MHB Linear Algebra Proofs and Problems
The discussion focuses on the sharing and correction of linear algebra problems and proofs, with a link to a Google Docs document provided due to file size limitations. The document contains undergraduate-level problems and theorems, but it cannot be edited directly, necessitating corrections to be posted in the thread. Specific problems needing solutions and verification are outlined, while a separate PDF includes more advanced proofs. Feedback on the initial document highlights necessary adjustments, including clarifications on eigenvectors, typos, and misconceptions about linear independence versus orthogonality. Participants are encouraged to post comments and questions in the designated thread.
Dustinsfl
We used to have a bunch of problems and proofs that were in a pdf could be downloaded by anyone. Since we aren't able to upload pdf files of a certain size, I provided a link to google docs. If there is an error, typo, or something is just drastic wrong let me know.
Undgraduate Final Review Practice problems with solutions
Theorems/Proofs Undergraduate level
However, with this first link, I can't edit this document. It was created with Maple which I no longer have. So errors have to just be corrected in the thread and then consolidated for readability.
This pdf has more advanced proofs in it.
Linear Alg Workbook
I have completed the second set. The only ones that need solutions are $A5$ part 2, $B7$ part2, $C4$ part 2 and 3, $C5$, $D4$, $F7$ needs to be checked, $H3$, $H10$, $I4$ part 3, $I5$, $I10$ part 2, $J7$, and $J10$.
The rest of the problems I believe to be right but they should still be checked out.
Comments and questions should be posted here:
http://mathhelpboards.com/commentary-threads-53/commentary-linear-algebra-proofs-problems-4230.html
For the first document, here is what Ackbeet$\equiv $Ackbach suggested on MHF that needed to be adjusted
Ackbeet said:
Very nice review! I just had a few comments:1. From Test 5, Problem 4, on page 4. I would say more than eigenvectors must be nonzero, by definition. It's not that the zero eigenvector case is trivial: it's that it's not allowed.2. Page 6, Problem 8: typo in problem statement. Change "I of -I" to "I or -I".3. Page 8, Problem 21: the answer is correct, but the reasoning is incorrect. It is not true that $\mathbf{x}$ and $\mathbf{y}$ are linearly independent if and only if $|\mathbf{x}^{T}\mathbf{y}|=0.$ That is the condition for orthogonality, which is a stronger condition than linear independence. Counterexample: $\mathbf{x}=(\sqrt{2}/2)(1,1),$ and $\mathbf{y}=(1,0).$ Both are unit vectors, as stipulated. We have that $|\mathbf{x}^{T}\mathbf{y}|=\sqrt{2}/2\not=0,$ and yet
$a\mathbf{x}+b\mathbf{y}=\mathbf{0}$ requires$a=b=0,$ which implies linear independence.Instead, the argument should just produce a simple counterexample, such as $\mathbf{x}=\mathbf{y}=(1,0)$.Good work, though!
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 24 ·
