Linear Algebra (eigenvectors, eigenvalues, and orthogonal projections)
In summary: The Attempt at a Solution continuedc) Show that n=<1,1,1> is orthogonal to {v1 ,v2}I just took the dot product of n*v1 and n*v2 and both were zero, so n is orthogonal to both v1 and v2.
Wm_Davies
51
I am part way done with this problem... I don't know how to solve part e or part f. Any help or clues would be greatly appreciated. I have been trying to figure this out for a couple days now.
W={<x,y,z>, x+y+z=0} is a plane and T is the orthogonal projection on it.
a) Find the basis of {v1, v2} for this subspace.
b) These basis vectors are basis vectors for what eigenvalue?
d) Show that n is orthogonal to all of W
e) n is an eigenvector for T for what eigenvalue
f) Using matrix with eigenvectors and one for eigenvalues, find the standard matrix of T.
I found the basis of W to be v1=<-1,1,0> and v2=<-1,0,1>
I found the eigenvalue to be zero after multiplying W with v1 and v2.
My reasoning is that n is orthogonal to all of W because W is a linear combination of {v1 ,v2}
so you need to find the matrix T, which projects any vector onto the plane W
actually for e) you don't need to find T first, what is the projection of n onto the plane? once you consider that the eigenvalue should be obvious
I am interested to see the answer to e) and f) myself... Landedance (or anybody) can you finish this example??
For b) the eigenvalue is not zero, as the vector is within the plane, the projection onto the plane will be the vector itself, so
T.v1=v1
From which u should be able to read off the eigenvalue
The reasoning behind a, c, d is ok
so why do you need a matrix with eigenvectors and one with eigenvalues to find the standard matrix T?
Is it a diagonalization problem where T=A and A=PDP^-1 where D is a matrix of the eigenvalues and P a matrix of the eigenvectors?
Is there a repeated eigenvalue? seems like T must be 3x3 since the basis, <-1,1,0> and <-1,0,1> are in R3 right? So there must be a 3rd vector? and a repeated eigenvalue?
Then you could use PDP^-1 to find A right?
Okay so if T is an othogonal projection onto W then the eigen values for {v1, v2} must be 1 then right?
And if n is orthogonal to W then T*(n) should be equal to zero right? That would make the eigenvalue for n equal to zero.
So to find the standard matrix of T I could set P=[n,v1,v2] which would then make the diagonal matrix D=[0,1,1]
I think that this is correct, but I am not sure.
(I am typing this on my iPod so I can't really put in the full matrices, but I am sure you get the idea.)
Yes, if I understand ur matrix correctly, then u have the right idea and the eigenvalues are correct
Okay, I am at my computer so just to make sure we both understand each other...
[tex]
P = \begin{pmatrix} 1 & -1 & -1 \\ 1 & 1 & 0 \\ 1 & 0 & 1 \end{pmatrix}
[/tex]
[tex]
D = \begin{pmatrix} 0 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 1 \end{pmatrix}
[/tex]
Since P-1TP=D
So then PDP-1=T
Then [tex]
T = \begin{pmatrix} \frac{2}{3} & \frac{-1}{3} & \frac{-1}{3} \\ \frac{-1}{3} & \frac{2}{3} & \frac{-1}{3} \\ \frac{-1}{3} & \frac{-1}{3} & \frac{2}{3} \end{pmatrix}
[/tex]
it would be easier to normalise you eigenvectors first, as then P^{-1} = P^Tm but that's the idea
to check, see whether you your eigenvectors behave as you would expect
What do you mean by P^Tm?
Is T in this sense a transpose or the matrix T? Also what is m?
Thank you for all your help so far it has really helped me clear up a lot of things!
sorry for the poor notation, but yes i meant the transpose, m was a mistype
Related to Linear Algebra (eigenvectors, eigenvalues, and orthogonal projections)
1. What are eigenvectors and eigenvalues in linear algebra?
Eigenvectors are special vectors in a linear transformation that do not change direction when transformed. Eigenvalues are the corresponding scalars that represent the magnitude of the transformation along the eigenvector.
2. What is the significance of eigenvectors and eigenvalues in linear algebra?
Eigenvectors and eigenvalues are important in linear algebra because they provide a way to describe and analyze linear transformations. They also have practical applications in fields such as physics, computer graphics, and economics.
3. How are eigenvectors and eigenvalues calculated?
Eigenvectors and eigenvalues can be calculated using a variety of methods, including solving a system of equations, finding the roots of a characteristic polynomial, or using iterative methods. The specific method used will depend on the size and complexity of the linear transformation.
4. What is an orthogonal projection in linear algebra?
An orthogonal projection is a type of linear transformation that projects a vector onto a subspace in a way that preserves orthogonality. This means that the projected vector is perpendicular to the subspace it is projected onto.
5. How are orthogonal projections used in real-world applications?
Orthogonal projections are commonly used in applications such as image and signal processing, where they can be used to remove noise or enhance certain features. They are also used in data analysis and machine learning to reduce the dimensionality of data and improve performance.
