sbj5533
- 1
Let w=span(w1, w2, ...,wk) where wi are vectors in R^n. Let dot product be inner product for R^n here. Prove that if v*wi=0 for all i-1,2,...,k then v is an element of w^upside down T (w orthogonal).
The span of a set of vectors in linear algebra is the set of all possible linear combinations of those vectors. In other words, it is the set of all vectors that can be created by multiplying each vector by a scalar and adding them together.
To prove that a set of vectors spans a vector space, you must show that every vector in the vector space can be written as a linear combination of the set of vectors. This can be done by setting up a system of equations and solving for the coefficients of the linear combination.
An orthogonal vector space is a vector space where all the vectors are perpendicular to each other. This means that the dot product of any two vectors in the space is equal to zero.
To prove that a set of vectors is orthogonal, you must show that the dot product of any two vectors in the set is equal to zero. This can be done by calculating the dot product and showing that it equals zero.
No, a set of non-orthogonal vectors cannot span an orthogonal vector space. In order for a set of vectors to span an orthogonal vector space, they must be orthogonal to each other. If the set of vectors is not orthogonal, then the span of those vectors will not be an orthogonal vector space.
