Linear Algebra - Find the value of a such that 2 lines lie in a plane
This will get you an equation that looks very similar to what you have now, but with an absolute value.But that's not what you asked for. Do you know what a plane is? In summary, to find the value of a such that L1 and L2 lie in a plane, we can set up equations for each line and set them equal to each other. By solving for s and t and substituting them into the equation for one of the lines, we can find that a is equal to 5t + 7. However, since t is arbitrary, a can take on any value. Therefore, there is no single value of a that will guarantee that L1 and L2 lie in a plane.
cris623
Linear Algebra - Find the value of "a" such that 2 lines lie in a plane
Consider the lines L1 and L2 with the following equations:
L1: (x y z)=(7 4 −4)+t(2 2 −2)
L2: (x y z)=(a 4 −4)+s(−3 2 −2)
Find the value of a such that L1 and L2 lie in a plane.
They also gave the hint : What must the minimal distance between the two lines be if we are to be sure they lie in the same plane?
I tried to find the intersection of the two lines
To solve I tried to set up the equations for individual x,y,x coordinates:
L1:
x=7+2t
y=4+2t
z=-4+2t
and L2:
x=a-3s
y=4+2s
z=-4-2s
and then set the equations equal to each other as:
7+2t=a-3s
4+2t=4+2s
-4+2t=4-2s
and then set up a matrix to solve for variables a, s and t
The final time I reduced I got :
(1 -3 -2 | 7)
(0 0 0 | 0)
(0 0 0 | 0)
I'm assuming my thought process was a little off and I'm not too sure where to go from here, and I'm kind of confused how the hint about minimal distance applies to this problem.
Thanks in advance!
L1:
x=7+2t
y=4+2t
z=-4+2t
Your equation for z, above, is incorrect. It should be z = -4 - 2t.
cris623 said:
and L2:
x=a-3s
y=4+2s
z=-4-2s
7+2t=a-3s
4+2t=4+2s
-4+2t=4-2s
The mistake from above is now in your last line, and you have introduced another. The last line should be which should be -4 - 2t = -4 - 2s.
This means that your last two equations are equivalent, so the third is redundant. From the 2nd equation, you can deduce that t = s.
(1 -3 -2 | 7)
(0 0 0 | 0)
(0 0 0 | 0)
Thanks in advance!
Thanks for the catch on my equation for z. Right before you posted I realized that t=s.
Alright so I switched up my matrix a bit and put "a" on the right hand side and solved for s and t. I got t=(7-a)/-5 and s=(7-a)/-5 which just showed that s and t were equal to each other which I already knew.
Then subbed s and t into the first equation - 7+2t=a-3s hoping I'd be able to solve for a.
Instead I got
-5a+35=14-2a+21-3a which just simplifies to 35=35 and that's pretty obvious.
I'm so lost on how to solve this
I solved for a, and got a = 5t + 7, which is equivalent to what you got. t is arbitrary, so pick a value of t to get a value of a.
Instead I got
My assignment indicates that there should only be one answer. Even though both you and I came to the conclusion that a varies based on what the value of t is.
unless you meant the answer is a=5t+7?
That's what I got for a, but I haven't taken it very much further. I arbitrarily set t = 0 (and s = 0), to get a = 7, but that's the same result as if you merely observed that when a = 7 and s = t = 0, you get the point (7, 4, -4), which is on both lines.
In the hint that's given, the minimal distance they're talking about has to be zero, so we have that, although not in some more elegant manner.
A nicer way to approach the problem is to get an expression that represents the distance between two arbitrary points (one on each line), and then minimize that, either by calculus or by a method that involves vectors and projections and such.
FAQ: Linear Algebra - Find the value of a such that 2 lines lie in a plane
1. What is the definition of a plane in linear algebra?
A plane in linear algebra is a two-dimensional flat surface that extends infinitely in all directions. It can be represented by a set of coordinates and is often denoted by the letter "P".
2. How can you determine if two lines lie in a plane?
If two lines are parallel, they lie in the same plane. Otherwise, if two lines intersect at a single point, they also lie in a plane. You can also use the vector equation of a plane to determine if two lines lie in that plane.
3. What is the vector equation of a plane?
The vector equation of a plane is r = r0 + a1v1 + a2v2, where r is the position vector of a point in the plane, r0 is the position vector of a point on the plane, a1 and a2 are scalar parameters, and v1 and v2 are two non-parallel vectors in the plane.
4. How do you find the value of a in the vector equation of a plane?
To find the value of a, you can use the coordinates of two points on the plane and set up a system of equations, solving for a to determine the specific plane that the lines lie in.
5. Can three lines lie in the same plane?
Yes, three non-parallel lines can lie in the same plane if they all intersect at a single point. However, if the lines are parallel or do not intersect, they cannot lie in the same plane.
