MHB Linear Algebra and Determinant
Swati
1(a) Construct a 4*4 matrix whose determinant is easy to compute using cofactor expansion but hard to evaluate using elementary row operations.
(b) Construct a 4*4 matrix whose determinant is easy to compute using elementary row operations but hard to evaluate using cofactor expansion
Would a matrix with all elements zero except for those on the diagonal which are a random sample of size 4 from U(0,1) qualify?
Would a matrix with two rows equal but with values samples from U(0,1), and all other values sampled independently from U(0,1) qualify?
CB
what is U(0,1) ?
Please explain me, i couldn't understand.
Swati said:
what is U(0,1) ?
U(0,1) - the uniform distribution on [0,1). The suggestion is to use a random matrix generated in the specified way. In one case it would be diagonal, so the co-factor method would give the determinant as the product of the diagonal elements, in the second case with two equal rows row operations would deduce it has zero determinant.
CB
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
