Linear Algebra: Augmented matrix echelon form y-space?
In summary, Gauss elimination is a way of solving systems of equations that uses a matrix called the inverse of the augmented matrix.
Matriculator
51
I'm doing my homework but I'm lost on one thing. Let's say that we have a systems of equations like so:
2x1+3x2=y1
4x1+2x2=y2
Instead of setting it to a constant our teacher sets it to a variable, he says that to be able to compute this, the augmented matrix should look like:
2 3|1 0
4 1|0 1
Then of course we find the echelon form. Does this have a name? The fact that he sets it to another variable or the way the augmented matrix is set up? I'm trying to learn more about them but my professor almost never follows the regular curriculum. Thank you in advance.
Gauss elimation? Or row reduction?
2x1+3x2=y1
4x1+2x2=y2
2 3|1 0
4 1|0 1
Basically, he is doing a form of LU-decomposition. If you start with ##B = [A|I]## (##A## = your original matrix and ##I##= unit matrix), then after some row-reduction steps you end up with
##B_{new} = [U|L]##. Here, ##U## is the usual row- reduced matrix, and ##L## is what happens to the matrix ##I## that you used to augment ##A##. The matrix ##L## will be lower-triangular (unless you performed row-interchanges); it is a fact that ##L \cdot A = U##; in other words, the matrix ##L## encapsulates the row-operations you used to get from ##A## to ##U##. Multiplying by ##L## on the left produces exactly the same results as row-reduction.
Why might this be useful? Well, suppose that for some reason you needed to solve several (separate) equations of the form ##Ax = b_1, \: A x = b_2, \: \ldots ##, all having the same left-hand-side but different right-hand-side vectors ##b##. You can use the matrix ##L## to conclude that the equations reduce to the simple, triangular forms ##Ux = Lb_1, \: Ux = L b_2, \ldots ##, each of which is easily solvable by successive evaluation and back-substitution. (It would, of course, be even simpler if you had the inverse ##C = A^{-1}##, but we often try to avoid computing the inverse for reasons of efficiency and numerical stability, etc. The upper-triangular form is almost as fast to deal with.)
Setting the augmented matrix to
2 3 | 1 0
4 1 | 0 1
and completely row-reducing to get
1 0 | -1/10 3/10
0 1 | 2/5 -1/5
give the inverse matrix to the original matrix. Multiplying that inverse matrix by the (y1, y2) will then give the solution to the original matrix. If you had only the one problem with given values for y1 and y2, row reducing directly with y1, y2 would be simpler. But it often happens in applications that you have an equation like Ax= y with the same "A" but many different "y". In that case it would be simpler to find the inverse to A first, the multiply it by the various y.
More likely, your teacher is using this as a way to introduce the "inverse" matrix.
FAQ: Linear Algebra: Augmented matrix echelon form y-space?
1. What is a linear algebra augmented matrix?
An augmented matrix in linear algebra is a representation of a system of linear equations. It contains the coefficients of the variables, as well as the constants on the right-hand side, in a rectangular matrix form. This allows for easy manipulation and solving of the system of equations.
2. What is an echelon form in linear algebra?
Echelon form is a special form that a matrix can be transformed into through a series of elementary row operations. In this form, the matrix has leading ones in each row, with zeros below each leading one. This form is useful for solving systems of linear equations and finding the rank of a matrix.
3. What is y-space in linear algebra?
In linear algebra, y-space refers to the set of all possible solutions to a system of linear equations. In other words, it is the set of values that the dependent variable (usually represented by y) can take on while still satisfying all of the equations in the system.
4. How do I convert a matrix into its echelon form?
To convert a matrix into its echelon form, you can use elementary row operations such as swapping rows, multiplying a row by a non-zero constant, or adding a multiple of one row to another row. By performing these operations in a specific order, you can transform the matrix into its echelon form.
5. What is the importance of augmented matrix echelon form in linear algebra?
The augmented matrix echelon form is important in linear algebra because it allows for efficient solving of systems of linear equations. It also helps in determining the rank of a matrix, which is a key factor in understanding the properties and behavior of the system represented by the matrix.
