Linear Algebra Dimension Proof
In summary: Chapter 3 of Linear Algebra, by Shilov?. If you have that, you can look at the solution there. If not, or if you're not sure how to find the solution, I'd recommend looking up the rank-nullity theorem.
Screwdriver
129
Let [tex]V\subset\,R^n[/tex] be a subpace with [tex]dim(V) = D[/tex]. Prove that any [tex]S[/tex] vectors in [tex]V[/tex] are linearly dependent if [tex]S > D[/tex].
Rank-nullity theorem?
[tex]dim(V) = D[/tex] implies that there are [tex]D[/tex] vectors in a basis for [tex]V[/tex]. If [tex]S > D[/tex] then there will be at least one more vector in the set, which will result in a free variable and thus, infinite solutions; implying that the set will be linearly dependent.
For the sake of illustration, suppose we are working in [tex]V = R^2, D=2[/tex], and suppose you choose [tex]S=3[/tex] vectors. You desire to prove that these three vectors must be linearly dependent in [tex]R^2[/tex].
Form a linear combination of these vectors. You desire to verify whether or not
[tex]a_1v_1 + a_2v_2 + a_3v_3 = 0[/tex]
holds true when not all [tex]a_i = 0[/tex].
Form a matrix where the columns of the matrix are your S vectors from V. The matrix will then have n rows and s columns. The linear combination above can then be expressed (in the case of our specific example) something like:
[tex]\left(\begin{array}{ccc}v_{11} & v_{12} & v_{13} \\
v_{21} & v_{22} & v_{23} \end{array}\right) \cdot \left(\begin{array}{c}a_1 \\ a_2 \\ a_3 \end{array}\right) = 0[/tex]
where
[tex]v_i = v_{1i}\hat{e_1} + v_{2i}\hat{e_2}[/tex]
for some basis consisting of D vectors.
You can easily generalize this to a matrix with n rows and s columns.
The question arises as to what values of v, a does the above linear system have solutions for?
Clearly, if [tex]a_1=a_2=a_3=0[/tex], the system above holds true.
The question is, does it hold true when not all [tex]a_i = 0[/tex]?
If so, then the three vectors must be linearly dependent, which is what you desire to prove.
The direction you were heading in w/ the rank of a matrix, is probably the right direction to go..
Thank you. So say [tex]V = R^n, D=n[/tex] and [tex]S > n[/tex]. I'm trying to determine if there exists a non-trivial solution to the augmented matrix:
[tex]
\left[ {\begin{array}{cccc}
v_{11} & v_{12} & ... & v_{1S} \\
v_{n1} & v_{n2} & ... & v_{nS} \\
\end{array} } \right|
\left| {\begin{array}{c}
0_{1} \\
0_{n}
\end{array} } \right]
[/tex]
Which will row-reduce to:
[tex]
1 & 0 & ... & x \\
0 & 1 & ... & y \\
0 & 0 & 1 & z \\
0_{1} \\
0_{n}
[/tex]
Where [tex][x, y ... z][/tex] is some non-zero vector that will arise since [tex]S > n[/tex]. Then the solution set will be
[tex][a_{1}, a_{2} ... a_{S}] = [x, y ... z][/tex]
And the set will be linearly dependent as a result. Or is that just what I had originally?
given two vector-(sub)spaces [tex]V \subseteq W[/tex] then [tex]\dim(V) \le \dim(W)[/tex]. You can use this fact to derive a contradiction.
I wouldn't even mess around w/ an augmented matrix, or trying to actually, "physically" reduce the matrix into some kind of row-echelon form.
Just consider the linear system:
[tex]A \cdot x = 0[/tex]
A is a k-by-n matrix.. that is, it has k rows and n columns.
x is an n-dimensional vector.
0 is the k-dimensional 0-vector.
This equation is a statement on the linear dependence of the vectors which make up the columns of the matrix A.
If the only "solution" to this equation is the "trivial" solution x=0, then by definition the vectors which make up the columns of A are linearly independent.
If there exist "non-trivial" solutions to this linear system, where [tex]x \neq 0[/tex], then by definition the vetors which make up the columns of A are linearly dependent.
If your problem statement, you have a vector space where dim(V)=k, and you are selecting n vectors from this space where n > k. You want to show that these n vectors must be linearly dependent. You can model your problem in the above system since dim(V)=k, and so every vector v in V can be expressed as a linearly combination of k basis vectors. Choose any basis of k linearly independent vectors, and construct the matrix A as above.
