Linear and nonlinear physical theories
In summary, classical physics is a nonlinear theory, but why is it that? Classical mechanics is not linear because the differential operators are fixed by Newton's second axiom, while different physical systems correspond to different functional dependencies in the equations of motion.
Higgsono
93
Classical physics is a nonlinear theory, but how is it that? Why is it nonlinear? Also quantum mechanics is a linear theory so that the sum of the solutions of the schrödinger equation is itself a solution.
But I'm not sure I grasp this completely. Why is quantum mechanics linear while classical mechanics is not? Could someone give an example why classical mechanics is not linear.
The crucial thing to look at are the equations of motion and what they are about.
In classical electrodynamics, the equations of motion are the Maxwell equations. They can be essentially expressed by certain linear operators (differential operators) acting on the fields [itex]\vec E(\vec r,t)[/itex] and [itex]\vec B(\vec r,t)[/itex], so they are linear.
In wave mechanics, we have the Schrödinger equation where the wavefunction [itex]\psi(\vec r_1,\vec r_2,...,t)[/itex] is also acted upon by a linear operator (the Hamiltonian). Different physical systems correspond to different linear operators.
In classical mechanics, the differential operators are essentially fixed by Newton's second axiom. Instead, different physical systems correspond to different functional dependencies on the positions [itex]\vec r_i[/itex] in the equations of motion. (Here is an example of a nonlinear equation of motion: the pendulum. Also, typical forces between interacting bodies lead to nonlinear equations of motion)
So in order to emphasize the difference between classical mechanics and wave mechanics, imagine that we have two particles and add a potential term of the form [tex]\frac{1}{|\vec r_1 - \vec r_2|}[/tex] In classical mechanics, this causes the equations of motion to become nonlinear in the [itex]\vec r_i[/itex]. In wave mechanics, the change occurs only in the linear operator which acts on the wave function. We never get something like [itex]\frac{1}{\psi}[/itex].
(Ironically, I just found out that the classical Kepler problem can be expressed in linear form. Of course, this doesn't change the main point.)
There are aspects of classical mechanics which are linear (e.g. simple harmonic motion), and aspects which are nonlinear (space motions of a free rigid asymmetric body). Most aspects of non-relativistic quantum mechanics at the graduate level are linear (quantum harmonic oscillator, free particle), but not all of quantum mechanics is linear (quadratic terms are often eliminated in perturbation theory). The non-linear schroedinger equation is generally not presented at this level.
Related to Linear and nonlinear physical theories
1. What is the difference between linear and nonlinear physical theories?
Linear physical theories are those in which the output of a system is directly proportional to the input, while nonlinear physical theories are those in which the output is not directly proportional to the input. In other words, the relationship between input and output in linear theories can be represented by a straight line, while in nonlinear theories it cannot.
2. How are linear and nonlinear physical theories used in scientific research?
Linear and nonlinear physical theories are used to model and understand various physical phenomena in the natural world. They are also used to make predictions and test hypotheses, as well as to design experiments and analyze data.
3. Can a physical theory be both linear and nonlinear?
No, a physical theory is either linear or nonlinear. However, some systems may exhibit both linear and nonlinear behavior, depending on the input or conditions.
4. What are some examples of linear physical theories?
Some examples of linear physical theories include Newton's laws of motion, Ohm's law, and the ideal gas law. These theories describe the relationship between input and output in a linear manner and are widely used in physics, engineering, and other scientific disciplines.
5. Are there any real-world applications of nonlinear physical theories?
Yes, there are many real-world applications of nonlinear physical theories. Some examples include chaos theory, which is used to study complex systems such as weather patterns and population dynamics, and nonlinear optics, which is used in the development of advanced technologies such as optical computing and telecommunications.
