Linear Charge Density and Divergence: Finding the Variation of D
In summary, the charge density increases linearly with distance from the origin and can be represented as pv=5R. To find the corresponding variation of D, we can use the integral form of Gauss law and take advantage of the spherical symmetry of the problem. By choosing the Gauss surface as a sphere with the center at the origin, we can easily evaluate the right hand side of the equation and determine the variation of D.
dcfan
If the charge density increases linearly with distance from origin such that pv=0 at the origin and pv=10 C/m^3 at R=2, find the corresponding variation of D.
So we know that for R=0, pv = 0 and for R=2, pv=10 C/m^3.
We know that the charge density increases linearly from origin
Gauss law: divergence(D) = pv
For a sphere: divergence(D) = 1/R^2 d/dR(R^2*AR) + 1/(R*sin(teta)) d/d(teta) (A(teta)*sin(teta)) + 1/(R*sin(teta))*dA(phi)/d(phi)
I found the relationship between sigma and R (because it is linear) and it is:
pv(R) = 5R
Then after I don't know how to find the variation of D. How can I get a variation of D from a divergence? I made some research on the internet and found nothing clear enough for me to understand.
Why don't you try the integral form of Gauss law? :wink: Notice the spherical symmetry of the problem.
I don't see how it can help me more to solve the problem...
Gauss law: [tex]\oint_S\vec{D}d\vec{A} = \int\int\int_V\rho dV[/tex]
You know the variation rule of [tex]\rho[/tex] in space, so the right hand side can be easily evaluated for any chosen volume V enclosed by a closed surface S. Plus that the system has spherical symmetry about the origin, [tex]|\vec{D}|[/tex] is the same at every point which has the same distance to the origin. Therefore you can choose the Gauss surface S as a sphere whose center is the origin.
thx very much Hikaru!
FAQ: Linear Charge Density and Divergence: Finding the Variation of D
What is electromagnetism?
Electromagnetism is a branch of physics that studies the relationship between electricity and magnetism. It explains how electrically charged particles interact with magnetic fields and how moving electric charges produce magnetic fields.
What is an electromagnet?
An electromagnet is a type of magnet that is created by running an electric current through a wire. The magnetic field produced by the electric current can be controlled by adjusting the amount of current flowing through the wire.
3. How does electromagnetism impact our daily lives?
Electromagnetism is essential in modern technology and plays a significant role in our daily lives. It is used in electricity generation, communication systems, transportation, and medical equipment such as MRI machines.
4. What is the difference between an electromagnet and a permanent magnet?
The main difference between an electromagnet and a permanent magnet is that an electromagnet can be turned on and off by controlling the electric current, while a permanent magnet always produces a magnetic field.
5. What are the applications of electromagnetism in the field of science?
Electromagnetism has numerous applications in science, such as in the study of electricity and magnetism, electromagnetic radiation, and the behavior of particles at the atomic and subatomic levels. It is also used in fields like engineering, chemistry, and astronomy to understand and develop new technologies.