You will have, by construction of your problem, a linear system where k < n.
By construction, you know that rank(A) <= k < n.
If you have a matrix with n columns and k rows, and you know that k < n, i.e., that the rank of the matrix is < n, what you can conclude about the linear dependence of the columns making up the matrix?
I don't want to give away the *whole* answer, but it's a standard result from linear algebra.. probably in your textbook somewhere.
Shilov treats it at the start of Chapter 3 in his classic on linear algebra.
I just realized you might need the statement from the first post to prove this claim. Not sure tough
I can conclude that the columns must be linearly dependent. I know that the rank is the number of linearly independent columns, so if I've got k of those but k < n columns in total, the leftover column(s) will have to be a non-trivial linear combination of the others. That then implies that the x vector in Ax = 0 will be non-trivial as well, right?
I'm still not sure how that's different from just making an augmented matrix though (sorry; I'm useless at Linear Algebra).
This is merely a question of knowing basic vocabulary and definitions.
Proof: Given any basis set {v1, v2, ... vD} in D-Dimensional space, the set is both linearly independent and "spans" the vector space. Now if you introduce a new vector, say vK, then Span({v1,v2, ... , vD, vK}) \subseteq \!\, Span({v1,v2, ... , vD}), where this relation follows because the second set spans the full space of V. Now because it spans the space we have that any vector can be written as a linear combination of D number of vectors:
a1v1 + a2v2 + ... a(D-1)v(D-1) + aDvD = bvK (****): a1,...aD, and b are scalars under the number field. Notice that in this case b = 1.
Now take that extra vector and concatenate it to the set to construc the set under question...
Now is it true that c1v1 + c2v2 + ... + cDvD + c(D+1)vK = 0 such that c1 = c2 = ... = cD = c(D+1) = 0 for all such scalars c1,c2,...cD,c(D+1)?
NO! Look at (****) if you don't immediately see it now.
QED.
Yes, essentially.
You mentioned in the OP something about a "rank-nullity" theorem.
I'm not sure exactly what you meant about "rank-nullity" theorem, but yes, the rank of a matrix is the number of linearly independent columns (or rows), and so if the number of rows is k, then you must have rank(A) <= k.. and if you know k < n (strictly less than), where n is the number of columns, then you can conclude that the columns of the matrix must be linearly dependent.
You can also think of it in terms like the following: suppose you are working in an n-dimensional vector space, and you have a basis (x1,...,xn) consisting of n vectors. That means that if we have:
[tex]a_1x_1 + ... + a_nx_n = 0[/tex]
then necessarily
[tex]a_1 = ... = a_n = 0[/tex]
Now consider another vector x0 from this same vector space, and consider the linear combination:
[tex]a_0x_0 + a_1x_1 + ... + a_nx_n = 0[/tex]
Suppose [tex]a_0=0[/tex]. Then we must necessarily have [tex]a_1 = ... = a_n = 0[/tex], since the basis is linearly independent.
Suppose now that [tex]a_0 \neq 0[/tex]. Then we can rewrite this equation as:
[tex]x_0 = - \left(\frac{a_1}{a_0}x_1 + \frac{a_n}{a_0}x_n\right)[/tex]
If x0 is not the zero vector, it must therefore be a linear combination of the basis vectors.
In other words, the set of vectors x0 + the basis vectors is linearly dependent.
I see now. Thank you so much to everyone :smile:
FAQ: Linear Algebra Dimension Proof
What is linear algebra?
Linear algebra is a branch of mathematics that deals with the study of vector spaces, linear transformations, and systems of linear equations.
What is dimension in linear algebra?
Dimension in linear algebra refers to the number of independent vectors that span a vector space. It is often denoted by the letter 'n' and represents the size or extent of a vector space.
How is dimension determined in linear algebra?
The dimension of a vector space is determined by finding the number of linearly independent vectors in the space. This can be done by using the rank-nullity theorem or by finding the number of pivot columns in the reduced row echelon form of a matrix.
How is linear algebra used to prove dimension?
In linear algebra, dimension is proved using various methods such as the rank-nullity theorem, the spanning set method, the linear dependence method, or the dimension theorem. These methods involve determining the number of linearly independent vectors in a given vector space.
What are some practical applications of linear algebra in dimension proof?
Linear algebra and dimension proof have numerous practical applications in fields such as physics, engineering, computer science, and economics. They are used to model real-world systems, solve optimization problems, and analyze data. For example, in computer graphics, linear algebra is used to represent and manipulate 3D objects in a 2D space.
