[Linear Algebra] Maximal linear independent subset
In summary: I see something else:## \begin{matrix} 1 & 1 & 0 & 2\\ 0 & 1 & 1 & 0\\ 1 & 1 & 0 & -1\\ 0 & 1 & 1 & 0\\ \end{matrix}##In summary, the method for determining whether a vector space is spanned by a set of vectors involves creating a matrix with the vectors as columns. The rank of this matrix can then be calculated using row operations, and if the rank is equal to the number of vectors, the vectors are linearly independent and span the space.
iJake
41
In the follow cases find a maximal linearly independent subset of set ##A##:
(a) ##A = \{(1,0,1,0),(1,1,1,1),(0,1,0,1),(2,0,-1,)\} \in \mathbb{R}^4##
(b) ##A = \{x^2, x^2-x+1, 2x-2, 3\} \in \mathbb{k}[x]##
The first part of the exercise is trivial, as it is easy to observe that the second vector is a linear combination of the first and third vectors. My question is one of mechanics. Should I be writing the elements of each vector as the rows or columns of a matrix?
In a previous exercise, I had to determine whether or not a vector space was spanned by a set of vectors. In that case, it was:
Determine if ## V = \mathbb{k}[x]_3## is spanned by ##A = \{1, 1+x^2, 1-x+x^2+x^3, 4-x+2x^2+x^3\}##
I reordered the elements and presented them as the columns of a matrix:
\begin{matrix}
0 & 0 & 1 & 1\\
0 & 1 & 1 & 2\\
0 & 0 & -1 & -1\\
1 & 1 & 1 & 4\\
\end{matrix}
I did row operations (switch R4 with R1, then with R3, add R3 to R4) and found a row of 0s, thus telling me the rank of the matrix is 3 and that A does not span V.
However, for my current problem, I wrote the matrix using the vector elements as rows, not columns. When I write them as columns I do not reach the same conclusion, which confuses me.
\begin{matrix}
1 & 0 & 1 & 0\\
1 & 1 & 1 & 1\\
0 & 1 & 0 & 1\\
2 & 0 & -1 & 0\\
\end{matrix}
Here I clearly observe that the second row is the sum of the first and third rows. However, if I write it where the vector elements are columns, I see something else:
\begin{matrix}
1 & 1 & 0 & 2\\
0 & 1 & 1 & 0\\
1 & 1 & 0 & -1\\
0 & 1 & 1 & 0\\
\end{matrix}
Can someone explain the difference to me? Thanks.
It might be because the last matrix has an error in it. The bottom left element should be 0, not 1.
If all you are trying to do is test whether n vectors in a n-dimensional space are independent, by calculating the rank of a matrix, you should get the same result regardless of whether you make the vectors rows or columns. I think it is more usual to make the vectors columns, but that's just convention.
Sorry, that was just a typo. It's fixed now, and I find that R4 - R2 gives me a row of 0s and that the rank of that matrix is 3. Is it irrelevant that the linearly dependent vector corresponds to the second column of the matrix, in this case?
\begin{matrix}
0 & 0 & 1 & 1\\
0 & 1 & 1 & 2\\
0 & 0 & -1 & -1\\
1 & 1 & 1 & 4\\
\end{matrix}
\begin{matrix}
1 & 0 & 1 & 0\\
1 & 1 & 1 & 1\\
0 & 1 & 0 & 1\\
2 & 0 & -1 & 0\\
\end{matrix}
\begin{matrix}
1 & 1 & 0 & 2\\
0 & 1 & 1 & 0\\
1 & 1 & 0 & -1\\
0 & 1 & 1 & 0\\
\end{matrix}
Both
$$A = \begin{bmatrix}
1 & 0 & 1 & 0\\
1 & 1 & 1 & 1\\
0 & 1 & 0 & 1\\
2 & 0 & -1 & 0\\
\end{bmatrix}
and its transpose
$$B = \begin{bmatrix}
1 & 1 & 0 & 2\\
0 & 1 & 1 & 0\\
1 & 1 & 0 & -1\\
0 & 1 & 1 & 0\\
\end{bmatrix}
have the same row and column ranks---3 in this case.
If you perform row-operations on ##A## you will produce a new matrix whose rows are linear combinations of the row-vectors ##\vec{a}_i## in ##A##, so will be manufacturing directly some linear combination ##c_1 \vec{a}_1 + c_2 \vec{a}_2 + c_3 \vec{a}_3 + c_4 \vec{a}_4## that is the zero (row) vector; that will be the "all-zero" row of the transformed matrix. When you perform row operations on ##B## that is not what you are doing: the new columns are not linear combinations of the old columns, and row operations that produced a zero-row in ##A## will not necessarily produce a zero row in ##B##---although, of course, some other row operations will do so. To find out what linear combinations of the column vectors ##\vec{b}_i## in ##B## are needed to get the zero (column) vector, we need to find ##k_i## that give ##k_1 \vec{b}_1 + k_2 \vec{b}_2 + k_3 +\vec{b}_3 + k_4 \vec{b}_4 = \vec{0}##. That can be done by solving the equation system
$$B \vec{K} = \vec{0},$$
where
$$\vec{K} = \pmatrix{k_1\\ k_2 \\ k_3 \\ k_4}.$$
Row operations on ##B## are just helping you to solve that system of equations.
Related to [Linear Algebra] Maximal linear independent subset
1. What is a maximal linear independent subset?
A maximal linear independent subset is a subset of vectors within a vector space that contains the greatest number of linearly independent vectors possible. This means that no vector in the subset can be written as a linear combination of the other vectors in the subset.
2. Why is finding a maximal linear independent subset important?
Finding a maximal linear independent subset is important because it allows us to reduce the dimensionality of a vector space without losing important information. This can simplify calculations and make it easier to solve certain problems in linear algebra.
3. How do you determine if a subset is linearly independent?
A subset is linearly independent if none of the vectors in the subset can be written as a linear combination of the other vectors. This can be determined by setting up a system of equations and solving for the scalars in the linear combination. If the only solution is when all the scalars are equal to zero, then the subset is linearly independent.
4. Can a maximal linear independent subset be larger than the basis of a vector space?
Yes, a maximal linear independent subset can be larger than the basis of a vector space. This is because a basis is a minimal set of vectors that span the entire vector space, while a maximal linear independent subset can contain any number of linearly independent vectors.
5. What is the relationship between maximal linear independent subsets and matrix rank?
The size of a maximal linear independent subset is equal to the rank of the matrix that represents the vectors in the subset. This is because the rank of a matrix is the maximum number of linearly independent columns or rows in that matrix. Therefore, finding a maximal linear independent subset can help us determine the rank of a matrix.
