoints.
How are line segments used in geometry and real-world applications?
Line segments are used in geometry to define and measure distances and angles, as well as in the construction of other geometric shapes. In real-world applications, line segments are commonly used to represent physical objects such as roads, buildings, or boundaries, and can also be used in mathematical models to represent distances or relationships between variables.
