Linear acceleration in a circular path
In summary, the linear acceleration of a body moving in a circular path is zero, but the direction is changed so it can't be zero so this didn't persuade me. Also, I don't know the difference between the linear acceleration and the centripetal acceleration in a circular motion. Thanks for your help!
Misr
385
Hi,
What is the linear acceleration of a body moving in a circular path?
its written in my book that its zero since the magnitude of velocity is constant
BUT the direction is changed so it can't be zero so this didn't persuade me.
Also I DUNNO the difference between the linear acceleration and the centripetal acceleration in a circular motion.
Thanks
If the speed is constant then the tangential acceleration would be zero. But the total acceleration, which would be centripetal, would certainly not be zero. Some books use 'linear acceleration' to mean 'tangential acceleration'. (I wouldn't.)
mmm wat is the tangential acceleration?and why it is zero in case of uniform velocity while the direction is changed?and how to calculate it?
the tangential acceleration is the change of velocity of an object as it moves in a line that is tangent to the circular path its moving in right?
so since the centripetal force is tangent to the direction of velocity then it wouldn't change its magnitude , thus if the rope is cut the body will move with a constant tangential velocity yet no tangential acceleration
Right?
For something moving in a circle, the acceleration can have two components: One component tangent to the circle, which determines the change in speed; The other component is the centripetal acceleration, due to the changing direction.
The centripetal force is perpendicular to the direction of the velocity.
Ok thanks ,
the tangential acceleration is zero according to the law of inertia " A body retains its state of rest or motion in a straight line WITH UNIFORM VELOCITY unless acted upon by external force"
right?
Thanks
No, not right. Something moving in a circle with uniform speed has zero tangential acceleration because the speed is constant, but it is definitely accelerating and there is definitely an external force acting (the centripetal force).
k...What is the tangential acceleration?
Imagine you have a very large racing track which is in the shape of a circle, and you have a nice racing car on the track.
You get in your car and drive around the circular track at exactly 50km/hr. You look at your speedometer and it says 50, and it stays on 50 all the time.
You say to yourself, "my car has constant speed, it is not accelerating".
Your co-driver sitting next to you has done some physics and reminds you that it is not perfectly true, because the car is going round in a circle.
He points out that in order to do that you need a constant force directed towards the centre of the circle, the centripetal force, and this is provided by the grip of the wheels on the road. Your friend also points out that this force produces an acceleration towards the centre of the circle called centripetal acceleration.
You thank him for reminding you and then decide to put your foot down on the gas and make the car go faster. Your speed goes up to 100km/hr but you make sure you stay on the track.
That increase in your speed (per second) was your tangential acceleration.
Acceleration is a vector; it has direction. You can specify the acceleration in terms of its components. A component tangential to the circle (along the direction of motion) and a component perpendicular to that one along the radius of the circle (that's the "centripetal" acceleration).
but i mean when we let the stone go
This is obvious
Great Thanks
FAQ: Linear acceleration in a circular path
1. What is linear acceleration in a circular path?
Linear acceleration in a circular path refers to the rate of change of an object's linear velocity as it moves along a circular path. It is a vector quantity that measures the magnitude and direction of the change in velocity.
2. How is linear acceleration related to angular acceleration?
Linear acceleration is directly proportional to angular acceleration and the radius of the circle. This means that if the angular acceleration increases, the linear acceleration also increases, and if the radius of the circle increases, the linear acceleration decreases.
3. How is linear acceleration calculated in a circular motion?
Linear acceleration can be calculated by dividing the change in linear velocity by the change in time. It can also be calculated by multiplying the angular acceleration by the radius of the circle. The units for linear acceleration are meters per second squared (m/s²).
4. What is the difference between linear and centripetal acceleration?
Linear acceleration is the change in linear velocity, while centripetal acceleration is the acceleration towards the center of the circular path. Centripetal acceleration is caused by a centripetal force, which is necessary to keep an object moving in a circular path.
5. How does linear acceleration affect the tension in a string or rope?
In circular motion, the tension in a string or rope is directly related to the linear acceleration of the object moving in the circular path. As the linear acceleration increases, the tension in the string also increases. This is because a higher linear acceleration requires a higher centripetal force, which is provided by the tension in the string.
